Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Interior Restoration Forum > General Interior Topics
Old 03-09-2004, 08:15 AM   #1
TomW's Avatar
Profile:  1967 26' Overlander
Huntsville , Alabama
Twin bed standard sheet?
I plan to build twin beds to replace the center double bed in my Overlander, and am trying to decide on mattress dimensions (and hence, how big to make the bed frames). There are no curves involved.
Researching past posts, one person said a standard twin sheet is 39”X75”, while another said the standard is 38”X75”. One man said his MH dinette bed measures 36”X69”. I was unable to locate any posts regarding how well a standard twin sheet fits an Airstream twin bed . Anyone know how well will a standard twin sheet fits an Airstream twin bed?
I suppose I will probably build to the space available. There were many posts on where to get custom mattresses, and good words for an Ebayer named reigle3 who sells bedding products.
Can anyone share insight into the build-to dimensions for an Airstream twin bed?
Tom
Old 03-09-2004, 08:28 AM   #2
Still Working
smily's Avatar
Profile:  North Charleston , South Carolina
Not even close
I owned Overlander with Twins in the middle and I can tell you that the sheets are not even close.
I believe "twins" is merely a reference to two single beds. 'twins" is not a reference to size, (at least in AS's).
This is a picture of the street side bed, It is not real obvious but you may be able to tell that most of the comforter has been tucked under the mattress to achieve a tight fit.
The mattress is barely wider than the pillow
Smily
Name:	airstream interior 010.jpg
Ken Smillie
My 1994 36' Classic MH is for sale
See it in the classifieds
smily is offline   Reply With Quote
Old 03-09-2004, 08:29 AM   #3
Still Working
smily's Avatar
road side
Mirror to the street side
Name:	airstream interior 009.jpg
Ken Smillie
Old 03-09-2004, 08:40 AM   #4
bswaslien@aol.com's Avatar
Profile:
Images: 12
Twin Sheets
I was told to use sheets made from TeeShirt material,as they tend to stretch to fit. Works perfect. PJ
bswaslien@aol.com is offline   Reply With Quote
Old 03-09-2004, 09:02 AM   #5
overlander64's Avatar
Profile:  1964 26' Overlander
1978 Argosy Minuet 6.0 Metre
Anna , Illinois
Images: 156
Greetings Tom!
While my Overlander is a '64 rather than a '68, I suspect that the twins were likely very close in size. When I had custom mattresses manufactured for my Overlander, they were 2.75" narrower than the standard twin and 1.75" shorther than the standard twin - - I ended up having the mattresses made 3" narrower and 2" shorter than (the standard twin) so that I would have room to utilize comforters and bedspreads.
Kevin
Kevin D. Allen
AIR #827
Old 03-09-2004, 03:00 PM   #6
RoadKingMoe's Avatar
Profile:  2001 34' Limited
Beavercreek , Ohio
Here's a chart of standard bedding dimensions. A residential twin is 39" X 75".
The curved head twins in a 8.5' widebody are supposed to be 34" wide by 78" long, so I'd guess they'd be about 31" wide by 78" long in an 8' wide trailer. If that's the case, a regular twin sheet would be too wide and too short on the rear curved beds.
Can't help with the center beds, but I suspect they're also longer than standard because a bulkhead at the ends prevents feet from hanging over the end, like they can on a 54" X 75" double bed or a 60" by 75" RV queen.
Maurice
AB8XA
AIR # 804, WBCCI 5446
The Long, LONG Trailer
Paralleled Honda EU2000i
