Old 07-15-2009, 10:46 AM   #1
SteveH's Avatar
Common Sense , Texas
Type of Wood Finish?
We have an '01 25' Excella and the interior wood is in need of some touch up finish in places. Does anyone know what type of finish it is? It appears to be some sort of laquer finish, but I'd like to know for sure if possible, before I try to touch it up.
Old 07-15-2009, 01:34 PM   #2
1963 24' Tradewind
San Diego , California
There are a number of products on the market that will work. I'm not familar with a unit that new, mine is a 63. First determine the sheen, gloss, semi-gloss, low-sheen, matt, flat etc. If it is a lacquer, there is a product called DEFT, it is a brushable lacquer that dryes fast 5-10 min. I has a nice look and fairly e-z to use and dosen't have that heavy build up look that polyurathane, varnish etc. have. I know there is alot of talk and opinons on these forums reguarding the wood finish. Good Luck!!
Sixty3TW4US is offline   Reply With Quote
Old 07-15-2009, 03:49 PM   #3
purman's Avatar
1968 28' Ambassador
Cedaredge , Colorado
I would use Lacquer or shellac. These will give you the best finish. The Lacquer you will need to vent very well as it has a strong smell and can make you feel really happy....
Jason
2008 5.7 L V8 Sequoia
AIR # 31243
WBCCI # 6987
FOUR CORNERS UNIT
Old 07-15-2009, 05:37 PM   #4
SteveH's Avatar
Thanks for your input. I do have some experince with finishing wood, and I would very much like to use a product of the same base at least, if not the exact product originally used on the wood.
Do you suppose Airstream customer service could tell me?
Old 07-16-2009, 10:30 AM   #5
1963 24' Tradewind
I would most definitely contact them. Your unit is still fairly new and i think they would know.
Old 08-18-2009, 07:46 AM   #6
SteveH's Avatar
Just an update on this subject....I talked with Airstream, and they told me the finish on the wood in my trailer is a laquer based finish.
So, I looked around in my stash of old paints and varnishes, and found a half can of a product called Deft, semi gloss, which is laquer based. Used it to touch up the areas needing assistance, and it looks great. Just like new.
Thanks for everyone's input on this.
What type of wood to use? LI Pets Cabinets, Counter Tops & Furnishings 48 06-22-2011 04:56 AM
Which finish on vintage wood? InsideOut Cabinets, Counter Tops & Furnishings 47 03-28-2009 06:52 PM
What Type of Restoration is Your Type? ankornuta General Repair Forum 16 11-21-2005 04:13 PM
Tow bar receiver type or ball type? Astrodokk Airstream Motorhome Forums 2 06-09-2004 07:20 PM
Wood veneer type Silver Bullet Cabinets, Counter Tops & Furnishings 7 03-25-2004 06:46 PM
