Old 03-04-2007, 02:39 PM   #1
RNR
2007 25' Safari
Yadkinville , North Carolina
Twin bed support question
We recently bought a 25' Safari with twin rear beds. The mattresses extend approximately 4" over the base support. Has anyone come up with an idea for providing support for the edge of the mattresses short of adding heavy 3/4" plywood over the existing frame?
RNR
RNR is offline   Reply With Quote
Old 03-04-2007, 02:54 PM   #2
CanoeStream's Avatar
St. Cloud , Minnesota
This is a recognized pattern for newer Airstream twins. It gets annoying -- can't sit on the edge without causing the bedcovers to drift off onto the floor after a while. By contrast, my Argosy twin mattresses are fully supported by a frame of 1" square aluminum tubing and 1/4" lauan ply.
5 meter Langford Nahanni
Old 03-04-2007, 03:32 PM   #3
wheel interested's Avatar
2007 23' International CCD
Lapeer , Michigan
I think Pahaska did a modification with support for the bed so he could sit on the edge and not have the mattress sag, but I can not find the specific post. Perhaps a pm to him will do it. John is very helpful here on the forums and does many DIY modifications and has a column in Airstream Life.
Caroljb
photography
wheel interested is offline   Reply With Quote
Old 03-04-2007, 04:44 PM   #4
Happycampers's Avatar
1979 30' Argosy
Havelock , where we park it
Hello... You might check to see if these are full twin mattresses or bunk size.. our other Argosy had mid twins and they were bunk size twins.. check out measurements..
Marvin & Annie
Niki (fur baby)
1979 Argosy 30 (Costalotta)
WBCCI 10103
"Happiness is a warm Puppy" Charles Schulz
Happycampers is offline   Reply With Quote
Old 05-20-2009, 01:39 PM   #5
2006 25' Safari
Bath , Pennsylvania
We just bought a 2006 Safari with this problem. The previous owners screwed 3/4 inch plywood over the bottom of the bed, It was worse than original. We took it off!
Any solution for the edge sag?
Merle & Jim is offline   Reply With Quote
Old 05-20-2009, 04:49 PM   #6
2004 25' Safari
1971 27' Overlander
Jourdanton , Texas
1/4 Plywood Solution
I cut strips of 1/4" ply equal to the the width that needed support. This was different on right and left beds. One strip was 4" and one 5". They were only 4 ft long. These were attached to 10" wide strips that lapped on to the surface by the head of each bed and extended the length of the strips. This gave a 1/2 edge that cleared the doors and drawers below. The remaining 1/4" portion was screwed to the bed platform. The interior 1/4" edge rests against the platform edge. Lengths matched scrap on hand rather than bed length, but they cover the area one is likely to sit on.
pienjim is online now   Reply With Quote
Old 05-20-2009, 08:18 PM   #7
Roadtoaster's Avatar
2015 30' Flying Cloud
Byhalia , Mississippi
I replaced all of the ply in our first AS, a 25' Safari. Not very cost effective but it sure improved the comfort.
Greg
Roadtoaster is offline   Reply With Quote
Bed Glide Repair Tamara General Interior Topics 16 08-31-2006 08:28 PM
Electric Brake Question. 68 Suburban Brakes & Brake Controllers 7 10-11-2002 09:14 AM
Number Decals Question wagsrp Airstream Motorhome Forums 7 10-11-2002 08:18 AM
Really a full-size bed mareinmn General Interior Topics 1 09-26-2002 06:47 AM
Idler arm support assembly PeterH-Airstreamer Mechanics Corner - Engines, Transmission & More... 0 09-11-2002 08:53 PM
