Old 10-15-2010, 09:44 PM   #15
RichHog's Avatar
1972 25' Tradewind
Houston , Texas
Alsa Corp makes FX Sheeting in different styles, one I used that looks like Burl wood. I cut it in strips and used it to replace a lot of the old plastic woodgrain trim that was getting brittle. You buy it by the linear foot so it's good to get at lleast 4' so you have long strips to cut and work with. You can see the band around edge in lower right corner
RichHog is offline   Reply With Quote
Old 10-16-2010, 09:06 AM   #16
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
Trim
MonaxLisa
Just to be clear, I did not use the 12"x12" vinyl tile. I used vinyl flooring (ie: like linoleum). It is sold in 12' wide rolls. Since it is sold from a roll 12' wide and I did not want any seams in on the floor I had a considerable amount of left over. Which is what I used to do the trim. It does not have any joints, I cut it 1 1/16" wide and then cut it to the length I needed for each aluminum channel. Hope this makes sense.
Old 10-16-2010, 09:14 AM   #17
Originally Posted by TG Twinkie View Post
MonaxLisa
Please be aware, that a one piece floor covering, will crack sideways at every 4 feet, because of the movement of the floor where it joins together.
That's why floor tiles are used and seamed at every 4 feet.
Old 10-16-2010, 11:51 AM   #18
MonaxLisa's Avatar
1975 31' Excella 500
undetermined , Washington
MonaxLisa
Ohhhh, gottcha. I bet I could buy a remainder strip of that.
MonaxLisa is offline   Reply With Quote
Old 10-16-2010, 05:51 PM   #19
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
One piece cracking
I used the type of vinyl floor covering that is not glued down, therefore the floor can float under it without causing any problem. I only used it in the bath and I don't have much more than four square feet let alone 4 linear feet. I agree with Andy, don't use the type that is glued down.
Old 10-16-2010, 05:51 PM   #20
1970 27' Overlander
Salt Lake , Utah
I have been unable to find a source for insert nosing of any kind. Where can you get it?
Oly10 is offline   Reply With Quote
Old 10-16-2010, 08:38 PM   #21
GAT
Owner Spirit of "76"
GAT's Avatar
1976 31' Sovereign
Ball Ground , Georgia
Shower pan material
I too had the same issue and didn't want to order the material.All the trim in the living area was also damaged. I purchased about one foot of sheet shower pan material(the grey stuff) from Lowes. Spray painted with epoxie paint to match and replaced all of it. This gives you six foot joints. Not exactly what I want but cheap.
GAT is offline   Reply With Quote
Plastic inserts for bathroom trim 1bbboomer General Interior Topics 10 03-09-2017 05:51 PM
Plastic trim in bathroom chuman70 Cabinets, Counter Tops & Furnishings 31 11-28-2010 04:58 PM
How I replaced the plastic bathroom light RichHog 1970-79 Tradewind 5 10-20-2009 09:53 PM
Plastic Bathroom Counters/Sinks lovingtahoe Cabinets, Counter Tops & Furnishings 10 05-06-2008 11:33 AM
Bathroom Plastic is cracked PhilMateo Sinks, Showers & Toilets 2 12-30-2005 04:30 AM
