Old 11-14-2017, 06:33 AM   #15
TRIPPPIN's Avatar
2012 25' FB Eddie Bauer
Southwestern Ontario , Ontario
Send a message via AIM to TRIPPPIN Send a message via MSN to TRIPPPIN Send a message via Yahoo to TRIPPPIN
We didn't need to move the furnace. There is enough space if you keep the recliner on an angle. When I built the new top over the furnace for the remaining couch(see pic) I took a small angle cut off the corner to make it fit better and so both recliners could recline. Our recliners do not swivel. I am not sure if your 25FB has the furnace in a different space but you can see where ours is under that new top.
TRIPPPIN is offline   Reply With Quote
Old 11-14-2017, 07:57 AM   #16
2017 27' Flying Cloud
Fort Wayne , Indiana
Remodel of 2017 27ft. FB Flying Cloud
Same complaints regarding the dinette and the long sofa that seemed out of place. Attached are photos of what we did and so far..... we love it!
kspan is offline   Reply With Quote
Old 11-14-2017, 08:26 AM   #17
Kensington , Maryland
Kspan that looks amazing. Would you mind putting up a couple more pics. esp. perspective where you are standing in the hallway looking twords the door?
2017 25' FC FB "Buck"
Too tall is offline   Reply With Quote
Old 11-14-2017, 09:57 AM   #18
Remodel 27' Flying Cloud
I'll have my wife see if there are any more that show a different angle but here is what I have that may help.
Old 11-14-2017, 10:06 AM   #19
We did all the work ourselves using most of what was already there. We purchased a few materials, but we were able to reconstruct the bed using the pull out to expand the sofa into a bed. The counter works well for eating as well as for computer work while on the road. We took one of the night stands from the bedroom and used it at the end of the sofa. Are having a new nightstand built now to replace the one in the bedroom.
Hope that helps!
Old 11-14-2017, 10:11 AM   #20
Kspan that helps some. Did you get rid of the subwoofer?
I REALLY like this. When I show this to Mrs. Too Tall she is going to want some changes.
Old 11-14-2017, 10:26 AM   #21
We disconnected it but saved it... just capped off the wires and bundled them. It is all open storage under the sofa so we can replace the sub-woofer if we want at any time.
Old 11-14-2017, 10:12 PM   #22
Vintage Kin
slowmover's Avatar
Fort Worth , Texas
Originally Posted by Rgentum View Post
Please see the attached photo about what we did with our 27 re our dinette etc.
Problem with dinettes is that one needs a big Class A for them to "work". Just not enough space.
Great solution!!
Hensley Arrow. 9-cpm solo, 15-cpm towing
Old 11-15-2017, 04:47 AM   #23
Hans627's Avatar
2009 25' FB International
2018 27' Globetrotter
Hanover , Pennsylvania
Attachment 299096
Attachment 299097
Very creative and nice work. And thanks for the explanation. A few more questions. So the base for the new sofa is from the area of the new table top? Did you have to get new cushions made?
Again, very well done!
Old 11-15-2017, 06:55 AM   #24
KJRitchie's Avatar
2008 25' Classic
Wichita Falls , Texas
Here is the link to all our changes. We did this as we are now full timing. Added another 200w to the roof (400w now) since this remodel.
http://www.airforums.com/forums/f366...al-160855.html
Old 11-16-2017, 02:14 PM   #25
Hans,
Yes, the sofa is made of 3/4" plywood cut from a pattern we used from the bench seating along the wall where the new counter top is now located. The new sofa is long enough to accommodate the slide out bed that was along the bench wall as well. We used the original cushions which fit perfectly and saved a lot of money.
We made the counter top of 3/4" plywood and laminated it ourselves.
Old 11-16-2017, 03:04 PM   #26
Half a Rivet Short
Carlisle , Pennsylvania
Hi
Our answer was to give up on those arrangements and get a different model
Essentially none of the seating made us happy. We spent a *lot* of time trying to force it to work. Move this, change that, rebuild something here. It all seemed to be to much of a compromise between working as a bed and working as a chair. To be a good mattress it needed to be shaped one way. To make a good chair cushion it needed to be shaped another way. Indeed the recliners are wonderful as chairs. You loose the bed function with them. That was fine with us. It might not be fine with everybody.
Old 11-22-2017, 11:41 AM   #27
1991 29' Excella
Livermore , California
Our dinette seating is very comfortable, but we’re not full timers. Maybe that makes a difference.
dennisv is offline   Reply With Quote
Old 11-22-2017, 12:20 PM   #28
Vintage Kin
slowmover's Avatar
Fort Worth , Texas
TT size dictates small furniture. Helps, as Americans keep shrinking.
Uncomfortable Dinette in 2015 23FB Randakk Interior Restoration Forum 10 05-18-2016 11:16 AM
extremely uncomfortable sofa or couch jjpandmtp 2009-2015 Flying Cloud 6 09-08-2014 04:31 PM
Uncomfortable lesson or merely coincidence? Goal15 Furnaces, Heaters, Fireplaces & Air Conditioning 5 06-22-2013 08:11 PM
Sofa is uncomfortable time2play Airstream Lifestyle 15 05-05-2013 09:31 PM
uncomfortable dinette hfc7713 Cabinets, Counter Tops & Furnishings 2 07-12-2009 07:21 PM
