Old 12-08-2019, 04:29 PM   #1
2020 23' Flying Cloud
Cape Coral , Florida
Table removal
Hi all,
We have a 2020 23 FB we’ve owned for 2 months. Our problem is with the dinette table in the booth. We HATE the pedestal that you can unlatch and swivel and are going to make a smaller table top that is narrower so we can slide in and out easily. It’s just the 2 of us so no one will be using the bed.
Now to our problem... we can’t figure out how to remove the sliding plate under the tabletop from the tabletop. Once it’s removed we are going to remove the slides and attach the smaller tabletop to the wide plate mounted to the pedestal.
If this doesn’t make sense imagine drawer slides. These are positioned flat on top of the plate between the tabletop and the metal plate.
Would appreciate any suggestions, but only if you know it will work. We’re fairly handy but this has stumped us!
One Smith is offline   Reply With Quote
Old 12-10-2019, 07:51 PM   #2
Cispook's Avatar
2017 27' Flying Cloud
Chillicothe , Ohio
Call the factory tech rep. They will help you.
Cispook is offline   Reply With Quote
Old 12-11-2019, 06:50 AM   #3
2018 23' Flying Cloud
Punta Gorda , Florida
Yep Agree that the table in the 23 can be frustrating. Yes the slider mech. can be removed by getting under the table and removing the screws from slider to table first. You have to move the slider back and forth to access the screw heads the are located within the actual slider slot tracks. Then once the table is off, you can now access the screws that mount the slider to the post. The plate on the post then can be used to fix mount a table of your choice, I used a pre made top which is sold as a tool cabinet work topper. Keep all of parts and table in for when you trade or sell. Take some care as the table is heavy, and when moving the slider to access the table screws can get away on its own. Let us know how it went or if you need further.
Jobjar is offline   Reply With Quote
Old 12-11-2019, 07:39 AM   #4
2015 23' FB Flying Cloud
Omaha , Nebraska
We replaced ours with a Lagune pedestal but kept slider mechanism. Frees up space under table and allows side to side table movement. Very happy with it. Click image for larger version
ID:	357540Click image for larger version
ID:	357541Click image for larger version
ID:	357542Click image for larger version
dolson is offline   Reply With Quote
Dinette Table (table top and 2 legs) helluva Airstream Classifieds 0 04-25-2016 01:49 PM
1985 Excella credenza, fold out table, little shelf that goes on top of the credenza, table next to the front door, chairs janeinthemtns Airstream Classifieds 0 10-12-2014 11:37 AM
credenza, dining table, small table for top of credenza, small table from other side of trailer janeinthemtns Airstream Classifieds 1 09-25-2014 06:24 PM
falling table leaf of credenza fold-away table Fenghuang Cabinets, Counter Tops & Furnishings 3 02-13-2007 11:27 AM
