Old 02-21-2012, 10:47 AM   #1
1977 23' Safari
Magnolia , Texas
Send a message via AIM to JillyBean63 Send a message via Yahoo to JillyBean63
Tambour On Kitchen Cabinets Hard To Open and Close
Is there something to help this or is replacement the only option? Thank you!
JillyBean63 is offline   Reply With Quote
Old 02-21-2012, 11:28 AM   #2
1974 29' Ambassador
1976 25' Caravanner
trenton , Missouri
If the doors are intact a good cleaning and lube should help. Use a Q-tip or small piece of rag with a popcicle stick and rubbing alcohol to clean the door channels. Some folks use WD-40 in the channels and it works well. I recently found some dry lube in a spray can which sprays wet and turns dry in a few minutes, works very well and doesn't smell. I got this at an automotive store. I don't have it in front of me but I recall that it is Liquid Wrench brand.
bimpy is offline   Reply With Quote
Old 02-21-2012, 11:46 AM   #3
1981 31' Excella II
New Market , Alabama
Use some slicone spray. It does not leave much of a mess behind. It cured all my tambour problems. I think GUNK makes some. Go to Autozone or Advance Auto Parts or Even Walmart and they should have it.
Perry
Old 02-21-2012, 12:00 PM   #4
SummitAir's Avatar
1970 27' Overlander
Summit , Mississippi
Have any of the tambour slats come loose at the side and jumped the track to where they are now sticking out on the outside of the track? Had this problem causing them to be hard to move. Replacing mine with new ones because of the broken ends jumping the track.
SummitAir is offline   Reply With Quote
Old 02-21-2012, 12:06 PM   #5
1977 23' Safari
Magnolia , Texas
Thank you all. They appear to be in tact.
Old 02-21-2012, 12:08 PM   #6
c_lewis77's Avatar
1982 34' Limited
Brunswick , Georgia
Images: 22
JillyBean:
here is a good video that may help!
1982 34' Limited
2000 Excursion V10 4x4
WBCCI #3321
TAC #GA-24
c_lewis77 is offline   Reply With Quote
Old 02-25-2012, 08:55 AM   #7
MaxAB's Avatar
1977 31' Sovereign
1985 25' Sovereign
South Central Rockies... , "...'Stream'n the Dream" thru the USA
Silicone spray might work after a good scrub down...
Art - W0ABX
High Desert Country of the Rockies
'85 Sovereign 25'er
WBCCI: 2197; AIR #: 36503; TAC #: NM-5
MaxAB is offline   Reply With Quote
I was told 'Not to Join'??? Travel Bird WBCCI Forum 159 05-09-2015 06:46 AM
Cost to go from copper to PEX? CarrieSue Trailer Values 15 02-25-2012 09:19 PM
Trip to Washington DC BLUEBELL On The Road... 11 02-21-2012 12:59 PM
Need info on WBCCI number on AS nascar427 WBCCI Forum 16 02-21-2012 04:23 AM
