If it can be taken apart, your neighborhood sign shop (one with a wide format digital printer) should be able to replicate it for you. The cause I can see on the failure is that most likely the screws the factory used are not stainless and rust stains from the threaded area are traveling underneath the image area. I am currently upgrading my screws to stainless as I have the same issue popping up in several areas, though mostly on woodwork ☺
Unfortunately if you pull those screws out and see rusty threads you may own Ms. Stewart an apology...
