Old 11-30-2004, 07:01 PM   #1
1983 34' Limited
Las Vegas , Nevada
Send a message via MSN to dmadam
Angry The work never ends!
Seems like every time I turn around there is something else I want to do. Today I decided I want to remove the front end cap as it is cracked pretty bad. Started out to do some simple remodeling and look where I ended up! I am having trouble finding mouldings for the front curved windows.
With all the screws and rivets I have pulled seem like I should get a couple more rivets to my name here! I have asked a lot of questions here and you folks have really helped me.
Attached are a couple of pix. See my TV through the front window! LOL The frame you see is the beginnings of the kitchen counter. It is just set in there to check the fit before I finish it.
Thanks again
David
ID:	9622   Click image for larger version
Name:	front area L.jpg
Retirement happens when you get over the illusion of usefullness.
dmadam is offline   Reply With Quote
Old 11-30-2004, 07:12 PM   #2
1983 34' Limited
Las Vegas , Nevada
Oops wrong pix
Didn't mean to send the pix of nothing in the dinette area!
Name:	kitchen dinette area L.jpg
Old 11-30-2004, 07:18 PM   #3
1973 31' Sovereign
Portland , Oregon
Images: 22
Could Bondo fix end cap cracks?
I know what you mean about the work never ending. My AS needs more work than yours appears to need though. I am still working on putting the sub-floor back in. Then I have to re-install insulation and the inner wall panels, etc., etc.
It did occur to me to wonder if you could use Bondo auto body filler to repair cracks in your end cap. Maybe even without having to remove it? It is an expoxy/fiberglass type of product and could very well stick well enough to the sides of the crack to work. You should be able to sand it out after the repair.
Has anyone reading this post had any experience using Bondo for this sort of thing?
Malcolm
malconium is offline   Reply With Quote
Old 11-30-2004, 07:35 PM   #4
eljay's Avatar
1968 24' Tradewind
Rural, blink and you'll miss it , Missouri
Could you post a pic of the endcap damage? I am thinking that the fiberglass/epoxy stuff I just used on my fridge scoop might just work.
eljay is offline   Reply With Quote
Old 11-30-2004, 07:49 PM   #5
1983 34' Limited
Las Vegas , Nevada
Eljay, Will send one in the morning. Thanks for the interest. I am going to cover it with vinyl anyway but am worried about it rest of the cap holding up for the long hall
Old 12-01-2004, 09:14 AM   #6
1983 34' Limited
Las Vegas , Nevada
Pix of the end cap cracks
Since I am going to cover the piece you might be right to bondou the piece but I am still woried about the long term durability since it cracks so easy. I could frame the opening with aluminum and a support piece underneath.
Any sugestions would be appreciated.
David
ID:	9627   Click image for larger version
Old 12-01-2004, 10:30 AM   #7
1983 34' Limited
Las Vegas , Nevada
Any one want this
If anyone wants this for free. I have the roll up doors and all hardware.
David
Name:	End cap frame.jpg
Old 12-01-2004, 11:08 AM   #8
eljay's Avatar
1968 24' Tradewind
I think that this could be repaired or strengthened with the application of fiberglass cloth (versus the batting) and epoxy (commonly known as fiberglass repair kit). You may be able to do this without removing it but I find it easier to work with when I can lay it on the bench or floor. Let me know if you need more details. LJ
Old 12-01-2004, 02:03 PM   #9
53flyingcloud's Avatar
1984 29' Sovereign
Savannah , Missouri
dmadam,
As I sit back, reading of your attempts to repair the end caps, the images of the end caps in my 40 yr old A/S (2nd Airstream) comes to mind. It is still as solid as the day it was installed with no cracks. It was made with Fiberglass material and, very thick as well, perhaps 1/8 to 1/4 inch thick. Certainly they has withstood the test of time~!
My 84 Sovereign has the very same material for end caps such as yours and...I know it's just a matter of time before both ends will start to develop cracks. Thus, the need to be replaced. I'll be following your progress`
Good Luck~!
53FC
WBCCI 5292 AIR 807
NEU #64
New England Unit
53flyingcloud is offline   Reply With Quote
Moving along still many hours of work to go! GT1963 General Interior Topics 35 09-16-2005 08:54 PM
Entry Door Lock Set Hunt ends at Inland Grady White 1959 - 1965 Ambassador 3 12-16-2004 09:08 PM
Dull walls and yellow plastic ends 74SovereignInt. Upholstery, Blinds, Walls & Interior Finishes 35 10-15-2004 12:57 AM
marker lights dont work wb13798 Mechanics Corner - Engines, Transmission & More... 6 11-09-2002 11:40 AM
Water heater work tool FrankR Water Heaters, Filters & Pumps 1 04-09-2002 10:57 AM
