Old 07-31-2005, 06:25 PM   #1
1978 25' Tradewind
Roseland , Florida
Trim in bathroom
Hi,
I am in the midst of doing some restoring/customizing of a 78 25 footer. In the bathroom there are many feet of brass channel with a plastic insert trim to protect the screws. I looked online to try and buy plastic trim to replace this an was unable to find anything. Any suggestions out there?
Eric, Tina and Kierstin Hedin
'78 Tradewind - Homeschooling RV Tech
kooblekidz is offline   Reply With Quote
Old 07-31-2005, 06:51 PM   #2
Craftsman
Guest
Posts: n/a
If you cant find the plastic insert, you may be able to use wood edge banding that you can find at most hardwood lumber suppliers. It comes in rolls in many different hardwoods that would compliment your interior.
Old 07-31-2005, 06:57 PM   #3
davidz71's Avatar
1986 25' Sovereign
Southern Middle , Tennessee
It's called nosing and you can get it through Inland RV www.inlandrv.com
Craig
AIR #0078
3.73 rear end
Mag-Hytec rear diff cover
Amsoil synthetics all around
Old 07-31-2005, 07:23 PM   #4
CanoeStream's Avatar
St. Cloud , Minnesota
Insert Nosing
I've got a bunch of the very product. I'll admit a mistake and take a bath on it. Total width is 1 1/16"; width of the middle band that stands away from the screw or rivet heads is slightly over 15/16".
Inland RV made full profit on my purchase. It is $1.80 a foot at InlandRV. I'd be happy to let it go at $.75 a foot. It's not doing me any good and will look better in your "happy home." I've got plenty of length -- what do you need? PM me if you're interested.
5 meter Langford Nahanni
Old 07-31-2005, 07:24 PM   #5
Chaplain Kent's Avatar
1994 30' Excella
Milwaukee , Wisconsin
Remove the plastic do not replace it. Next replace the rusted screw with brass screws. Polish this "new" metal trim and give it a coat of wax it will serve you many years and look great.
Chaplain Kent
2015 Coachman Freedom Express 19RBS, Chummy IV- Ford Excursion- 7.3 Turbo-diesel
Chaplain Kent is offline   Reply With Quote
Old 08-01-2005, 01:22 AM   #6
trim
I bought some at Oasis rv it is only .36 per foot.
grouchosbp is offline   Reply With Quote
Old 08-01-2005, 06:13 PM   #7
My price just dropped...
I learned my lesson -- I was actually hunting for J-trim for the metal edges and got waylaid by an underling at inlandrv. And where do you think I got my J-trim? OasisRV of course!
I've got plenty of this plastic stuff for a song if you want it...
Old 08-01-2005, 06:27 PM   #8
davidz71's Avatar
1986 25' Sovereign
Eric,
I'd take canoe stream up on that offer. I would myself but already installed mine and won't need more.
Craig
AIR #0078
3.73 rear end
Old 08-01-2005, 09:47 PM   #9
PizzaChop's Avatar
1973 31' Sovereign
Danielsville , Georgia
Images: 202
Use strips of linoleum
We just used leftover linoleum in our bathroom. Looks better than the plastic stuff and ties the bathroom together.
'73 Sovereign center bath
'72 Overlander rear bath
Ron Kaes
Psalm 112
www.paparonnis.com
PizzaChop is offline   Reply With Quote
Aluminum Trim Source? melprice Cabinets, Counter Tops & Furnishings 6 09-08-2009 06:19 PM
Poor design on slide bathroom door lbrodsky 2001 Safari 15 04-17-2005 08:01 AM
blue trim molding larry smith Clearcoat, Exterior Paint & Trim 83 12-07-2003 11:04 AM
Bathroom Counter Trim 74Sovereign Upholstery, Blinds, Walls & Interior Finishes 1 07-10-2002 06:36 AM
Exterior trim ALANSD Airstream Motorhome Forums 1 04-14-2002 07:53 PM
