Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Interior Restoration Forum > General Interior Topics
Old 01-24-2007, 10:17 AM   #1
Profile:  1974 29' Ambassador
1976 25' Caravanner
trenton , Missouri
tambour doors
I need to replace several tambour doors. Does anyone know if you can buy this material in large sheets and cut it yourself?
bimpy is offline   Reply With Quote
Old 01-24-2007, 10:24 AM   #2
InsideOut's Avatar
Profile:  1964 19' Globetrotter
1956 22' Safari
Only Airstreamer in Edgewater , Colorado
Images: 87
Not necessqarily the same plastic laminate finish, but you might want to try Outwater Plastics or for real wood, try any wood working store like Rockler.
Put in "tambour" as your keyword search
Shari
RMVAC | WBCCI DenCO Unit | Maxwell | Birdy
Old 01-24-2007, 11:16 AM   #3
VAC Membership Chair
Buttercup's Avatar
Profile:  1977 27' Overlander
1954 25' Cruiser
VC Highlands , Nevada
Send a message via Yahoo to Buttercup Send a message via Skype™ to Buttercup
Winona Manufacturing: Decor Tambour, Ceiling Systems, Kitchen Cabinet Doors is the original manufacturer of the tambors in the vintage units (well our '77 anyway) so you can try them.
Buttercup's Web Site. Save WBCCI - Save Wally! Check out the SaveWally Unit Guide. WBCCI # 17330, VAC Membership Chair/Webmaster, CAC.
2009 Mouse count:
Buttercup - Possibly 3 but I haven't caught them - yet!
Airtini -
Buttercup is online now   Reply With Quote
Old 01-24-2007, 11:29 AM   #4
1976 25' Caravanner
trenton , Missouri
thanks guys. I checked Rockler some time ago,but could not find material of correct thickness and slat width. I'll check again with them and check Winona and Outwater also.
Old 01-24-2007, 11:43 AM   #5
azflycaster's Avatar
Profile:  1975 25' Tradewind
Phoenix , Arizona
Images: 62
If you have all the pieces to the old doors, they can be repaired by putting new backing material on them.
Richard
Charter Member Four Corners Unit
Old 01-24-2007, 11:50 AM   #6
Buttercup's Avatar
1954 25' Cruiser
I wish that was our problem! Our doors were falling apart completely. Something about MDF and heat..... We will have order all new and start over.
2009 Mouse count:
Airtini -
Old 01-24-2007, 12:18 PM   #7
Lumatic's Avatar
Profile:  1971 25' Tradewind
Estancia , New Mexico
Through trial and error I have been able to do a pretty good repair:
1. Separate and clean up the old tambour, take off the handles
2. Apply strips of aluminum tape about 6" apart to attach them
3. Cut sections of packcloth (Rockywoods Fabrics, Colorado) the size of the tambours
4. Glue the packcloth to the backs using contact cement
And yes, you can get new cut to size or in large sheets
Old 01-24-2007, 01:01 PM   #8
1976 25' Caravanner
trenton , Missouri
thanks marshall. I have some aluminum tape and I've been wondering what I will use it for!
Old 01-24-2007, 06:17 PM   #9
Ganglin's Avatar
Profile:  1971 27' Overlander
Gahanna , Ohio
Images: 13
Airstream sells the material in 4 X 8 sheets.
OHIO - WE ARE THE MOTHER SHIP
Gary
Old 01-24-2007, 07:10 PM   #10
Lumatic's Avatar
Tambour Sources
(see my post above)
Rockywoods Fabric's phone number is 970 663 6163
I found this tambour source a couple of years ago so the prices are old.
4'x8' Walnut Tambor material - about $100
Tape-Ease, Depere WI 920 864 3461/ 888 443 3461
Old 01-24-2007, 07:17 PM   #11
Royce's Avatar
Profile:  1977 Argosy Minuet 6.0 Metre
Colorado Springs , Colorado
Some of the Pergo type flooring may be the correct thickness. If you can fine a thickness and pattern you like mill your own strips and attach pack cloth to the back as suggested in a previous post. Contact cement will work fine or you can use "Roo Glue". Any glue that remains flexiable and will glue fabric to wood will work.
Royce (KORKK) and Karen
AIR# 3913
'77' Minuet 6 Metre TV: '94' Wrangler, 4.0L inline 6, Ford 8.8 rear, NV4500 tranny, Old Man Emu suspension, 30x9.5 tires
Royce is offline   Reply With Quote
Old 01-30-2007, 09:18 AM   #12
Commercial Vendor
Silver Threads's Avatar
Profile:  1966 24' Tradewind
Kingston , Tennessee
you may also try this site. They also sell a tool to make your own if you are talented and patient enough to make it. http://woodworker.com
John & Tammy
Silver Threads Custom RV Curtains
1966 Tradewind | AIR 15902
Silver Threads is offline   Reply With Quote
Old 01-30-2007, 09:38 AM   #13
Always Airstreaming!
rickandsandi's Avatar
Profile:  2005 22' Safari
1960 24' Tradewind
Anytown , Connecticut
Send a message via AIM to rickandsandi
I know JC had some sheets in their Bargin Room. Give them a call to see if they still have them.
J. Rick Cipot
Sandi Gould
NEU New England Unit
Airstream Life Magazine
WBCCI #3411
AIR #17099
2009 Silverado 2500HD
2004 22' Safari
1960 24' Tradewind
rickandsandi is offline   Reply With Quote
Old 01-30-2007, 12:35 PM   #14
Profile:  1971 31' Sovereign
Hamilton , Ontario, Canada
Hey Bimpy
I am also in the same boat with a 1971, part # is 800368.01 this is from the parts person at a/s you just have to order it from your local dealer comes in a 4x8 sheet good luck
Atomic#13 is offline   Reply With Quote
Replacing Tambour [Credenza] niftypkg Cabinets, Counter Tops & Furnishings 5 01-16-2007 01:36 PM
Tambour Door Resources InsideOut Link Archive 4 09-23-2002 04:12 AM
Cabinet Door Retrofit to Tambour Doors ARGOSY79 Cabinets, Counter Tops & Furnishings 5 08-28-2002 09:34 AM
Tambour..... Chuck Cabinets, Counter Tops & Furnishings 4 07-22-2002 02:00 PM
Must be sick of me by NOW - Tambour Door repair niftypkg Cabinets, Counter Tops & Furnishings 4 07-05-2002 12:11 PM
