Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Interior Restoration Forum > General Interior Topics
Old 04-18-2004, 11:04 AM   #1
tin can luv
tin can luv's Avatar
Profile:  1968 22' Safari
1976 27' Overlander
Newport , Washington
Images: 82
Question Stripping paint off aluminum
OK, have had this aluminum window frame doused in stripper all day, and nothing is really happening. I was just going to paint them, but realized that they were aluminum (duh) underneath, and now have scratched them up too bad to paint, but cant get the paint off.
I'm using my fav. Bix stripper....what else should I try that I can buy at the store, I don't have time to order anything....
Ron
Ron ... now in Newport, Washington
[font=Impact][font=Arial Black]
tin can luv is offline   Reply With Quote
Old 04-18-2004, 12:06 PM   #2
summerkid
Profile:  1962 16' Bambi
1959 18' "Footer"
1964 19' Globetrotter
Kankakee , Illinois
Ron, I've had good luck stripping painted metal of all types by just soaking it in a tray of LimeAway. Can't vouch for aluminum specifically, but on my metal floor grates, for instance, the paint quickly bubbled off in big pieces. CLR (Calcium-Lime-Rust, I think) is another commonly available substance that's hell on paint.
summerkid is offline   Reply With Quote
Old 04-18-2004, 01:19 PM   #3
InsideOut
InsideOut's Avatar
Profile:  1964 19' Globetrotter
1956 22' Safari
Only Airstreamer in Edgewater , Colorado
Images: 87
Another is Aircraft Stripper by Kleen Strip. It can be found at most auto supply stores & WalMart. It's nasty stuff...but should do the trick. It worked better than Bix for me on some stubborn clearcoat. Be sure to read & heed all the warnings & instructions...good luck!
Shari
RMVAC | WBCCI DenCO Unit | Maxwell | Birdie
Old 04-18-2004, 08:19 PM   #4
tin can luv
1976 27' Overlander
Images: 82
finally.
Once I made it to the hardware store, (a different branch of the same hometown hardware store down the street, which is closed on Sun.) I completely forgot to buy Lime away. I found a whole stash of aluminum strips, corners, all kinds of 'I might need this' aluminum.
So, after wearing the prints off of my fingers, because my rubber stripping gloves are missing, I finally was able to get down to the aluminum. I WILL be checking out that other stuff tomorrow.
Thanks, just an update....
Ron
Name:	April 18th Ralph 024.JPG
Old 04-18-2004, 09:32 PM   #5
w7toc
Profile:
Peelaway
Hi All:
There is a product PEELAWAY http://www.dumondchemicals.com/ that I have used before that can take off 4 or 5 layers of paint in one application. The best part of using this product is that it is not messy and it is very easy to use.
Might be worth a check out.
Rick
w7toc is offline   Reply With Quote
Interior Aluminum Replacement swebster Upholstery, Blinds, Walls & Interior Finishes 34 02-24-2005 09:14 PM
permanent decal & paint stripping 0557 Our Community 1 02-19-2004 05:44 AM
Exterior paint peeling! Astrodokk Airstream Motorhome Forums 2 08-10-2003 08:18 PM
Question on what kind of paint to use for interior respray williamhenshall Upholstery, Blinds, Walls & Interior Finishes 2 08-15-2002 05:39 PM
Help...re Paint GOOFUP Cat Clearcoat, Exterior Paint & Trim 3 04-18-2002 08:14 PM
Cooking Forum - Sailing Forum - Early Retirement - Airstream Trailer - Aquarium Forum - Royal Forum - Book Forum - Yoga Forum - Volkswagen Touareg Forum - Jeep Wrangler Forum - Whitewater Kayaking & Rafting Forum - Fiberglass RV Forum - U2 Forum
