Old 03-19-2011, 05:17 PM   #1
tr0y's Avatar
Las Vegas , Nevada
Tile Shower ?
Hi All
I was wondering if anyone here had done a tile shower / bath area in a restore ? I really don't like the cheap look of fiberglass showers but I am afraid that the twisting and bumping a trailer takes might make tile fail.
Anyone have any thoughts or experience with tile ?
T
tr0y is offline   Reply With Quote
Old 03-19-2011, 05:50 PM   #2
B4WEDI's Avatar
2006 19' Safari SE
Nawthin' , Hemisphere
Ix - nay on the Ile - tay.....
Originally Posted by tr0y View Post
Hi All
.........but I am afraid that the twisting and bumping a trailer takes might make tile fail.
T
I'd be thinking the same thing, that and I don't think you need to drag all that extra weight around with you.
*** KEEP LOOKING UP ***
T & K
B4WEDI is offline   Reply With Quote
Old 03-19-2011, 06:09 PM   #3
DaveFL's Avatar
2000 31' Land Yacht
Central , Florida
As much flex as a trailer will have, once you leave the flat floor area, you will have problems with seams opening, at the corners and long runs up the wall.
I replaced the carpet under the toilet with tile, weight for a 2x2 foot area not a problem, flat to floor with edges under the trim molding.
Trailers are designed for lightness, and you would be adding about 50 square feet.
Old 03-19-2011, 06:35 PM   #4
Hi All
T
Remember, that the shell flexes, inside and out.
Rigid ceramic tiled surfaces in an Airstream won't last.
Old 03-19-2011, 06:37 PM   #5
KerriO's Avatar
2008 27' International CCD FB
Bay Area , California
This guy did it: Pro Portfolio: Architect Matthew Hofmann remodels Airstream into live-work space | L.A. at Home | Los Angeles Times
It's beautiful, but who knows how long it will look like that!
KerriO is offline   Reply With Quote
Old 03-19-2011, 07:03 PM   #6
Michigander's Avatar
2005 30' Land Yacht 30 SL
Oakland County , Michigan
I agree with all of the above. Why push it? Virtually everything in a mobile unit flexes.
Bob & Nancy
2005 ASLYG 30 SO
2009 Wrangler Toad
Michigan
Michigander is offline   Reply With Quote
Old 03-19-2011, 07:07 PM   #7
tr0y's Avatar
Las Vegas , Nevada
That is what I thought, it was actually that Matt Hoffman trailer I saw and his shower was what made me want to do mine in that way.
I should let you all know I am not doing an Airstream, I am actually building out a living quarters in an all aluminum horse trailer, and am going to do it in a way far more akin to a nice mid century mod with a cowboy twist, than a horse trailer.
This forum is far superior to any other I have lurked through and my father in law is a member here and suggested I would do far better here than the horse trailer oriented forums, and I agree so I hope you let me stay ...
That trailer is parked not far from my parents home and next time I am in Santa Barbara I may just have to go knock on his door.
Thanks !
Old 03-19-2011, 07:18 PM   #8
Globie64's Avatar
1964 19' Globetrotter
The Sea Ranch , California
Images: 18
I want to redo our shower, and I'm thinking of sheet stainless. You might look at aluminum tiles, yes, they exist, but also use a good brush on membrane- expensive but good at keeping the water from getting behind the tiles, wicking down the walls and destroying the plywood. Also, with a ceramic tile shower, if its on one side of the trailer, you're adding significant weight to the trailer eccentrically.
Wherever you go, there you are
Globie64 is offline   Reply With Quote
tile shower
Wet bath to shower? osolow Sinks, Showers & Toilets 6 03-24-2011 10:25 AM
1981 Excella II shower valve noreen&sal Sinks, Showers & Toilets 2 03-06-2011 08:06 AM
newer airstream shower question 386kustoms Sinks, Showers & Toilets 2 02-25-2011 11:13 AM
Original Shower Curtain for 1967? star kitty General Interior Topics 3 02-19-2011 08:49 PM
Shower Curtain JuJu Fogle General Interior Topics 1 01-31-2011 06:17 PM
