Old 03-02-2014, 01:47 PM   #1
Miami , Florida
Swaging 1/4 aviation wire
Hi all. This is my first post here. I need to be pointed in the right the direction. I would like to swage(?) and 1/4" nylon coated aviation wire with a single shank ball but, I have no idea how to do it or what tool I should use. Thanks in advance.
slash8789 is offline   Reply With Quote
Old 03-02-2014, 02:32 PM   #2
GeocamperAS's Avatar
1974 Argosy 28
1978 Argosy Minuet 6.0 Metre
Wauwatosa , Wisconsin
Images: 37
I am familiar with swaging copper tubbing but never heard of it for wire. So I just had to look it up. Not the same process at all. Here's a site I found. Doesn't look like a job for someone wanting to only do it once. The tools look expensive.
http://www.atitools.com/ATICatalog20...aging_2010.pdf
Judging a person does not define who they are, it defines who YOU are.
GeocamperAS is offline   Reply With Quote
Old 03-02-2014, 02:54 PM   #3
Maniacal Engineer
barts's Avatar
Menlo Park , California
I'd see what is available from nicopress.
If you're working on planes, see
http://www.337skymaster.com/document...inspection.pdf
However, 1/4" is big for planes.
Single Shank Ball MS20664
- Bart
Bart Smaalders
Menlo Park, CA
http://tinpickle.blogspot.com
http://smaalders.net/barts
barts is offline   Reply With Quote
Old 03-02-2014, 03:46 PM   #4
pgr32e's Avatar
1974 27' Overlander
Sault ste Marie , Ontario
Check with a local aviation maintenance organization. they make the swage fitting MS20664C8, the tool to do it is pretty expensive so the mtc. outfit can tell you if they can do it or point you in the right direction.The coating will have to be removed for the swage though.....Phil.
pgr32e is offline   Reply With Quote
Old 03-02-2014, 04:06 PM   #5
garthbf's Avatar
1975 31' Sovereign
1960 26' Overlander
Mount Vernon , Washington
find a yacht rigger near you. they can do it.
garthbf is offline   Reply With Quote
Old 03-07-2014, 09:02 PM   #6
1971 21' Globetrotter
Redondo Beach , California
I love to swage. I bought my first swaging tool a few years ago, and I'm amazed at all the uses I keep finding for doing things with stranded cable instead of rope or whatever. For example, my backyard hammocks hang from cable. They stay put with no stretching. That said, the upfront investment is pricey. Especially when you get into larger cables, like 1/4". I only go up to 5/32", which has something like 2000lb break strength.
You also need a good way to cut the cable. Regular wire cutters are no good, nor are bolt cutters. I bought a Felco C7 which is amazing, but also $65 for a little hand tool. Then I trolled eBay for awhile to find a used pair of the ferrule crimpers to do the 5/32 cable, and the Nicopress swaging crimper was around $70. Very happy with the results though.
BenHud is offline   Reply With Quote
1988 Running Light Exposed Wire vhariable Lights - Interior & Exterior 2 06-25-2011 08:56 PM
Where does this heavy black wire go? malconium Electrical - Systems, Generators, Batteries & Solar 3 05-31-2011 01:07 PM
One Wire Running Lights---Effects on Grounding tinbender Lights - Interior & Exterior 7 04-18-2011 07:22 AM
Burnt wire on my univolt MonaxLisa Batteries, Univolts, Converters & Inverters 11 03-23-2011 12:31 PM
Running Lights LED - How do I route the wire? AirHome Lights - Interior & Exterior 6 02-20-2011 07:15 PM
