Old 09-24-2005, 08:13 PM   #1
1972 29' Ambassador
Tucson , Arizona
Suspended Ceilings
I'm having problems with putting a suspended ceiling in my trailer. The Bozo's I have working on it in AZ, thinik I"m crazy. They're having trouble with the curves, and they say I won't have enough headroom. I figure it's the only way to put all the floresent lights in, and make it look decent. Has anyone else done this? Any advice? I've got to straighten out these clowns.
tamis is offline   Reply With Quote
Old 09-24-2005, 09:38 PM   #2
Janet H's Avatar
1964 26' Overlander
1964 19' Globetrotter
Eastern , Washington
Images: 90
Hi Tamis, I've never seen suspended ceilings in an Airstream and will be interested to hear about your end result. Have you considered using halogen lighting instead? Small fixtures or a small cove edge with hidden under mount lights might do the trick.
AirForums Custom Search
Janet H is offline   Reply With Quote
Old 09-25-2005, 05:13 AM   #3
Rivet Monster
wahoonc's Avatar
1975 31' Sovereign
1980 31' Excella II
Sprung Leak , North Carolina
Images: 40
Tamis, I am inclined to agree with the reduced head room comment....I am 6'-2" and would hate to loose even an inch of head room. You can buy recessed fluorescent fixtures designed for RV's...but you would have to cut into the inner skin for installation. Aaron
WBCCI #XXXX AIR #2495
Old 09-25-2005, 05:53 AM   #4
1977 31' Sovereign
1989 34' Excella
Johnsburg , Illinois
I have indirect lighting with lights facing up from sides reflecting off the ceiling. I have it at low level for watching tv or the like and have direct lighting for reading, eating, playing cards. Florescent uses less watts and led even less if you are really trying to conserve battery power.
Old 09-25-2005, 08:39 AM   #5
This is easily the most baffling post I have seen in a long time. Is it a joke of some sort? If not, are the "bozos" in Arizona also having trouble with the sunken tub in the bath?
Both surface mount and recessed 12 volt fluorescent lights are available from RV and marine suppliers. There are several threads in the archives on installing recessed fixtures in an Airstream.
Mark
'85 Sovereign, 25'
Old 10-03-2005, 09:13 PM   #6
1972 29' Ambassador
Tucson , Arizona
It's a Joke.....
What can I say, a few cocktails and a sick sence of humor.........
Now, about that sunken tub.............
The "Bozo's" in AZ are doing a fine job. Or, I should say, have done a fine job. It's been fixed and ready to roll.
Just waiting for this clown to buy a tow vehicle, and go pick it up.
Have you used this on your walls and ceilings? mello mike Upholstery, Blinds, Walls & Interior Finishes 14 09-28-2014 10:33 AM
another Caravel owner davidw 1966-68 Caravel 46 02-03-2005 06:53 PM
gear ratios RVNUTTY Tow Vehicles 11 09-04-2004 03:38 PM
