Old 02-26-2009, 02:25 AM   #1
2010 27' FB Classic
N/A , Texas
Spider Solution Needed, Please Help!
Not sure where to post this but here goes. After my trailer sat in storage for a little over a year, a while back, I found that some black widows made there home in it. I had to use a fogger to make sure I killed them all before using it again. then I aired out the unit for several days. Since that happened I now put the trailer in storage and I bag up everything in the trailer in plastic storage bags and stack the stuff on the floor so if I need to fog the area again it will be easy to remove the contents and I know there won't be any crawling friends in the stuff. Now finally to my question; if I put moth balls around the inside of the trailer will that help keep those nasty spiders out? The trailer is sealed up on the outside as much as possible but somehow they still managed to get inside and set up camp.
Old 02-26-2009, 02:50 AM   #2
Gainesville , Florida
My pest control person for my home will also spray my AS if asked. jim
xrvr is online now   Reply With Quote
Old 02-26-2009, 04:19 AM   #3
Steve & Susan's Avatar
2005 28' International CCD
Willoughby , Ohio
Black Widows aren't an issue in these parts, but Brown Recluse are.
We use moth balls over the winter and so far so good - no spiders in the spring. We put them in all of the access points (back of fridge, water heater, storage compartment, furnace, etc.). I've seen some folks sprinkle them liberally throughout the TT. The odor airs out relatively quickly in the spring with open windows.
There is also a natural repellant that many folks around here use - the fruit of an osage orange tree is used in basements of homes to repel spiders. I don't know if this is a good remedy for a TT in winter storage unless you can check it every few weeks to make sure the fruit isn't rotting.
Best of luck - I'm a backpacker and we make sure to look for those little beasties when hiking out west.
Steve & Susan
WBCCI# 03876
AIR# 6511
2005 28' CCD, 2011 Sierra 5.3L, Equal-I-Zer
Empty Nesters - spending our money on OURSELVES for a change!
Steve & Susan is offline   Reply With Quote
Old 02-26-2009, 07:14 AM   #4
More than one rivet loose
thecatsandi's Avatar
Keymar , Maryland
Originally Posted by Bluto View Post
Not sure where to post this but here goes. After my trailer sat in storage for a little over a year, a while back, I found that some black widows made there home in it. .
You are going to need to check your refrig, hot water heater and furnance for dead spiders and webs. They love the smell of propane.
Michelle TAC MT-0
Sarah, Snowball
Old 02-26-2009, 07:40 AM   #5
HowieE's Avatar
Princeton , New Jersey
Images: 12
I use moth balls to keep spiders from nesting in the burner tube of the refrigerator. But rather than just sprinkle them around loose I put them in a seal able plastic bag and then poke 20 or so holes in the bag with a pin. Moth balls left in the open will vaporize quite fast and not last through my winter storage period. However contained in the bag the vaporization is slowed down but still releases enough odor to do the job.
For the interior of the trailer I would try several bags of moth balls spotted around.
Keep in mind that the temperature in Texas will accelerate the vaporizing of the moth balls and a second application may be necessary during the storage period.
2004 Excursion 4x4
Old 02-26-2009, 08:46 AM   #6
INSANITY CENTRAL
doorgunner's Avatar
1986 32' Excella
2014 Interstate Ext. Coach
Citrus Heights , California
Images: 35
We have black widows here and whatever else the wind blows to the trailer.
I get dog flea collars and cut them into 2" pieces and put them in the bottom of the window sills, in the water heater area, fridge area and outside compartments. Been doing it for 3 years now and so far so good. but spiders are hard to control seeing as they move around.
I've noticed since I've used the flea collars that my eyes are buggin out, rash all over my body and knobs developing on my neck, not.
www.popasmoke.com
Proud Appellation American
Vine View Heights is now closed.
YETI ( 65 Quart )
IGLOO (Ice Cube, 50 Quart )
doorgunner is offline   Reply With Quote
Old 02-26-2009, 08:54 AM   #7
wbrownrr's Avatar
2002 22' International CCD
San Luis Obispo , California
Hmmm... dog flea collars. Think I'll try it for our spider problem. Thanks!
Wayne
2002 22' CCD
2008 Dodge Ram 1500 5.7L Hemi
wbrownrr is offline   Reply With Quote
Old 02-26-2009, 09:37 AM   #8
FreshAir's Avatar
1966 24' Tradewind
Placerville , California
We get many spiders. Moth balls when the trailer isn't in use works. Airing out the coach for use is fast. Our home, however, is another issue. We may just move into the trailer.
Yes, I have seen doorgunners knobby neck. But if you mention that to him his eyes bug out.
Neil
Neil and Lynn Holman
FreshAir #12407
Avatar;
1966 Trade Wind
455 cid
1969 Oldsmobile Ninety Eight
455 cid
Old 02-26-2009, 01:50 PM   #9
2010 27' FB Classic
N/A , Texas
You guys are good. I'm still laughing about the flea collar effects on doorgunner.
Thanks everyone for the help with this problem. I bought the mothballs and will spread them around in various places in the unit. It's 87 degrees here right now, so I know those spiders will be looking for a nice dark cool spot to call home. I never thought about flea collars. Might try that also. In the trailer, of course!
Old 02-26-2009, 06:53 PM   #10
Wabbiteer's Avatar
1972 29' Ambassador
St. Paul , Minnesota
There is an aerosol spider killer that targets arachnids and persists for six-months. I use it to keep the indoor cobweb builders from covering basement windows too rapidly and defeat the scary buggers in the hidey hole places I may need to be once a year...
It's made just for spiders and by the directions just coat stuff lightly and that's that. It is a slender tall aerosol can & I can't put my fingers on the can ATM to retrieve the brand & active ingredient.. If I find it like I want to I will post back.
Old 02-26-2009, 08:27 PM   #11
1950 Flying Cloud 7039
FC7039's Avatar
1950 21' Flying Cloud
Allen , Texas
Leave the spiders alone. You will be healthier and all other things will too if you just let them be. If you have too scoop them up on a piece of paper and toss them outside.
FC7039 is offline   Reply With Quote
Old 02-26-2009, 08:53 PM   #12
FreshAir's Avatar
1966 24' Tradewind
Ah, you sound like my late mother, bless her. She would spend a great deal of time 'shooing' flys from the house. I suppose I inherited some of that......until I became very ill a few years back. I thought that I had a severe flu and after a few days of no change in my fever my wife took me to emergency where a spider bite (Recluse maybe) was found on my lower calf. The doctor removed a lot of dead tissue. Now I squish spiders. Our daughter has severe reactions to spider bites and when she visits with our grandsons I try to clear (not round up) out spiders.
Neil
FreshAir #12407
Avatar;
1966 Trade Wind
455 cid
455 cid
Old 02-27-2009, 05:12 AM   #13
centennialman's Avatar
2016 20' Flying Cloud
Centennial , Colorado
I have one rule that I stick to:
If the spider is outside, it's his home and I leave him alone. If he comes inside, it's my home and he is doomed...or, in the case of black widows (she is doomed).
Steve "Centennial Man"
centennialman is offline   Reply With Quote
Old 02-27-2009, 08:40 AM   #14
FC7039's Avatar
Allen , Texas
Spider Myths: Home
spider corrosion under the plastic coat.. safari25-05 Clearcoat, Exterior Paint & Trim 1 01-19-2009 11:16 AM
A Sewer Solution.... Solution FreshAir Waste Systems, Tanks & Totes 15 09-29-2007 10:23 AM
dry camping toilet solution help needed wheel interested Our Community 2 12-26-2004 10:56 AM
Sewer Solution Craftsman Waste Systems, Tanks & Totes 4 09-12-2004 09:04 PM
What's a Google Spider? Rog0525 Our Community 4 06-08-2004 08:15 AM
