Old 04-30-2011, 08:19 PM   #1
Goal15's Avatar
Dallas , Texas
Three questions
Okay, now that we've got our AS home and cleaned up three questions. Searched threads but didn't find exact answers.
2006 22 ft Safari
1. Is the bathroom vent fan supposed to work by pushing the small red button in the vent itself? If so, nothing happens. All other electric except one light fixture in front above the fold away table area work great. That one seems like the switch doesn't engage anything.
2. What do people use for cleaning their wood surfaces?
3. What do people use for cleaning the vinyl laminate flooring? Anything special?
Thanks for your help.
D
Goal15 is offline   Reply With Quote
Old 04-30-2011, 08:30 PM   #2
blmitch5's Avatar
2006 19' International CCD
Olathe , Kansas
My fan in my 06 19' Bambi turns, it doesn't push. Maybe yours if different. But check it just the same. If not post a pic and Someone else might chime in.
To clean the laminate wood we keep Pledge multiple surface wipes in the AS because it's a small package and they work great. For the floor any vinyl floor cleaner will work. You found a nice AS! I love that layout.
Get involved and sign up for a Rally!
http://www.airforums.com/forums/calendar.php
WBCCI 4973
blmitch5 is offline   Reply With Quote
Old 04-30-2011, 08:31 PM   #3
TBRich's Avatar
2006 19' Safari SE
Tucson , Arizona
Images: 64
2006 22 ft Safari
D
(1) Yes, that's how you turn it on/off. (As Brad mentioned some have a turn switch.) It may be a wiring disconnect or a bad switch/fan motor. The first thing to determine is whether the lead wire to the switch is hot. It it is, then it's a switch or motor issue. Then test the exit wire from the switch turning the switch off and on to test both positions. If that gives you power, then the switch is OK and the motor is most likely compromised. If the lead wire to the switch is not hot then there is a problem somewhere in the wiring before the fan itself. If that's the only thing in that area of the trailer that is not working it is probably not a fuse, but just to be sure you should check all the fuses behind the converter door.
(2) We just use a light solution of household cleaner or an all-surface cleaner. If you are unsure, test a small inconspicuous area.
(3) Same as (2)...
Good luck!
TB & Greg and Abbey Schnauzer
#3954
Old 04-30-2011, 08:32 PM   #4
Goal15's Avatar
Dallas , Texas
We love it. It was so well taken care of and just the perfect size for the two of us leading up to retirement.
Old 04-30-2011, 08:39 PM   #5
blmitch5's Avatar
Olathe , Kansas
Oh you just had to say the R word! I'm 15 years away and get a bit jealous when I hear that! Just kidding...sort of. I cant wait to see your maiden voyage pictures!
Here is a fun link to get ideas to personalize your new baby!
http://www.airforums.com/forums/f415...all-47134.html
WBCCI 4973
Old 04-30-2011, 08:52 PM   #6
Goal15's Avatar
Dallas , Texas
6 years, 4 months but who's counting
DW is retired already from teaching, so we are going to weekend and vacation, then do some more extended trips when I retire.
Lots of Rib questions... NicheVintage Ribs, Skins & Rivets 12 07-10-2012 03:22 PM
Should I??? Noob questions... kjpintn Buyer Guidelines 10 04-13-2011 07:08 PM
New AS Owner - General Questions MoDrifter Bumpers & Bumper Storage 9 04-04-2011 04:14 PM
2010/2011 Sport 22 FB Questions smeghead Member Introductions 16 02-10-2011 10:09 AM
A couple Overlaner questions. DougZ 1972 Overlander 2 01-17-2011 05:04 AM
