Old 01-17-2013, 09:35 PM   #15
Registered User
ineedair's Avatar
Black Mt , North Carolina
Hi I am a cleaning lady by trade and "awesome" works awesome and is evry cheap. Dawn
ineedair is offline   Reply With Quote
Old 01-17-2013, 10:28 PM   #16
mefly2's Avatar
2015 25' FB Eddie Bauer
... sometimes referred to as mouse fur ??? ...
Old 01-18-2013, 12:25 AM   #17
Mexray's Avatar
1978 28' Ambassador
Morada , California
I think we tried all those 'solvents/cleaners' mentioned above without any great results... too many applications, too much rubbing, brushing, etc., without removing all the 'sticky' stuff...
Then an Airforums member suggested 'POR-15' cleaner - I got a couple of jugs, diluted it as per their info, and it WORKS GREAT...
Apply with spray bottle - with plenty of ventilation - wipe off the sticky crud with paper towels... Then rinse with plain water...
When done, and the surfaces are dry, apply some acrylic floor polish to seal, as mentioned above...
POR-15 requires no special brushing, scrubbing, etc - apply with a circular rubbing motion is all that's needed, in our 78 Ambassador, that is...
Believe me, nothing works as great as the POR-15 - it's not caustic, but you'll need plenty of ventilation so the fumes don't get to you...
Ray & Pat; Morada, CA
Old 01-18-2013, 05:33 AM   #18
77 R GO C MH's Avatar
1977 28' Argosy 28
Lincoln , Nebraska
The easiest and cheapest cleaner is odorless mineral spirits.
77 R GO C MH is offline   Reply With Quote
Old 04-07-2018, 05:38 PM   #19
Jenniflow's Avatar
1982 34' Limited
1986 34.5' Airstream 345
Sausalito , California
Send a message via Skype™ to Jenniflow
for sticky plasticizer on walls use Goof Off and rotary brush
Originally Posted by dwightdi View Post
I was a vinyl compound developer for years. The sticky stuff is the degraded plasticizer and the secondary stabilizing plasticizer. Moisture and heat will help it spew. Clean the walls and use acrylic sealer, like Future, to seal in future spew. It does make the walls have a little higher gloss.
I have been around the block on this in Mexico where it's not easy to find the toxic cleaners. The best I've done so far is to use Goof Off and a medium grade rotary brush on my drill. And thanks so much for your comment here, dwightdi, it's much more than just cooking oil or tobacco stains, it's an intrinsic feature of the plastic and it doesn't get gone easily!
sent from my hipflask
Jenniflow is offline   Reply With Quote
Vinyl (we think) ceiling odor? Skater Upholstery, Blinds, Walls & Interior Finishes 14 07-27-2015 01:17 PM
How to protect interior walls after stripping the vinyl? Mrs.S Upholstery, Blinds, Walls & Interior Finishes 3 10-31-2011 09:25 PM
Roll Vinyl vs. Vinyl Tile in Bathroom? Roadrunner Repairing/Replacing Floor &/or Frame 6 09-29-2011 07:23 AM
Creating Light Strong Walls beyond General Interior Topics 10 08-08-2011 06:04 AM
grease reapearing on walls? turfclubroad Upholstery, Blinds, Walls & Interior Finishes 6 04-04-2011 09:02 AM
