Old 01-24-2006, 09:35 PM   #1
RichardT's Avatar
Special screws with hourglass shaped center.
I have some screws in two Airstreams, a 1963 and a 1964 that I cannot find a screwdriver bit to use on them.
They have a hold unlike a Flat or Phillips head and not a star square or torx, it is like and hourglass.
I have went to every auto parts store and both Home centers with no luck finding the tool I need.
They are on every window crank and latch on the 64 and I am sure they are original, they are holding the table base on the 63. What are these called and where can I find a suitable bit?
Thanks in advance.
RichardT
RichardT is offline   Reply With Quote
Old 01-24-2006, 10:04 PM   #2
RichardT's Avatar
Figured out they were called clutch head screws.
Here is a picture. http://www.retiredtractors.com/Q/JDHeritage/Driver.html
http://www.sizes.com/tools/screw_drive.htm I will grind down a flat head to remove them.
Old 01-25-2006, 04:47 AM   #3
Retired Moderator
john hd's Avatar
1992 29' Excella
madison , Wisconsin
Images: 40
richard,
i have a set that i no longer need. they were for a 46 chevy project i sold.
contact me if you are interested...
john
you call them ferrets, i call them weasels.
Old 01-25-2006, 04:54 AM   #4
norbert's Avatar
1993 30' Excella
chicagoland , north of cheddar curtain
Images: 24
i take it that this elvolved into a robertson?
norby
Illegitimous noncarborundum(dont let the bastards wear you down)
The only true nobility is found through giving good food to your friends- Anton Careme
beauty is in the eye of the beerholder-cosmo fishhawk
if something is too good to be true, its usually gone before i get there-mister boffo
norbert is offline   Reply With Quote
Old 01-25-2006, 08:44 AM   #5
Darol Ingalls's Avatar
Clutch head screws are an automotive fastener. Robertson (square drive) are a construction fastener. Bits for both can be obtained from Snap-On or Mac tool dealers. Good industrial tool suppliers should also have then. Like the Star drive screws, clutch heads were an attempt by the auto makers to prevent tampering by owners and forcing them back to the dealers. They have since given up on that and now frustrate us by mixing metric and english sizes in their vehicles! Darol
Darol Ingalls is offline   Reply With Quote
Old 02-19-2006, 06:47 PM   #6
volvophile's Avatar
colorado springs , Colorado
Images: 14
Aces hardware has them
I was able to find the clutch head driver at my local Aces hardware in thier RV section for around $7.
One thing I found with these goofy screws is that they are almost impossible to strip out. I was able to get a good hold on all the clutch head screws that are under my '63 avion and covered in road crust and rust.
Normally though, whenever I remove a clutch head, I replace it with a stainles steel philips head.
volvophile is offline   Reply With Quote
Old 02-19-2006, 07:15 PM   #7
RichardT's Avatar
I was able to find one at a local mom and pop hardware store for $1.85 just the other day.
I will most likely not reuse the screws.
Richardt
Ever toured the Jackson Center plant? KY Girl Our Community 21 11-17-2002 10:04 PM
Screws... Chuck Ribs, Skins & Rivets 1 10-21-2002 08:22 AM
Clutch head screws Zed2 Windows & Screens 4 08-23-2002 05:16 PM
Center folding bed attachment uwe Cabinets, Counter Tops & Furnishings 6 06-30-2002 08:01 PM
front couch for 31 soverign center bath jim c taylor General Interior Topics 0 04-12-2002 03:58 PM
