Old 10-21-2019, 07:59 AM   #1
1972 23' Safari
Middletown , Rhode Island
Stick on tile over zolatone?
Anyone use stick on tiles over zolatone? Im planning on adding a backsplash in my kitchen/galley area. If yes did anyone use gorilla glue or contact cement for extra support? Thanks.
Mx468 is offline   Reply With Quote
Old 10-26-2019, 02:09 PM   #2
InsideOut's Avatar
1956 22' Safari
Conifer/Evergreen , Colorado
Images: 108
#1 - I don't think your 1972 has Zolatone. Zolatone is a speckled epoxy paint. Airstream stopped using Zolatone in the mid-sixties.
I'm pretty sure your 1972 has vinyl wallcovering on the walls, which tends to "off-gas/deteriorate" and become tacky after 40+ years.
#2 - Regardless, tiles probably wouldn't stick well to either surface with Gorilla Glue - that's a better adhesive for porous materials and clamped.
#3 - The basic adhesive on "stick-on tiles" is probably not strong enough to withstand the vibration and temperature swings of a trailer. And may react with the off-gassing vinyl.
#4 - If you were determined to glue on tiles, Liquid Nails or a silicone-type glue would probably be better. But the surface must be very, very clean first.
Shari
RMVAC | WBCCI DenCO Unit | BIRDY - our 1956 Safari | 1964 Serro Scotty
To Zolatone or Not to Zolatone jonplayers Upholstery, Blinds, Walls & Interior Finishes 7 07-18-2017 04:50 PM
Wall carpet replaced with stick on metal tile HeikeET Interior Restoration Forum 2 09-08-2016 10:39 PM
Original Zolatone or New Zolatone - Value judgement? robwok General Interior Topics 1 12-05-2014 10:34 AM
Cork Tile Peel and Stick Flooring lubbockgolf Interior Restoration Forum 4 04-15-2011 12:50 AM
Why not latex over zolatone? Stefrobrts Upholstery, Blinds, Walls & Interior Finishes 6 05-28-2004 10:47 AM
