Old 11-01-2008, 10:02 AM   #1
Judy Barde's Avatar
1960 24' Tradewind
pittsburg , Kansas
Trem pro 635 (Vulkem)
I installed the trim for my wet bath with Trempro in May of this year. I have to replace my black water tank. Anyone know if anything will cut the trempro so I can remove my trim? thanks Judy B.
S. Silver
Judy Barde is offline   Reply With Quote
Old 11-02-2008, 11:45 AM   #2
Wabbiteer's Avatar
1972 29' Ambassador
St. Paul , Minnesota
I know Vulkem a little bit from tearing apart shell pieces - working with it on interior finished pieces maybe someone else has a better method, but here is my best guess...
Heat, A safety razor blade, and slow even lifting to get one point separated and the rest should zip apart. I think it might take more than a hair drier, if you go with a forced air heat gun on low be very wary as it will deform the backboard laminate in an instant. Shielding just where the air outlet 'overspray' will flow off the trim onto the backboard will make it work if you are sparing.. with a chunk of sheet metal or thin plywood as shielding, heat the trim piece and work a safety razor blade under it and start prying...
Old 11-02-2008, 06:19 PM   #3
pauly g's Avatar
1960 22' Safari
Oceanside , California
I don't know much about removing Vulkem, but that's one nice looking bathroom!
pauly g is offline   Reply With Quote
Old 11-02-2008, 08:42 PM   #4
Head Animal Wrangler
BamCamper's Avatar
2010 19' International
Los Osos , California
I agree...it's a nice looking bathroom.
May I ask what kind of toilet that is and where did you get it?
Thanks.
Rally on,
Bam
and no, those photos are not me.
BamCamper is offline   Reply With Quote
Old 11-03-2008, 08:34 AM   #5
Judy Barde's Avatar
1960 24' Tradewind
pittsburg , Kansas
Thanks everyone I removed it with a hair dryer and a plastic razor blade. It worked as I even saved the trim. I think it was because it had only been installed for 3 MO. The toilet is the the one that was in the trailer when I bought it.. I lightly sanded it and had an automotive shop spray it. It has held up very well so far.
judy B
S. Silver
Trempro 635 TravisA Leaks - Weatherstrips, Gaskets, Caulks & Sealants 11 10-05-2014 05:38 PM
Pro-flamingo? Why or why not? Stella Fun & Games 32 04-13-2008 10:18 PM
midwest polishing pro? Auretrvr Cleaning, Stripping & Polishing 5 10-14-2006 05:40 PM
Vulkem 635 or 636? Dano57 Leaks - Weatherstrips, Gaskets, Caulks & Sealants 2 08-17-2006 10:04 PM
Long trem parking till Our Community 3 05-26-2004 10:54 AM
