Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Interior Restoration Forum > General Interior Topics
Old 02-05-2005, 05:54 PM   #1
JETER
Profile:
Tempur Pedic Mattress
I have resently purchased a 28ft 2004 Classic with the bedroom in the rear, I'm concerned with the fact that the previous owner has installed an 8" tempurpedic mattress in the rear bedroom. The weight of the bed is quite heavy and I am wondering if anyone has had any problems with this causing swaying and body separation?
JETER is offline   Reply With Quote
Old 02-05-2005, 06:24 PM   #2
maxandgeorgia
maxandgeorgia's Avatar
Profile:  1995 30' Limited
Ashland , Missouri
Don't know, but you'll sure sleep soundly til you fall out! Sorry, I'm sure this is a serious issue, but those memory foam mattresses give SUCH a good sleep
maxandgeorgia
1995 Airstream Classic Limited 30' ~ Gypsy
Chev Silverado 2500HD Duramax/Allison, 4X4, Crew Cab
WBCCI #5013 AIR #2908
WDCU. . .MALs no longer! What's a few miles among Airstream friends?
maxandgeorgia is offline   Reply With Quote
Old 02-05-2005, 07:01 PM   #3
85MH325
85MH325's Avatar
Profile:  Tipton , Iowa
Images: 37
we took the stock horrible 8" RV queen mattress out of our 34' and pitched it. By removing the head board, we were able to replace it with a full-sized 11" foam mattress made by the Lebeda Mattress company. In any event, the trailer doesn't handle any differently, and since we carry very little weight in the back anyway, it doesn't seem to make any difference at all.
Roger
AIR 2053 “A generation which ignores history has no past and no future.” Robert Heinlein
2006 Bigfoot 25B25RQ towed by a 2001 Born Free 23RK moho
Old 02-12-2005, 10:43 PM   #4
Theo
Confused & Wandering
Theo's Avatar
Profile:  1993 34' Excella
Right here, , where ever I wake up
It is my intention to fit a custom sized Tempurpedic mattress into our 34ft, as the thing in it at present fails to meet the requirements needed to call it a mattress - we have been sleeping on it only when 2 memory foam toppers were covering it.. One is not enough so the sooner that monstrosity leaves the bedroom, the better.
Theo
'05 Cargo hauler gooseneck, carrying an '05 Jeep TJ, all hauled by an '05 C4500 Kodiak Truck
Theo is offline   Reply With Quote
Old 02-12-2005, 11:32 PM   #5
Bob Thompson
'97 Excella 25
Bob Thompson's Avatar
Profile:  Corpus Christi , Texas
Images: 60
Looking at it from a common sense point of view, the Tempur-Pedic mattress probably weighs about 120 pounds. A similar Talalay Latex mattress, about 135 pounds. An OEM queen mattress probably weighs about 50 pounds. So.... the Tempur-Pedic weighs about 70 pounds more. Not much weight to a 7000 pound trailer. Only 1%. Little effect on the other 99%.
Or... short queen mattresses are usually 59" x 74" and it is 8" thick, that is close to 20 cu. ft. . At 5 lbs. per cu. ft. density, that's about 100 pounds, plus a 6 lb. cover brings the weight to about 106 pounds or 56 more pounds than the OEM mattress or about .8 % of a 7000 lb. trailer.
Bob Thompson is offline   Reply With Quote
Old 02-13-2005, 01:07 AM   #6
Anon
Profile:
Good thing these memory foam mattresses have come along. I wish I could do something about the cushions in my Minuet. They were fine when I was younger but now I tend to feel every little seam in them.
Good luck with your mattress ideas. Keep dreaming them up, (no pun intended).
Anon is offline   Reply With Quote
Old 02-13-2005, 07:07 AM   #7
Silvertwinkie
Aluminut
Silvertwinkie's Avatar
Profile:  2004 25' Safari
Northern Suburbs , Illinois
This is not factual or anything, but if you really think about it and the numbers are a close as has been suggested, the frames have been tweaked quite a bit over the years. Heck the 25' Safari SS has about 150 pounds of black tank back there. If one were removing weight and adding a bit more in it's place, I'd suspect it could be ok. I know the newer Classics are suppose to have more robust axles, so NCC will clearly go up, I would guess that using common sense when loading would be a good idea. One question I would have about newer coaches would be if they increase the NCC limits by adding larger capacity axles, have they done any further frame improvements or are they needed? Of course this all means squat to those that already have a coach....
Old 02-13-2005, 09:06 AM   #8
rtaylor537
Profile:
Check out the foam mattress by Dormia. They make a short queen which fits the Excella platform. It is about 8inches thick and reasonably priced.
RTaylor
rtaylor537 is offline   Reply With Quote
Old 02-13-2005, 11:48 AM   #9
Theo
Theo's Avatar
Last year, I had 4 ammunition boxes, full of .45acp ammo under the bed.. that put a weight of 350 pounds under there, and caused no sag, no damage, and no adverse handling problems, in 3200 miles of travel. ( I went to a gun show, and bought the ammo, and a few other things.. I got 1000 pounds of various bits of junk in the back of the truck, and put the ammo in the Airstream..)
Theo
Old 02-13-2005, 02:36 PM   #10
Silvertwinkie
Aluminut
Theo
Guess we all know who's Airstream we should stay clear of.
Old 02-13-2005, 08:54 PM   #11
Over59
Over59's Avatar
Profile:  1959 26' Overlander
1968 17' Caravel
Images: 37
I'ld be more worried if he drove that monster after happy hour. When it hits the fan Theo's our man.
Let those who can play, let those who cann't watch....
Over59 is offline   Reply With Quote
Old 02-14-2005, 05:49 AM   #12
norbert
norbert's Avatar
Profile:  1993 30' Excella
chicagoland , state of confusion+north of cheddar curtain
Images: 24
temperpedic?....the previous owner must have been a millionaire.....
norby
Illegitimous noncarborundum(dont let the bastards wear you down)
The only true nobility is found through giving good food to your friends- Anton Careme
beauty is in the eye of the beerholder-cosmo fishhawk
if something is too good to be true, its usually gone before i get there-mister boffo
norbert is offline   Reply With Quote
Old 02-14-2005, 06:44 AM   #13
Silvertwinkie
Aluminut
...should have also said, park next to.
Driveway camping with new mattress! 85MH325 Our Community 11 05-04-2004 03:42 PM
96 Excella Mattress For Sale Like New dufrain Parts Archive 4 11-29-2003 08:52 PM
Original Airstream Mattress... 85MH325 General Interior Topics 8 07-17-2003 04:31 PM
Buying mattress pad? beware of Camping World false ad. femuse Our Community 5 03-19-2003 06:55 PM
Mattress replacements for '99 Safari cljackson 1999 Safari 6 02-03-2003 10:51 AM
Cooking Forum - Sailing Forum - Early Retirement
Airstream Trailer Forum - Aquarium & Reef Forum
Royal Forum - Book and Reader Forum - Yoga Forum
Volkswagen Touareg Forum - Jeep Wrangler Forum
Whitewater Kayaking & Rafting Forum - Yoga Forum
U2 Forums
