Old 08-10-2004, 07:17 PM   #1
nevisstudio's Avatar
Images: 8
trying to remove water heater..need help
hello...
im trying to remove a water heater in a 63' safarri....something is holding the bottom down...the tank rotates but wont lift off...
what do i do....
thanks
rich
nevisstudio is offline   Reply With Quote
Old 08-10-2004, 09:24 PM   #2
InsideOut's Avatar
1956 22' Safari
2015 27' Flying Cloud
Conifer/Evergreen , Colorado
Images: 108
If it's like our '64 (which it should be) there is a 'pin' mounted to the floor and a 'catch' on the bottom of the water heater. You need to pull out the water heater straight, parallel to the floor without trying to lift it out.
I have some pics on our webpage that may help, check the 'Water Heater' page and you can see the pin in the floor (especially, pic #4). The bottom of the water heater isn't shown but it's has a 'C' shaped slot that fits around the pin.
Shari
RMVAC | ACI - CO Unit (Formerly WBCCI) | BIRDY - our 1956 Safari | 1964 Serro Scotty
Old 08-10-2004, 09:35 PM   #3
5 rivets, 1 loose screw
Rog0525's Avatar
1966 20' Globetrotter
Saginaw County , Michigan
Images: 11
Shari gives good advice as usual. If you are trying to lift it from it's perch, that's wrong. It should slide out through the door panel opening.
It took me a while to learn that on a previous trailer.
Rog
May you camp where wind won’t hit you, where snakes won’t bite and bears won’t git you.
Rog0525 is offline   Reply With Quote
Old 08-11-2004, 07:06 AM   #4
Images: 8
thanks shari...
u explained it great...ill try it today..
good documentation...were doing the same....this is a great learning experience
thanks
rich
Water Heater Craig 1978- 1979 Excella 500 7 10-01-2007 05:16 PM
Water heater and furnace need work? goodgrey Water Heaters, Filters & Pumps 18 04-15-2006 10:29 AM
Water Heater By-Pass? TroutStream Water Heaters, Filters & Pumps 4 09-01-2004 07:15 PM
Winterization Blues - Water Heater Question BrianRegan Water Heaters, Filters & Pumps 0 06-13-2004 11:36 AM
Could Water Heater Tank Be Filled with Junk? heyskipper Water Heaters, Filters & Pumps 4 03-17-2003 07:26 AM
