Old 02-27-2009, 08:55 AM   #15
Melody Ranch's Avatar
1956 22' Flying Cloud
1953 32' Liner
1955 22' Safari
Valley View , Texas
Images: 78
now you've done it....
After reading that I have the heebie jeebies.
Old 02-27-2009, 10:02 AM   #16
USN/LAPD Retired
Safari-Rick's Avatar
North Las Vegas , United States
I submitted a resolve earlier last year on spiders that was presented on television due to the skin reaction by humans on some of the sprays and chemicals used to kill the 8 leg pests.
Answer: Downey Softener sheets. They work great and don't smell like moth balls! I haven't had a black widow or any spider problem since. they last for about 3 months inside. I stick them in the floor near the door, and any openings (like inside the closet/floor where the water pump is).
Also, a little off topic..... to keep mice out, use stanless steel pads and stuff them in the tube opening (under the hitch) so those little critters can't make a home.
Just saying......
Safari-Rick
2007 Dodge Ram Quadcab 6.7L Diesel w/jakebrake
"Better to have more then you need, then need more then you have because you don't have enough!"
AIR #: 8129
Safari-Rick is offline   Reply With Quote
Old 02-27-2009, 11:46 AM   #17
2010 27' FB Classic
N/A , Texas
I heard that Bounce is good to keep black flies away when tucked under the collar of your shirt or in the outside hat band of your hat when canoeing so maybe Downey will work with spiders in the trailer. I think I'll use all three things, moth balls, pieces of flea collars and softner sheets in various places. I'll probably have to air the thing out for a week before I'll be able to live in there myself.
One thing I won't do is keep spiders around as pets.
Old 02-27-2009, 12:34 PM   #18
345bill's Avatar
Las Vegas , Nevada
Bluto- HedgeApples may be your answer. There's a post here titled, Spiders in my Argosy, by wanderer1, with alot of replies in the favor of HedgeApples to keep spiders out. Check it out.
345bill is offline   Reply With Quote
Old 02-27-2009, 12:36 PM   #19
Gainesville , Florida
Spiders suck! jim
Old 02-27-2009, 12:58 PM   #20
Steve & Susan's Avatar
2005 28' International CCD
Willoughby , Ohio
I always wondered - what exactly is a jeebie?
And is the Heebie part of the jeebie or does it describe it?
Steve & Susan
WBCCI# 03876
AIR# 6511
2005 28' CCD, 2011 Sierra 5.3L, Equal-I-Zer
Empty Nesters - spending our money on OURSELVES for a change!
Steve & Susan is offline   Reply With Quote
Old 02-27-2009, 04:48 PM   #21
2010 27' FB Classic
N/A , Texas
Thanks for telling me about that thread. Sounds like there are a lot of us with this problem. I have seen the apples but never knew what good they were. I'll check into it further. I thought that the idea someone had about spraying around the tires and jack post might help too.
spider corrosion under the plastic coat.. safari25-05 Clearcoat, Exterior Paint & Trim 1 01-19-2009 11:16 AM
A Sewer Solution.... Solution FreshAir Waste Systems, Tanks & Totes 15 09-29-2007 10:23 AM
dry camping toilet solution help needed wheel interested Our Community 2 12-26-2004 10:56 AM
Sewer Solution Craftsman Waste Systems, Tanks & Totes 4 09-12-2004 09:04 PM
What's a Google Spider? Rog0525 Our Community 4 06-08-2004 08:15 AM
