Old 03-24-2005, 02:33 PM   #1
arodriguez60's Avatar
1959 22' Flying Cloud
1969 25' Tradewind
1983 34' Limited
fairview , New Mexico
Images: 85
sticky walls
I first want to say how very helpful this site has been for my husband and I(we are newbies).I had sticky walls and although I tried Simple Green, I found that Greased Lightning works great with much less elbow grease.I just sprayed it in and left it for a few minutes and used a sponge scrubber and wiped with a clean wet rag. smooth! Greased lightning can be found at Lowe's or Walmart.Again thanks for you great info-Tamara
P.S. We found our 73 Safari in pretty decent shape, but needs a few things, like tambour repairs and the nasty carpet needs to go.I can't wait to go out in soon.
arodriguez60 is offline   Reply With Quote
Old 03-24-2005, 02:50 PM   #2
silver 67's Avatar
1967 30' Sovereign
Leavenworth , Kansas
Talking
Once you get them "unsticky", don't forget to give them a couple coats of Future floor wax. Makes them beautiful and the dirt and grime doesn't "stick".
Good luck with your "new home".
Beth and/or David
67 Sovereign, double bed, rear bath-"Moby"
2005 Dodge Ram 2500 Hemi, Quad Cab-"Ahab"
"Vintage trailer, vintage owners"
silver 67 is offline   Reply With Quote
Old 03-24-2005, 03:03 PM   #3
1969 25' Tradewind
1983 34' Limited
Images: 85
I tried to find Johnsons floor wax, does't seem like anyone here carries it ,but did'nt know if others would do it, thanks for the info-I am for anything that makes less "house work".
Old 03-24-2005, 03:04 PM   #4
balrgn's Avatar
1974 27' Overlander
1954 26' Romany Cruiser
1960 26' Overlander
Rockingham County , New Hampshire
Images: 74
Send a message via AIM to balrgn Send a message via Yahoo to balrgn
Welcome and good luck with your project.
'74 Overlander (T-O-Bee)
'46 Spartan Manor (Rosie)
'54 Cruiser (Bogart)
'60 Overlander (Hoagy)
WBCCI 1754 - AIR # 6281
www.balrgn.com
balrgn is offline   Reply With Quote
Old 03-24-2005, 04:13 PM   #5
Moderator Emeritus
overlander64's Avatar
1964 26' Overlander
1978 Argosy Minuet 6.0 Metre
Anna , Illinois
Images: 183
sticky walls
Greetings arodriguez60!
Welcome to the forums and the world of Vintage Airstream ownership!
Future floor wax is typically available in a number of places, but may not be on the shelves of the typical mass merchandiser. My local True Value Hardware store stocks it as does the local HWI Hardware store, and even the local ACE Hardware store stocks it - - the local Kroger Supermarket stocks it, but I couldn't find it on the shelves the last time I checked the Super Wal Mart and K-Marts in nearby cities. My local True Value Hardware store was able to special order the Johnson's Hardwood Floor wax that I needed when preparing my home for market so if you have a True Value Hardware store in your area chances are very good that they can get Future if they don't already stock the product.
Good luck with your coach!
Kevin
Kevin D. Allen
AIR #827
Old 03-24-2005, 04:48 PM   #6
1969 25' Tradewind
1983 34' Limited
Images: 85
Wink
Kevin
We have a Truevalue and an Ace, but I think our Wally world has Future wax,again thank-you all for a nice welcome to the forum-Tamara
Old 06-14-2005, 08:48 PM   #7
1990 34' Excella
Windcrest , Texas
Super Cleaner and Future Floor Wax
After reading this thread, I thought we had some 'crazies' running around here. But after giving our AS the treatment, I'm a total believer in it. We started with wiping the entire interior down with the Super Clean product and upon it drying promptly put on the future floor wax.
This was alot of work but the results are awesome. Other posters commented about needing 2 coats of future and that is true.
Mitch
Swanny is offline   Reply With Quote
Old 06-14-2005, 08:51 PM   #8
early's Avatar
Had great results with future floor wax. Our walls are smooth. Used two coats,also.
Dawn
early is offline   Reply With Quote
Old 06-14-2005, 09:41 PM   #9
It has been a year since I used the Future floorwax and mine is still smooth and shiny!
Anon is offline   Reply With Quote
Old 07-12-2005, 11:00 AM   #10
jaiman's Avatar
Images: 32
Has anyone done an adhesion test to see that the Future is still intact. Say after a year or at least a summer. My thought is that if the stickiness is a result of plastisizers leaching out of the substrate, could it be compromising the clear (future). A good way to test is, if you have strong finger nails is to really try and scratch it off in an inconspicuous area.
jaiman is offline   Reply With Quote
Old 07-12-2005, 11:11 AM   #11
juel's Avatar
1976 31' Sovereign
Chandler , Oklahoma
Images: 24
I peeled the vinyl wallcovering off my bath sliding door and painted over the sticky stuff with two coats of BullsEye shallac. It is no longer sticky and looks beautiful. I used Marine Clean to clean the ceilings and walls of the Argosy and the difference is amazing. There is no longer any sticky feeling. I recovered the back wall with vinyl wall covering after taking off the old with a heat gun. It looks very, very good now. The wood on the walls was not the quality of the wood on the sliding door, so that's why I recovered them.
juel is offline   Reply With Quote
Old 07-12-2005, 02:59 PM   #12
TomW's Avatar
1967 26' Overlander
Huntsville , Alabama
Originally Posted by jaiman
Has anyone done an adhesion test to see that the Future is still intact. Say after a year or at least a summer. My thought is that if the stickiness is a result of plastisizers leaching out of the substrate, could it be compromising the clear (future)...
Reading jaiman's post, I thought I would toss out a bit of detail picked up from another list:
Originally Posted by Deborah B.
The stickiness on the vinyl interiors is caused by plasticizers added to the vinyl polymer. They were intended to add flexibility to the polymer, but with age they migrate out to the surface. This is very common and you see it in all sorts of aging plastics - look at old purses and go-go boots at a yard sale. You can find a solvent that will remove the plasticizer from the surface but the process will continue and the stickiness will return until all of the plasticizer is gone. At that point the vinyl will become brittle and you may see some damage to the vinyl, such as cracking, flaking or powdering. I'm not sure what coating the vinyl, as Forrest does, would do - perhaps this would slow down the migration process by protecting the vinyl from air. But the process might continue under the coating, I'm not sure.
Tom
Old 07-12-2005, 04:27 PM   #13
We can tow it!
tin sista's Avatar
1996 28' Excella
Where the water tastes like wine , Michigan
Images: 82
Question Still sticky even with elbow grease
Hi,
Guess I didn't have much luck, tried both simple green and greased lightning. Used the scrubber and the future two coats--watch those fumes!!
Still sticky . Maybe I'll try the shellac next.
Steph
tin sista is offline   Reply With Quote
Old 07-12-2005, 05:10 PM   #14
Troubs Roady Emeritas
airstream6666's Avatar
1979 31' Excella 500
1974 27' Overlander
1974 27' Overlander
Livingston , Texas
Send a message via MSN to airstream6666 Send a message via Yahoo to airstream6666
Hi Steph!
Originally Posted by tin sista
Hi,
Steph
Hmmmm. Were your walls sticky after the cleaning step (simple green and greased lightening) but before the wax? Now any cleaning will have to remove the wax as well as the cause of the stickiness.
One product I have recently used as a replacement for my old favorites (commercial application cleaners with scary MDS sheets) is Rubbermaid Professional Plus Concentrated Orange Cleaner & Degreaser. This product is not to be confused with residential products, and should be treated with respect. Use rubber gloves and lots of ventilation.
It is sold at Walmart, but it is located among their other commercial products not their much larger display of stuff like Simple Green and the citrus-based weenie cleaners.
No scrubber pad (or scrubbing) required to clean an AS whose PO was a heavy smoker. Simply wipe walls and interior ceiling off with a paper towel (actually, lots of paper towels).
I would expect the coat of wax would make things a little more difficult, but I still don't know what else I might use.
airstream6666 is offline   Reply With Quote
sticky interior walls sovereign Upholstery, Blinds, Walls & Interior Finishes 64 08-14-2009 10:18 AM
Zolatone walls Rob Upholstery, Blinds, Walls & Interior Finishes 19 08-05-2009 06:54 PM
wood walls in an A/S? Dave Cole Upholstery, Blinds, Walls & Interior Finishes 26 03-10-2008 11:35 AM
Shower walls, what to do? myboyburt General Interior Topics 1 04-16-2004 03:54 PM
getting behind the walls... Chuck General Interior Topics 14 07-11-2002 12:20 PM
