Old 04-27-2009, 06:42 PM   #1
Mini Rivet
bmklawt's Avatar
1975 25' Tradewind
Holland , Michigan
Thermometer repair, replacement needed
The thermometer in the front overhead does not work anymore, I assume it is a vapor thermometer.
Does any one know if there is a replacement out there or if this can be repaired?
What have you done to replace the clock and thermometer in the front overhead, any ideas you could give me would be appreciated.
Bruce,
Parts needed: Fan for roof vent or whole vent fan assembly, vented catalytic heater.
My blog for the 1975 Tradewind restoration, Has not been updated in a while but I am still working on it.
bmklawt is offline   Reply With Quote
Old 04-27-2009, 08:15 PM   #2
Ganglin's Avatar
1971 27' Overlander
Central , Ohio
Images: 13
Bruce - the front clock in our 71 was dead from battery leakage. I replaced it with a movement from Michael's. I think JoAnns has them also. I have an original thermometer, barometer and humidity gauge that I found at a yard sale that is like the 71 but not sure it would work in yours. What brand is on the dial. Our thermometer wasn't working correctly either so I took it out and cleaned it - works fine now.... mostly it needed oil at the indicator arm shaft.
Old 04-29-2009, 10:18 AM   #3
Mini Rivet
bmklawt's Avatar
1975 25' Tradewind
Holland , Michigan
Ganglin thanks for the input.
Luckily my clock works fine, but the thermometer does not.
I have looked but can not find a thermometer movement with a remote probe, I would like to stay away from wireless.
I also thought about replacing the clock and thermometer with an indoor\outdoor thermometer, clock but have not found one yet that would look good in that spot.
ID:	79424   Click image for larger version
Bruce,
Old 04-29-2009, 10:22 AM   #4
maccamper's Avatar
1974 29' Ambassador
1966 20' Globetrotter
Bloomington , Illinois
great tip
Great tip on putting oil on the indicator arm of the thermometer, Gary, thanks very much for putting that out there. I will try that on my unit.
Laird
maccamper is online now   Reply With Quote
Old 10-22-2009, 10:29 PM   #5
1973 25' Tradewind
Abbotsford , British Columbia
The thermostat in my 1973 Tradewind seems to prefer approximately -30 as the usual temperature. Is there a way to either recalibrate the thermostat or to replace the bulb?
Brian
bridor15 is offline   Reply With Quote
Old 10-23-2009, 07:25 AM   #6
ventport's Avatar
1977 Argosy 24
Milltown , Wisconsin
This repair may work, it works on auto dash temp gauges.
Broken Temperature Gauge
The temperature gauge is a “mechanical” unit consisting of a bulb with fluid (ether) mounted in engine head, a gauge head mounted in the instrument cluster on the dash, and a tube connecting the bulb to the gauge head. The gauge head is actually a pressure sensing unit.
In operation, the coolant in the engine head heats the working fluid in the sensor bulb. As the engine gets hotter the pressure in the bulb and tubing rises. The dash head unit simply reads the pressure on a scale calibrated in degrees Fahrenheit.
A common failure mode is for corrosion to lock the bulb in the engine head. The tubing is twisted off near the bulb when bulb removal is attempted. In this case, the gauge head unit is known to be working properly, the defect is in the tubing and in the loss of fluid from the sealed system.
For a more detailed description, a number of articles about the operation of this type of temperature gauge have appeared in Skinned Knuckles over the years. The earliest article I have is from the March 1984 issue.
Replacement parts
Mechanical temperature gauges are still being manufactured and available in most auto parts stores. The goal of this procedure is to graft a new bulb (with fluid) and tube onto the old gauge head.
Find a gauge that has a spiral wound protective cover over the tube. There are some that use a plastic coating. While these can be made to work, they will not look correct. As of October 2004, it is possible to find a suitable donor gauge in California auto supply stores for about $15.
The Procedure
Caution: The working fluid in the gauge is ether, a highly flammable substance. Do not have any open flame near your work area. Do not use a torch for the soldering operations.
Make up a sleeve from some tubing. In this case the capillary on the donor gauge had a slip fit into 1/16" inside diameter copper tubing found at the local hardware store. The capillary on the original gauge was slightly larger, so the 3/4" long sleeve was drilled out halfway through to make a slip fit for the old capillary.
To keep the ether from escaping we use some crushed ice and salt to create a “cold bath” for the sensing bulb.
And we might as well be chilling the bulb while we do all the other preparation work.
Trim the capillary tubing on the old gauge a couple of inches from the gauge head.
Make sure that the tubing has not been closed off when trimming to length.
We might as well do as much as we can before cutting open the donor gauge. So the next step is to “tin” the capillary on the old gauge near the cut. You don’t want to tin all the way to the cut as you don’t want to encourage solder to fill the capillary opening.
Now we can attach the sleeve to the tinned capillary. In this case we seated the capillary tubing to the limit that we opened up the diameter by drilling.
Again we want to make sure we have not closed off the capillary. A piece of stiff wire small diameter can be used to verify that the capillary is not clogged with solder.
Cut the protective spring on the donor gauge capillary near the point marked for the length you need (indicated by the tape).
In the spirit of doing as much work as possible before breaking the seal on the donor unit, we now tin the part of the capillary that will be inserted in the sleeve.
Almost done! Verify that the sensor bulb is still in the ice solution. Cut the capillary tubing, assure that the center is open and now solder it into the sleeve.
Before removing the sensor bulb from the ice solution, double, triple and quadruple check that you have a good solder joint with no voids or other possible leaks on both sides of the sleeve. When you are happy with your work it is time to check the function.
Immerse the sensor bulb in boiling water while observing the needle of the gauge. It should move up to the 212° F mark. While observing the dial mechanism, you might want to cycle the sensor bulb between the ice solution and boiling water a few times to verify that nothing is binding the movement. The gauge should now be restored to operation.
Calibration
If the gauge does not read 212° F in boiling water you have two options:
Note the error and live with it.
Attempt to adjust the gauge head unit.
The gauge head is a Bourdon tube connected to the indicator by a linkage. The Bourdon tube is simply a flattened tube rolled into a coil. As pressure is applied the tube slightly unwinds. When the pressure is removed, the coiled tube returns to its original position.
Adjustment is made by bringing the sensing bulb to a known temperature by placing it in boiling water (212°F) then bending the linkage that connects the Bourdon tube to the indicator. Do not bend the Bourdon tube itself. [Chrysler 1953 page 70] States that it is possible to adjust the gauge if its reading is less than 30° different than the actual temperature.
If you have any doubts about the adjustment operation, then don't do it. You can buy replacement sensing bulbs and tubes at any auto supply store. Getting an original gauge dash head is a lot harder.
Installation
Avoid sharp bends or kinking the tubing when installing the repaired gauge.
Update
My original repair instructions were based on my 1977 repair of the gauge in my car and called for replacing the tubing at the gauge head. This current set of instructions is updated based on concepts presented in the April 2000 issue of Skinned Knuckles magazine. In an article by Bill Cannon a significant improvement is given. The improvement is in splicing the old tubing to the new tubing with the use of a sleeve. This allows you to work away from the gauge head and thus be less likely to damage it.
In the Restoration Forum of the June 2000 issue of Skinned Knuckles A. R. “Dick” Evans (“The Temperature Gauge Guy”) of Dunedin, Florida pointed out the safety issue of working with an open flame near the ether working fluid.
In general I don't make commercial endorsements on this web site. But I have to say if you repair or restore old cars a subscription to Skinned Knuckles is required.
ventport is online now   Reply With Quote
Clock / Thermometer balrgn Electrical - Systems, Generators, Batteries & Solar 20 08-05-2012 09:46 AM
Frame dent - repair needed? Cos Repairing/Replacing Floor &/or Frame 4 05-14-2007 02:02 PM
Non Airstream aluminum repair help needed Goin camping Off Topic Forum 7 04-09-2007 07:41 PM
Who Turned down the Thermometer wingfoot321 Off Topic Forum 0 03-21-2006 10:29 PM
Where is the outside thermometer? InspectorDread Interior Restoration Forum 8 03-07-2005 10:08 AM
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
