Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Interior Restoration Forum > General Interior Topics
Old 10-21-2006, 09:56 PM   #1
Merry Stahel
Profile:  1974 31' Sovereign
Osceola , Missouri
Stupid Question Time...
I have a 74 31' Sovereign. We have gutted it in prep for a full restoration.
I have questions.
Has anyone ever gone ALL electric? Removed all propane appliances, including furnace, stove and fridge?
Recomendations for an ELECTRIC tankless hot water heater that handles high volume (I found a low volume one, but I love my LONG hot showers <grin>).
Thanks!
Merry
Merry Stahel is offline   Reply With Quote
Old 10-21-2006, 10:11 PM   #2
Bob Thompson
'97 Excella 25
Bob Thompson's Avatar
Profile:  Corpus Christi , Texas
Images: 60
When I was looking for my first Airstream, I ran across an all electric '96 25' Excella for sale near Sarasota, Fla. The original owner's wife was scared to death of propane due to some former incident so they ordered the all electric Excella direct from the factory. Unfortunately the trailer leaked like a sieve and the floor was rotting. It was all moldy and damp inside so I ran like hell!
2002 Toyota Tundra
Why is it Levee's built by volunteers with sand bags hold better than Levee's built as directed by the Corps of Engineers with millions of taxpayer dollars?
Bob Thompson is offline   Reply With Quote
Old 10-21-2006, 10:19 PM   #3
Merry Stahel
Osceola , Missouri
Due to an unfortunate fire in my teens, I too, am afraid of fire. Open flames don't bother me - having to restart a pilot light or a sparkingelectronic ignition, that sort of thing scares me.
We will be doing all electric, I just wondered of anyone else has ever done so? Is there anything to watch out for? Advice, tips, suggestions, things to beware of?
Thanks, Merry
Old 10-21-2006, 10:42 PM   #4
Foiled Again
Foiled Again's Avatar
Virginia Beach , Virginia
Talking Fire good.
Thanks, Merry
You're going to be restricted to being at full service campgrounds only - no boondocking. Now I thought I'd be spending 99% of my time in just those circumstances, but I've found the joy of being self contained. The new gas water heaters have ignitions that don't require a long match or lighter, and a gas water heater recovers much faster than an electric one. I never had propane before, but I'll tell you the smell is "distinctive".... You'll never have a leak you won't smell LONG before it becomes dangerous.
By all means get a convection microwave oven if you want, but I'd really try to get some help getting over the fear of open flames and keep the water heater and gas burners.
Whatever you decide... enjoy your airstream.
Paula
Old 10-21-2006, 11:07 PM   #5
azflycaster
azflycaster's Avatar
Profile:  1975 25' Tradewind
Phoenix , Arizona
Images: 58
I agree with Paula, I boondock 99% of the time and could not be without propane. Another thing to think about is the amount of current all electric is going to use. Your trailer most likely has 30 amp service as do most RV parks. Add the amperage of the items you want to run at the same time and you will be way over the 30 amp number. 120 volt tankless water heaters draw alot of power (20+ amps) as do A/C units, stoves and ovens. Check out the units you want to get, find the amout of current they require and do the math.
Richard
Charter Member Four Corners Unit
Old 10-21-2006, 11:31 PM   #6
ROBERTSUNRUS
ROBERTSUNRUS's Avatar
Profile:  2005 25' Safari
Lakewood , California
Images: 18
I have questions.
Thanks!
Merry
Hi, with everything electric, you would probably have to have 50 amp service; And with the exception of a hot plate, I believe electric stoves all run on 220 volts. And if I'm right about this, what campsites have 220 volt systems for you to plug into? High voltage could be just as dangerous as with a propane problem. [Key word Problem]
Old 10-22-2006, 01:30 AM   #7
Chaplain Kent
Chaplain Kent's Avatar
Profile:  Wauwatosa , Wisconsin
You will be without a cook stove since none operate on 110 and if you ever did find one the amp drain would be too great for campground wiring. Then there is the problem of campground wiring. Many, too many, campgrounds have poor wiring, reverse grounds, no grounds, low voltage, and anything else that can go wrong. There have been times that I will plug Chummy in only to unplug and go without due to the campground wiring problems. I am willing to bet that more fires are caused by electrical problems than by propane problems. One other thing for you to consider is the resale if you do go all electric. You may not think you will ever want to sell but most of us are on at least our second Airstream. An all electric trailer will make it difficult to sell and diminish the price. I drive a motorhome with a 100 lb. propane tank that extends from the passenger seat almost to the entrance door and we keep it full. There is a propane gas detector inside but as previously mentioned the rotten egg smell from a leak is very distinctive. The only concern I have about the propane is the ever increasing price.
Chaplain Kent
1982 280 Turbo Diesel Motor Home (Chummy)
http://www.fuzzytravel.com/grandakent/
Chaplain Kent is offline   Reply With Quote
Old 10-22-2006, 02:40 AM   #8
Merry Stahel
Osceola , Missouri
Hmmm..the voltage thing would be a problem. I shall reconsider.
That said, when we boondock, we stay in tents. We've been doing it for about 14 years. Although Mom and Pa bought a pop-up a couple years ago, they've never really cooked in it, we STILL cook outside even when they bring it along.
The problem is that we have various needs for this Airstream. It wasn't bought to camp in, it was bought so I'd have a living space while the house was being built. Due to construction delays, looks like I might be living in it for up to a year. I am permanently parked on my property, tied into septic, electric and water.
I'll be staying in it through the winter. An experimental night sleeping arrangement was tested 3 nights ago - the electric space heater did a fine job of keeping the place warm. Of course, it only dropped to the mid 30s...so we shall see.
We still have a long way to go to rehab it, flooring, cabinets and walls are awaiting a dry day because we need to caulk a couple windows before the floor is tackled. Some leak spots have damaged the subfloor.
Anyway, I'll talk to the husband and Pa about which propane devices may stay, if any.
Thanks for the advice and I'll refer them here to see what you have to say, too! Thanks again!
Merry
Old 10-22-2006, 07:23 AM   #9
Bob Thompson
'97 Excella 25
Images: 60
On the "all electric" Airstream I saw in Sarasota, the owner used a 110v hotplate for cooking. The upgrade to 50 amp service will likely be a necessity.
2002 Toyota Tundra
Old 10-22-2006, 07:50 AM   #10
CanoeStream
CanoeStream's Avatar
St. Cloud , Minnesota
Images: 13
No trailer should be without a smoke detector and CO detector (mounted high) and a propane detector. The latter is mounted near the floor since propane is heavier than air. One might not smell it right away down there, so the detector is vital. New units certainly have all three and anyone should retrofit if theirs doesn't have them!
I was traveling last week in 30 degree weather and having my LP furnace running was cheap insurance to keep the pipes thawed. (Unthawed if you speak Minnesotan... )
CanoeStream is online now   Reply With Quote
Old 10-22-2006, 07:59 AM   #11
Auretrvr
Auretrvr's Avatar
Profile:  Iowa City , Iowa
CO detector
Canoe Stream,
I know smoke detectors need to be up high, but I just got a CO detector and was going to mount it low. I always thought it was "heavier" than air. (Our home bedroom is below grade and our kids said we needed to put one at a lower lever where the CO "sinks". I need to be sure on this one.
Airstream OCD...there is no cure!
1983 Classic 310 Motorhome.
AIR 15765
Auretrvr is offline   Reply With Quote
Old 10-22-2006, 08:02 AM   #12
Bob Thompson
'97 Excella 25
Images: 60
It occurred to me some people may be too young to remember hotplates so here's a pic of one:
2002 Toyota Tundra
Old 10-22-2006, 08:40 AM   #13
markdoane
Profile:  , Minnesota
Images: 59
I agree that you should probably upgrade to 50a service if you want to avoid propane. You can run a 240V cooktop and oven on a 50a campground service, or your temporary service at the construction site.
You should figure out a way to get warm air to the black and greywater tanks if you don't use the propane furnace. May be as simple as installing a booster fan in the existing ductwork, or running just the furnace fan to draw warm air from the electric spaceheater.
Non-contributing deadbeat.
Old 10-22-2006, 09:43 AM   #14
Fyrzowt
Fyrzowt's Avatar
Profile:  2000 25' Safari
Templeton , California
Images: 8
Originally Posted by Auretrvr
Canoe Stream,
Actually, it depends. Here's a link.
Dave
http://www.newton.dep.anl.gov/askasc.../chem03364.htm
Fyrzowt is offline   Reply With Quote
Question re new floor fitting on our 1958 Traveller williamhenshall Repairing/Replacing Floor &/or Frame 9 06-30-2004 03:08 PM
Stupid human tricks, part 2 74Argosy24MH Off Topic Forum 9 12-22-2002 01:14 PM
Stupid Human Tricks airstreamcaravel General Repair Forum 12 11-20-2002 02:08 PM
Number Decals Question wagsrp Airstream Motorhome Forums 7 10-11-2002 08:18 AM
Newbie question Rog0525 Our Community 2 05-27-2002 01:30 PM
Cooking Forum - Sailing Forum - Early Retirement - Airstream Trailer - Aquarium Forum - Royal Forum - Book Forum - Yoga Forum - Volkswagen Touareg Forum - Jeep Wrangler Forum - Whitewater Kayaking & Rafting Forum - Fiberglass RV Forum - U2 Forum
