Old 07-04-2010, 10:11 AM   #1
Minno's Avatar
1972 31' Sovereign
Lexington , Minnesota
The great insulation debate revisited!
Chris was too chicken (BKAAAAK - you knew the job was dangerous when you took it, Fred!) to post this question, but I like to live dangerously. For those of you that have reinsulated your trailers: we're looking at the differences between Prodex and fiberglass insulation, and whether it's worth the extra expense to do Prodex. Keep in mind that we live in Minnesota, are planning on winter traveling when we retire in the south. We've investigated the costs of Prodex and fiberglass, and the time involved in putting in Prodex, the R value of each, and we're still debating. I'm of the opinion that we should go with fiberglass, and Chris is still going back and forth. We had some major mouse infestations in Little Girl when we picked her up, but she had been neglected for many years, and we're not planning on letting that happen again. We've read and read and read the threads on insulation. Help!
Kay
Old 07-04-2010, 10:19 AM   #2
nmbosa's Avatar
Nowhere , Washington
I went though this debate a couple months ago and through a combination of laziness, running out of time, budget, and uncertainty over the benefits of Prodex, I ended up using fiberglass. However, I don't plan on doing much winter camping and even summer camping up here in the Northwest is fairly mild in terms of heat. So I was not really trying to get a house like R-value out of my insulation.
Done correctly, it seems like the Prodex can give excellent R-value, but doing it correctly involves a significant time investment (in addition to the cost) and very particular attention to detail.
Norm and Mary
blog: Captain Wilson's Overlander
nmbosa is offline   Reply With Quote
Old 07-04-2010, 10:30 AM   #3
Minno's Avatar
1972 31' Sovereign
The only other to add I that when we gutted her, there was only one place where the wall/ceiling insulation was wet or had been wet (i.e., black & gunky). One shell leak around one window after 37 years. So, we're not too concerned about future water leaks ruining the fiberglass insulation either.
Norm & Mary - Kay feels vindicated.
Chris
Old 07-04-2010, 01:06 PM   #4
purman's Avatar
1968 28' Ambassador
Cedaredge , Colorado
Has anyone ever thought of using a spay in foam. it sure would do a nice job of sealing everything. We used it on the last house I built. It was a high dense foam the expanded only a little so there wasn't much trimming to be done. and on a 2x6 wall we got about an R26 out of it.
Jason
2008 5.7 L V8 Sequoia
AIR # 31243
WBCCI # 6987
FOUR CORNERS UNIT
Old 07-04-2010, 05:22 PM   #5
Minno's Avatar
1972 31' Sovereign
My understanding from experienced people is that it would fall apart from the vibrations and flexing when you tow. Experts say it powders out after a short time.
Kay
Old 07-10-2010, 04:54 PM   #6
1968 20' Globetrotter
Kelowna , British Columbia
I just finished removing the interior skin from my 68 GT and having seen the mouse infestation, water damage and settling of the old fiberglass, I would sooner not use insulation than repeat the fiberglass. I have used professionally applied spray foam in a number of home renovations, but I can't imagine the time it would take to detail the foam so that the inner skin could be reapplied. (those pesky curved surfaces) Soooo, I think I'll use Prodex (or an equivalent material from a Canadian supplier to avoid cross border shipping).
Ian
Canlib is offline   Reply With Quote
Old 07-10-2010, 05:34 PM   #7
GR8DANE's Avatar
1966 22' Safari
1964 24' Tradewind
1956 18' "Footer"
Southern , Minnesota
I have heard 2 things about the reflective bubble insulation that I like a lot. Uwe says "mice don't like it." Many say that it keeps the trailer substantially cooler in hot weather. Use both the reflective and the fiberglass and get the desired results.
life is too short to drink cheap beer...unless that's all we've got and then pass me a cold one!
Steve "Dancin" Hansen
TAC MN-31
visit my almost yearly blog http://www.bluessafari.blogspot.com
GR8DANE is offline   Reply With Quote
Old 07-10-2010, 05:55 PM   #8
Got gandkids?
Jim & Susan's Avatar
'Possum Holler , Georgia
I used reflective bubble with about a 1" layer of pink stuff over that. I can say unequivocally that I would NOT do that again. Have a look at my Full Monte thread if your interested. The foil stuff is a pain to work with, costs too much and I may have installed wrong (sealed it up too tight).
Zepelinium has a thread here someplace showing results of testing he did on various types of insulation. The pink stuff held up very well vs. the others.
Just my 2 kopecks. YMMV.
www.nesa.org
Air No. 6427
Old 07-10-2010, 06:01 PM   #9
MDSilverado's Avatar
1977 31' Sovereign
Severna Park , Maryland
I have been contemplating the same topic for some time and finally settled with 2" polystyrene board on the underbelly and fiberglass in the walls. I saw very little if any signs of mice infestation and expect that if it does happen it will more than likely be in the underbelly than walls. So I will not use fiberglass in the underbelly. I sealed the edges of the polystyrene with spray foam or caulk depending how tight the gap was at the edges. The 2" polystyrene was $39.00 and I think I will end up using four sheets total. I tried working some with the Prodex and found that it was very difficult to seal the edges. And as with all insulation if there is any violation of the barrier (gaps at the edges) then the heat/cold will transfer around the insulation rather than through (much faster). The great thing about fiberglass is that you can cut it a little big and stuff it in and it will expand to fill the voids. Just dont cut it so big that you are compressing it substantially, that will reduce its R-value. Prodex due to its rigidity does not flex and expand like fiberglass and thus does not seal as well at the edges.
The other item I will be experimenting with is installing a thin piece of foam tape to the rip before installing the inner skin. This will hopefully prevent(slow) heat transfer from the ribs to the interior skin. I would think that due to the aluminum construction the skins and ribs are conducting a great deal of heat directly through the metal. Just my two cents...
MDSilverado is offline   Reply With Quote
Old 07-10-2010, 06:08 PM   #10
Minno's Avatar
1972 31' Sovereign
Thank you for the responses. Part of our great hesitation in going with Prodex is the tremendous amount of time we think it would take to install it, especially in a 31 footer. We had pondered using Reflectix with fiberglass, but based on Jim's response, that doesn't sound like fun either! We think at this point that we will go with fiberglass and be vigilant about mice!
(Did anyone get the reference to "you knew the job was dangerous when you took it, Fred" ? Just curious if anyone else knew it.....)
Kay
Old 08-16-2010, 09:46 PM   #11
bgordon's Avatar
Austin, TX & , Colorado
Images: 32
I've been reading over insulation tips/techniques quite a bit as I just picked up a gutted '48 14' Boles Aero. I'm leaning toward a foil/bubble insulation on the premise of air quality.
There is a similar product I just became aware of called TekFoil.
TekFoil, Reflective Insulation, TekFoil Reflective Insulation, Insulation Products, Energy Efficient Insulation - TekSupply
It is a reflective foil/bubble layer/reflective foil layering. There is also a double bubble version and a single ply reflective foil version if you want to layer over the pink stuff. The pricing seems comparable to ProDex.
Is there an aversion to the bubble layer? From what I've read ProDex has closed cell foam as the middle layer. It seems like there isn't an issue of the bubble layer bursting as one application is to use it under concrete floors. Any thoughts on TekFoil?
-Blake
bgordon is offline   Reply With Quote
Old 08-17-2010, 07:05 AM   #12
Dave Park's Avatar
2005 22' Safari
Hyde Park Place , Ohio
Three things...
I'm a bit confused with your reasoning on a statement you made.
You said, paraphrasing, "we're not concerned about water damage, because after 37-odd years, there was just one patch of water-damaged insulation."
A trailer going from 0-37 years will have a certain number of leaks. A trailer going from 38-74 years can be expected to have a lot more leaks.
Secondly, when refurbishing my last trailer, I invested several hundred dollars and about 50 hours of labor to reduce the weight by 100 lbs. In retrospect, I could have achieved the same weight loss for less investment and far less time by using the radiant barrier insulation.
Thirdly, nobody's mentioned in fiberglass' favor, it is a better sound insulator. I can't say how much difference this makes after two aluminum skins... but a good night's sleep is important to me.
My "forever airstream" will have radiant barrier insulation, because of the almost doubled R-value, the weight reduction, the pest-resistance, the water-resistance and because updating wiring later on will be a much less unpleasant task as needs change...
TX-16
Dave Park is offline   Reply With Quote
Old 08-17-2010, 07:09 AM   #13
Dave Park's Avatar
2005 22' Safari
-Blake
That is not a radiant barrier application of the product. Also, it's in static compression. The stress on bubbles in an airstream application is the easily 200F temperatures the outside wall can reach - the bubbles go through expansion cycles and are in tension. Over the years, they will leak.
That said, the primary action of the sheet is as a radiant barrier, and the bubbles play little part in that role. They are merely a low cost filler material to reduce conduction from one side of the sheet to the other, to reduce convection effects from sheet to air.
TX-16
Old 08-17-2010, 07:14 AM   #14
SilverHoot's Avatar
1967 24' Tradewind
Greenville , South Carolina
I've done my bellypan area on my back in the dirt working with Prodex and will be doing the walls in a few weeks. I'm sure that the Prodex is more work than fiberglass, but is really not THAT difficult or time consuming. I found it pretty easy to cut to size with scissors and install.
SilverHoot is offline   Reply With Quote
insulation
Is my debate over? purman General Repair Forum 6 05-12-2009 01:40 PM
The Great Toilet Paper Debate moosetags Sinks, Showers & Toilets 26 02-19-2008 08:59 AM
The Great Frame Debate Becky B. Repairing/Replacing Floor &/or Frame 20 05-01-2007 07:44 PM
lets debate at eight! john hd Off Topic Forum 20 10-26-2004 05:45 PM
The Great Towing Debate Continues... Chuck Towing, Tow Vehicles & Hitches 9 04-30-2004 01:20 PM
