01-16-2010, 07:18 PM
1976 31' Sovereign
portland
, Oregon
Specs? Blue Prints? What lies beneath the floor...
Hi-
Anyone know if blueprints of airstreams exist? We're pulling out the rotted floor, the screws are rusted out, so we (i.e., my husband) has been dabbaling with the saws-all. Yes, feel free to roll your eyes, we (he) sawed through a water tank (which we might have decided to replace anyway...)
Also, if anyone would like to suggest the best threads on replacing the floor, that would be great. I'm doing a search, but sometimes you miss the best convo's that a venerable member might recall.
Thanks in advance!
We're gutting a '76 Soverign down to the "studs". Good times.
01-16-2010, 07:46 PM
Not much resides beneath the floor but your tanks. It's not uncommon to find all kinds of nasty things under the floor so be prepared.
Best of Luck,
Kevin.
William C. Swinney
01-16-2010, 07:54 PM
Port Hadlock
Many of the really good renovation threads are linked here: http://www.airforums.com/forums/f44/...ons-35399.html
When searching, I find using Google directly works the best. Try something like "site:airforums.com subfloor replacement" directly in Google and you'll get many hits.
I used a circular saw set to just slightly less than the thickness of the plywood. No damage that way. Then, a one inch hole saw can cut down over the tops of the elevator bolts and the pieces of floor will come right out. That's in my thread and blog below, but there are better threads.
And, welcome to the forums. Read, read, and reread and you'll learn so much.
01-16-2010, 07:55 PM
2008 27' International FB
Venice
Good luck with your project. I will be watching your thread in regards to the wiring. Where are they all and were do they go??
Bill
01-16-2010, 09:53 PM
1976 31' Sovereign
portland
, Oregon
Super helpfull!! I love the hole saw idea!!!!!!
01-16-2010, 10:18 PM
Corona
Originally Posted by mrsdinapoli
Hi-
Thanks in advance!
A service manual is available for your 76 31'.
It does not give dimensions, but it does tell you about all the systems, including photo's, as to how to repair, or replace the whatevers.
01-18-2010, 10:48 PM
1948 16' Wee Wind
1964 26' Overlander
2007 19' Bambi
crossville
, Tennessee
once floor board are out a die grinder with cutting wheel and needle nose vise grips work well for removing rusted elevator bolts. don't forget eye protection and a spray bottle of water will help wwith the minor fires .
