Old 08-07-2014, 08:39 AM   #1
Whizzo's Avatar
2014 23' FB Flying Cloud
San Antonio , Texas
Images: 18
U-Shape Dinette is Useful
We've decided we really like the newer u-shaped dinette feature. Turning, then locking, the table 90 degrees from normal gives one person workspace, and the other lots of 'flop seating.' And you can still open the refrigerator.
Name:	ImageUploadedByAirstream Forums1407422356.847591.jpg
2014 Flying Cloud 23FB
2015 Ram 1500 EcoDiesel
Whizzo is offline   Reply With Quote
Old 08-07-2014, 09:01 AM   #2
Cannonball's Avatar
2014 22' FB Sport
San Antonio , Texas
This is a good idea.
Cannonball, Deep in the Heart of Texas!
WBCCI #4387, Air #84080
Cannonball is offline   Reply With Quote
Old 08-07-2014, 09:49 AM   #3
KJRitchie's Avatar
2008 25' Classic
Wichita Falls , Texas
Is the table top on tracks also so you can move it in and out from the aisle as well as rotating it like you show? When making the dinette into a bed are the corner curved cushions stowed under the table?
Kelvin
Old 08-07-2014, 03:23 PM   #4
Whizzo's Avatar
San Antonio , Texas
Images: 18
Yes Kelvin, you're correct on both. The table can be positioned about any way you like. We likely will never need to use the sleep mode, but it does convert easily. The table telescopes downward. Much easier than the older drop table designs.
Old 08-07-2014, 05:08 PM   #5
egraham's Avatar
2016 28' International
Birmingham , Alabama
On what models is the u shaped dinette available?
egraham is offline   Reply With Quote
Old 08-07-2014, 08:29 PM   #6
Whizzo's Avatar
San Antonio , Texas
Images: 18
The Flying Cloud 23FB and Sport 22FB are the two plans I've seen currently featuring it. Larger plans tend to have both a gaucho/ lounge and a booth-styled dinette. But like any Airstream, I bet a customizer could install one.
Old 08-07-2014, 09:30 PM   #7
LiLNomad's Avatar
2007 25' International CCD FB
Northridge , California
The 30ft bunk has the U shaped dinette
LilNomad
LiLNomad is offline   Reply With Quote
Old 08-08-2014, 05:42 PM   #8
is the pedestal removable from the floor and table top? If so how does the track system work?
Or is it designed to telescope downward and not be removed from the table?
pattonsr is offline   Reply With Quote
Old 08-09-2014, 12:11 PM   #9
Whizzo's Avatar
San Antonio , Texas
Images: 18
The pedestal appears to be designed to stay in place. The sliding track system has a latch pin under the tabletop. I have not tried to see if it will slide completely off the track, but I suspect it has a stop tab. The pedestal has two unlatching turnbuckles which allow it to rotate, and to collapse downward.
Plumbing Vents - Useful Info lebolewis 1974 - 1979 Sovereign 0 07-07-2006 06:22 PM
Oven useful or not? '70 Overlander blackboat Stoves, Ovens & Microwaves 20 06-17-2006 03:56 AM
N.A.D.A. value: Useful or bogus? tphan Trailer Values 10 05-13-2005 12:12 PM
Non-obvious but useful AS tips hohne On The Road... 3 05-24-2004 05:35 PM
