Old 01-08-2008, 09:22 PM   #1
samb's Avatar
1961 22' Safari
Union , Oregon
Images: 11
The Joggle Stick
There is a great article in WoodenBoat magazine number 200 about fitting bulkheads. It is about cutting panels to fit curved and irregular surfaces. If that doesn't describe and Airstream, I don't know what does. After all, an Airstream is just a landlocked boat. By using this method, developed by 19th century British shipwrights, you would cut once and it would fit.
A couple of other articles in this issue cover the mixing and uses of shellac and the Sardine Stove, a woodstove small enough for even a Bambi.
For 62overlander, there are photos of beautiful mahogany joinery in the interior of a sloop named ANNA. Frank, I expect the interior of your ANNA to look just as good. (Among the other things that you are challenged to get done)
And no, I don't own stock in the magazine. I am not reproducing any part of the article because I respect copyrighted material. I think most people that are a bit handy could thumb through the magazine at their local store and understand the principle of the joggle stick in just a few seconds.
I hope this helps someone who has been looking at their gutted AS and gives them the courage to get started. "The days are getting longer---summer's almost here"-----I say to myself as I look out in the back yard at 3 foot snow drifts.
Sam
samb is offline   Reply With Quote
Old 01-08-2008, 09:37 PM   #2
CanoeStream's Avatar
St. Cloud , Minnesota
Joggle stick = story stick = story boards. I first got my technique out of WoodenBoat magazine somewhere between issues 60-90. It takes a little trimming with a hand plane but you can rough out a template very quickly! Sam, thanks for bringing this up. It's used from cabinetwork to boat building and deserves every exposure here.
A sticky thread in the Floor & Frame subforum: http://www.airforums.com/forums/f36/...pes-29321.html
5 meter Langford Nahanni
Dip Stick Bill Resseau Mechanics Corner - Engines, Transmission & More... 26 11-09-2010 04:08 PM
Windows that stick wacnstac Windows & Screens 8 06-19-2006 03:29 PM
weatherstripping didn't stick Chuck Leaks - Weatherstrips, Gaskets, Caulks & Sealants 14 04-03-2005 11:49 AM
What does stick to aluminum? malconium Interior Restoration Forum 21 08-26-2004 05:20 AM
Stick-on-States Stefrobrts On The Road... 21 12-18-2003 02:02 PM
