07-08-2005, 08:19 AM
Yorktown
That "Old" Smell...
My '72 Ambassador has that "old" smell that permeates the entire trailer. That's the only way I know how to describe it is "old". It's not the "leak" smell...it's the "old" smell.
I aired it out during the homecoming and didn't smell it after about half way through the first day, but now that it's back in my driveway all closed up, it's thick again.
I've heard someone else say in a prior thread that it might be caused by the upholstry. Is this true? I plan on redoing all three of the couches and the fabric "guards" behind the twin couches which is most of the upholstry but will that curb the smell? Will fabreeze work?
Anyone who has any information that will resolve this issue in my trailer will receive $1,000,000 (in the form of a personal check that will bounce as high as Jimi Hendrix) Thanx!
Ben
07-08-2005, 08:55 AM
1968 17' Caravel
Battle Ground
My floor repair project improved the old trailer smell somewhat, as I got a lot of rotten wood and dirt out of the trailer and bellypan. The smell does stay in the upholstery though, and it gets worse when it's closed up. Since i keep my trailer at home I often open the windows and door on hot days, and usually leave the vents open the rest of the time, which helps a lot. Fabreeze on the upholstery might help contain the smell somewhat. I find that after three years I have gotten used to it, and it's just what the trailer smells like. That smell makes me want to go camping now
Stephanie
07-08-2005, 09:47 AM
1956 22' Flying Cloud
Durango
I solved it by replacing the entire interior, including the sub-floor - do I win do I win???
Ken J.
1956 Flying Cloud
Founder :
Four Corners Unit
Albuquerque National Balloon Fiesta
Rally
Vintage Trailer Academy - Formerly the original
restoration rally
07-08-2005, 09:56 AM
1955 30' Liner Commodore Vanderbilt
Wayne County
, Michigan
Yep, they do sometimes stink, got rid of most of our "stink" by removing the old carpeting. We also throw Bounce dryer sheets in the cabinets and stuff to help it out. They are also supposed to help keep away the unwanted bugs and critters (which, knock on wood, has proved to work so far). We also keep the vents cracked open to provide a little circulation as Steph mentioned.
Jason & Veronica J.
S.E. Michigan
1955 Commodore Vanderbilt 30'
"Hawley"
TAC Member MI-6
2008 Chevy Silverado Ext. Z71 w3.73
07-08-2005, 10:20 AM
418
2007 25' Safari FB SE
1958 22' Flying Cloud
1974 29' Ambassador
Yucca Valley
My 1971 Tradewind used to have that old smell. I can best describe it as a combination of plastic, bad breath, and cooking odors.
What helped tremendously was cleaning the walls completely, especially behind the galley cabinets. We cleaned every inch of wall and cabinetry, inside and out. I had to get fresh water in the bucket about 5-6 times before it came clean, and the trailer did not even look really dirty inside.
New upholstery and no carpet did the rest. It did not smell at all after the interior was cleaned and refurbed. It would sit in the hot sun in a storage yard for a week, with no annoying odors to speak of.
I guess that's one of the advantages of the synthetic interiors of the 70's, in that the material really does not absorb odors like real wood.
When the new owners came and looked at the trailer, the first thing the woman said was "ooh, this one doesn't stink!" Maybe that's why it sold so quick.
07-08-2005, 10:27 AM
2006 19' Safari SE
NW of Boston
, Massachusetts
working out the "old" smell
Rivetedude -- we're still working out the "old" smell in ours too. It is strongest after the doors and windows have been closed up, and its worse in the front of the trailer than it is in the back.
We've removed all the carpet and old curtains and shades, and steam-cleaned the cushions, and we still have the smell. I don't notice it so much in the plywood floor (yes, I actually got down on hands and knees and sniffed at the wood -- it smells like wood (thank goodness!). I'm smelling it mostly in cupboards, walls, and ceiling. My latest theory is that propane odor from the old furnace (which we recently replaced) has permeated the old vinyl somehow. Does anyone know if the "old" odor is somehow worse, or different, in trailers of different model years? In other words, do 70s or 80s models with all their ABS plastic, vinyl, etc. have different odors than 60s or 50s models?
Doug & Jamie, AIR #650
07-08-2005, 10:38 AM
2006 19' Safari SE
NW of Boston
, Massachusetts
Uwe -- I think our replies are running along the same vein. I think most of our odor is behind the galley, where the range and furnace are located, but it's also in other areas where cooking odors drifted.
What did you use for the cleaning process to get the odor out of the walls?
07-08-2005, 11:13 AM
Durango
Actually I did the same thing as Uwe on my 59 and 75 - scrub, scrub, scurb..........
Ken
1956 Flying Cloud
Founder :
Four Corners Unit
Rally
restoration rally
07-08-2005, 12:25 PM
2006 19' Safari SE
NW of Boston
, Massachusetts
Ken and Uwe -- you're givin' me some hope here. So what did you use to scrub, scrub, scrub away the odor? Ken -- did the odor in your '75 seem to be concentrated in the vinyl wall covering?
-J
07-08-2005, 01:26 PM
Durango
I'm not sure where the odor was coming from - my trailer had been basically unused for 20 years so it just sat. It was in great condition, but dirty/dusty. If I remember I used pinesole (sp?) - as Uwe - went through several rinses - it did not look like anyone had ever cleaned under cushions in closets etc - I really scrubbed from top to bottom.
Another thing to consider - is if some critters have made their way into the belly - also if you have a leak somewhere, you may be dealing with wet insulation smell - that takes a bit more work to fix. I would start with a good scrub down -
Ken
1956 Flying Cloud
Founder :
Four Corners Unit
Rally
restoration rally
07-08-2005, 01:37 PM
Somewhere
, Indiana
My two cents!
Doug & Jamie,
I was selling a beautiful 1968 Camaro one time. Shortly before listing the car on eBay I was inspecting and photographing the car. All at once a stink took me by surprise. I located a mouse (deceased) in the head liner. How can one little creature emit such a stink I will never know. I used a small canister purchased at Wal Mart that was an odor capture device. Sounded hokey at best, but I was desperate. Geeeee . . . . . get rid of smell pocket $20,000 – I’ll just have to try it. Needless to say – I am adding my two cents to this thread because this device was a life saver. I agree that locating the stink source is important as is a good cleaning. I just thought that I would add some additional food for thought.
Regards,
Henry
07-08-2005, 02:05 PM
2006 19' Safari SE
NW of Boston
, Massachusetts
Uwe's description is the closest I've seen to what we have. It's a combination of cooking odors, propane, and plastic. Earlier it had a mildewy odor that went away after we removed the curtains and carpet and I scrubbed down the dirty walls and floor behind the fold out beds. A few weeks ago we had the old furnace replaced and the old catalytic heater removed and were checked for leaks. So I'm pretty sure there are no propane leaks now but the smell of propane lingers and I think it's an old smell that is still in the vinyl. So I'm going after that next.
What about the rangehood/fan. How do you clean that?
07-08-2005, 02:06 PM
smellovision
I have a '61 Overlander that smells like........umm old too.
If there were a thing such as "smellovision" you know, smell TV, you could use this smell in a creepy basement scene for a horror flick. It would work awesome.
07-08-2005, 02:09 PM
1968 17' Caravel
Battle Ground
When I did the floor I had the cabinetry out and scrubbed the walls with softscrub cleanser with bleach. I concur, there was a ton of dirt on the walls, particularly behind the kitchen cabinet. Lots of dust buildup on the floors around the wheelwell liners as well. There was a lot of cleaning to do, considering I thought the trailer was clean enough during the previous two summers when we were using it!
Stephanie
07-08-2005, 02:14 PM
that smell
That smell is probably a combination of mold accumulation in the bowels and storage areas, and from a leak someplace. Carpet is one place to start, I pulled all of mine out. check... under the sink, closet, under the beds. and the couch.
if you have polybutyline plumbing you may have leaks.
check the stove vent going to the outside, mine was never sealed properly
by the half-as#$ed installers at AS back in 91.
07-08-2005, 04:02 PM
418
1974 29' Ambassador
Yucca Valley
Yellow Spray Bottle
I used Castrol concentrated cleaner, and also some really good cleaner in a yellow spray bottle from teh 99c store. It was 3 or 4 bucks a bottle, not 99c.
pinkflamingoes and creampuff know where to get it. The name of it escapes me right now. I gave mine with the trailer to the new owners. They had 3 boys, figured they need a good cleaner....
My 1963 will smell like paint, varnish, glue and new wiring....how does one get rid of that? I guess a good Cuban cigar will be in order.
07-08-2005, 08:03 PM
Old Paint, rolling again.
1973 Argosy 20
Lorain County
Not so fresh AIRstream
Hi Ben,
I was going to replace my curtains but when my rehab budget disappeared I decided to try Fabreeze. I hung all the curtains out on the clothsline and WET both sides. It worked very well and now that smell welcomes me every time I enter the trailer (except when it's been completely closed up and then I smell the black tank more than I want).
First you need to be certain that it's completely dry inside your TT. I've used "Damp Rid" before but if you have a dehumidifier you could run that inside for a week or so and see if it finds any moisture. Also, try taking out the cushions, store them somewhere dry and see if the smell moves with them, or not.
Probably not related to your problem but I've been wondering...Do you think that there is a way to test that the black and gray water tanks are venting properly?
Perhaps one of the AS Funeral Coach owners has a tip or 2 for eliminating odors?
Best of luck,
Steve
Have you never questioned those who travel? Have you paid no regard to their accounts- Job 21:29
07-08-2005, 08:11 PM
1973 31' Sovereign
Danielsville
Greased Lightning, Odo Ban, and a Good Belly Drop
I've found that Greased Lightning works wonders on the walls with minimal elbow grease. I've also used OdoBan to disinfect/deodorize. The Bounce sheets help as does Fabreeze, although the Fabreeze doesn't seem to last as long as it should.
Definitely cleaning behind everthing (galley, fridge, pantry) is a good idea, and an easy thing to do if you're replacing all the appliances anyway.
Of course, until you've removed the belly pan and banana wrap, you can never really be sure. (Actually, you're probably not a full credentialed old Airstream owner till you've had the pleasure.)
There's no telling what has lived and died under the floor until you've inspected it yourself. It does appear that a squirrel or two has lived in this Sovereign of mine, not to mention countless mice. I have removed all of the nasty insulation (replaced with new R-19 pink) and that's got to make a difference.
You'll never know until you look.......
07-09-2005, 08:16 AM
1951 21' Flying Cloud
1960 24' Tradewind
West Coast
, BC
I told my buddy who just turned 60 that he's picked up that "old" smell. He was not impressed and I can't figure out why. On a more serious note with our '51 we oiled the wood with a lemon type of oil several times as we were refurbishing the interior and let it soak in. Not only did the wood perk right up and now looks gorgeous, but it has a nice clean homey smell to the trailer. I also added a couple of pieces of cedar to the inside of a couple of cupboards and that has added a distinctive, outdoors/camping aroma to the mix, very light but clears off any background smells. We love it. Barry
07-13-2005, 12:49 PM
Yorktown
Thanks for all of your replies! It sounds like from the general concensus that it's the walls. I really didn't clean them when I got the trailer because they looked clean. I guess I'll give that a try and see what happens. I plan on re-upholstering everything anyway so I'll kill two birds with one stone (who thought that up? was there a lot of bird-stoning going one in mankind's past?).
Ben
