Old 06-13-2011, 10:36 PM   #1
Aluminum Falcon Mechanic
Darkspeed's Avatar
1972 31' Sovereign
Wesley chapel , Florida
Thermal break
I am planning on adding a thermal break between the ribs and the interior skin when I replace the interior skins.
What I am planning on using is a self adhesive silica fabric strip that is 1" wide and .03" thick - about 1$ per foot
McMaster-Carr
It has a very low thermal conductivity. I used this material when I built my last powdercoat oven and it does an amazing job of stopping heat transfer.
Has anyone done this?
Darkspeed is offline   Reply With Quote
Old 06-13-2011, 11:50 PM   #2
NevadaGeo's Avatar
1978 31' Excella 500
Genoa , Nevada
You might have found something there, whatever this means in their specs: "Temperature range is -40° to +482° F. Heat flow rate (K-factor) is 0.76 Btu/hr. x in./sq. ft. @ 75° F. Density is 61 lbs./cu. ft. Color is off-white. For indoor use. Cut with a utility knife or shears and install with pins and washers. Meets UL-94 5VA flammability requirements..."
Can anybody translate this to an R-value we could understand?
I admit to being powerless over housecleaning and social niceities
Airforums 22655 and now, WBCCI 22655
NevadaGeo
NevadaGeo is offline   Reply With Quote
Old 06-13-2011, 11:54 PM   #3
Maniacal Engineer
barts's Avatar
Menlo Park , California
With any luck your Airstream skin will never reach temperatures necessitating such high tech material... why not use fiberglass tape?
- Bart
Bart Smaalders
Menlo Park, CA
http://tinpickle.blogspot.com
http://smaalders.net/barts
barts is offline   Reply With Quote
Old 06-14-2011, 12:02 AM   #4
NevadaGeo's Avatar
Genoa , Nevada
Bart, did you ever put a temp gun on the outside skin on a hot day on playa? Especially the blue. I did, OUCH! 120+ on the inside, forget the outside number. He might have a good idea there...
But I think he's talking about using it as insulation.
NevadaGeo
Old 06-14-2011, 12:11 AM   #5
Maniacal Engineer
barts's Avatar
R-Value
So, .76 BTU*inches/sq. ft.*hour*F /.030 = 25.3 or an R value of .04.
From
R-Value Table
we can see that 1/4" plywood has nearly 10x this R value....
I'd guess ripping some 1/8" Luan ply into strips might work better...
It's clear what matters here is thickness.
- Bart
Bart Smaalders
Menlo Park, CA
Old 06-14-2011, 12:41 AM   #6
1985 31' Excella
Fresno , Texas
There is a foam back glazing tape that is
adhesive
used in storefront glazing in fact I believe Airstream has it under the window flanges. Its not going to do as much good as you think with all the rivets breaking your thermal break 98418X12BL - CRL Black 1/8" x 1/2" Double Sided Foam Glazing Tape ENERGY STARŪ– CRL is an ENERGY STARŪ partner, and our fenestration foam glazing tapes carry the ENERGY STARŪ seal. ENERGY STARŪ is a government backed program helping businesses and individuals protect the environment through superior energy efficiency.
Wsmith is offline   Reply With Quote
Old 06-14-2011, 06:54 AM   #7
Darkspeed's Avatar
1972 31' Sovereign
Silica tape K factor is 000.78
Aluminum K factor is 250.00
For a limited thickness I have the feeling the Silica will provide a noticeable result.
I will still have heat leaks where the aluminum rivets link the ribs to the interior skin.
I have a lab pyrometer, it may be worth a little experiment.
Old 06-14-2011, 07:01 AM   #8
Darkspeed's Avatar
1972 31' Sovereign
- Bart
Fiberglass can be used as well. I have found from using both on an oven, the silica transmits less heat in the 0-275f range. It is a little more in cost but I feel it may be worth it.
Old 06-14-2011, 05:56 PM   #9
Wabbiteer's Avatar
1972 29' Ambassador
St. Paul , Minnesota
jeepers.
My '73 27' has at least nine ribs at 18 feet each, and ten Sixteen-foot shell cross-rib rails riveted in, plus around 80 foot of horizontal rib on each end, then eight or more feet per window frame and door.
That is $450~ before knowing if that adhesive will forever cement tape to ancient aluminum - plus all the heave and shrink from thermal expansion and the pinch of riveting / road vibration may well grind the refractory type insulation to dust.
Fireproof or excellent fire resistance and nearly inert to 300°F - automotive gasket paper? This is not a place that really needs R-Value, just to arrest the torrent of heat aluminum can transmit.
How about Tyvek housewrap paper, it melts at 275°F and ignites at 750°F, the printed side has been treated to accept inks so glues may adhere better long term.
There are many sorts of synthetic roofing underlayment paper that is good to 300°F - glued to the shell ribs with an automotive caulk like a fast-setting Sikaflex or Vulkem equivalent...
Old 06-14-2011, 07:38 PM   #10
DanielB's Avatar
1974 31' Excella 500
Charleston , South Carolina
Tyvek sounds good.
How about spray stuff. Is there any spray stuff to spray a coat in the inside of the aluminum to arrest the heat transfer there? Thanks in advance.
As I grow older, I pay less attention to what men say. I just watch what they do.
- Andrew Carnegie
DanielB is offline   Reply With Quote
Old 06-14-2011, 09:10 PM   #11
Darkspeed's Avatar
1972 31' Sovereign
My plan is 1.5" closed cell fire rated spray foam in the cavity plus a thermal break strip on the ribs.
Old 06-14-2011, 09:12 PM   #12
Darkspeed's Avatar
1972 31' Sovereign
That would be in addition to a white roof, polished sides, and a high quality solar film on the windows.
Old 06-14-2011, 11:26 PM   #13
Nowhere , Tennessee
I can't wait to hear how this turns out. All I hear is that spray foam want work, but I saw a picture of a 69 avion c10 with foam that looked great. Its been 40 years and I'm sure the foam is a little better now. Keep us posted
fishingpig is offline   Reply With Quote
Old 06-14-2011, 11:55 PM   #14
Darkspeed's Avatar
1972 31' Sovereign
I will be the guinea pig.
There is two ways to do foam.
1. Scuff the surface and spray foam
2. Spray a latex paint and then spray foam
The second choice will keep the foam from binding to the aluminum so if you ever had to replace an exterior skin it would be less work . The first choice makes for a more solid leakproof structure. I am going for no 1.
The E-84 foam will give R11 @ 1.5"
4CU 004 : Spring break at the lake silverback WBCCI Rallies & Events 68 04-19-2011 08:55 PM
Break away brake cable Cap-N-Red On The Road... 26 04-10-2011 03:10 PM
Spring Break Camping Bettye On The Road... 3 03-28-2011 03:58 PM
Tag axle brake parts Myrtle lynn Classic Motorhomes 9 02-10-2011 08:05 PM
Spring Break, TRIP,.. Need help Again. THEPILL On The Road... 18 02-06-2011 11:14 AM
