Originally Posted by HiJoeSilver
Spookies, good timing, getting ready for this myself. Hope you don't mind if I hop in.
Dr Boyd, how did you attach to the ceiling? Similar to DavidF? Pocket screws into the aluminum? Any issues holding, screws coming loose? Can the back be pocket screwed horizontally from the bottom?
Im also trying to figure out how to support drawer slides where they go over wheel wells and can't transfer weight to floor.
I use small L-brackets screwed into the wood and riveted into the aluminum skin. Where it's just 1/4" paneling, I'll use a nut and bolt through the cabinet instead of a wood screw.
As to the drawers, (which I'm just about to do) I'll be using an upside-down L-shaped piece of 3/4" plywood that attaches to the floor, the underside of the countertop, and the inner skin. A pair of these will be connected together, and the drawer/door attached. Theoretically, the whole unit will slickly slide into place, be attached with a few screws, and then be done. All of my cabinets have curved faces, so this makes things even more problematic than they should be.
