Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Interior Restoration Forum > General Interior Topics
Old 11-16-2015, 09:20 PM   #1
1976 Argosy 28
Phoenix , Arizona
Tension wire between ribs
I'm renovating a 1976 Argosy 28'. I've taken down the interior aluminum skin and am planning to replace it with 1/4" plywood panelling. However, without the additional strength of the interior aluminum, I'm concerned about the panelling wiggling loose over time due to the subtle flex of the shell. Should I criss-cross tension wire between the ribs in order to firm everything up? This solution was suggested to me, but I've been unable to find any documentation of anyone else using it. Is this necessary? Does anyone have experience with this?
bicen.falcon is offline   Reply With Quote
Old 11-21-2015, 05:59 AM   #2
Belegedhel's Avatar
1973 21' Globetrotter
Houston , Texas
Why not just reinstall the interior aluminum skins with countersunk (flush) rivets, and then install your plywood over-top? Yes, it is more weight, but should relieve your fears about things coming loose. Alternatively, you could just go ahead and use the wood alone and not worry about the "structural support" afforded by the aluminum interior skins, guy wires, etc.. See the thread below for a recent discussion on the relative contribution of the interior:
http://www.airforums.com/forums/f36/...ry-141728.html
Good luck!
Something between the interior skins and ribs? Airwave503 Ribs, Skins & Rivets 20 03-01-2015 07:31 PM
Sufficient Sway Bar Tension? Frank&Mike Hitches, Couplers & Balls 7 10-29-2012 04:37 AM
Tension on Zip Dee? bwaysteve Awnings 3 06-19-2010 12:57 PM
Throttle tension & Cruise control Chaplain Kent Mechanics Corner - Engines, Transmission & More... 10 07-14-2005 09:01 PM
Wire ,wire, oh wire can it be ? 69 Silverback Electrical - Systems, Generators, Batteries & Solar 8 05-15-2003 11:09 AM
