Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Interior Restoration Forum > General Interior Topics
Old 09-15-2004, 03:11 PM   #1
Patriotic
Chuck's Avatar
1973 23' Safari
Images: 260
speaking of "Duct Tape"....
the face-plate of my control panel has been loose, and the clock and thermometer are not well secured, so I browsed through my trusty service manual to see what it was all about. Seems that the faceplate is secured with double-stick mounting tape. there's a diagram in the manual describing how everything is held together, and they use the term "furnace tape" ...apparently, this is what is supposed to hold the clock and thermometer in place. never heard the term "furnace tape" before...are they talking about plain ol' duct tape?
Air:291
Wbcci: 3752
'73 Safari 23'
'00 Dodge Ram 1500 4x4 QC
Old 09-15-2004, 04:39 PM   #2
Janet H's Avatar
1964 19' Globetrotter
OlyPen , Washington
Images: 101
Duct tape and furnace tape are different critters. Furnace tape can be used in higher temps - duct tape cannot. The adhesive on duct tape becomes soft and then, over time, brittle. When it finally fails, it leaves a nasty residue. Find something else to use.
AirForums Custom Search
Old 09-16-2004, 07:29 AM   #3
Patriotic
Chuck's Avatar
1973 23' Safari
Images: 260
well, this isn't a high temperature application, to say the least. I've just never heard of the stuff. wonder where you can get it? what's it look like?
Air:291
Wbcci: 3752
'73 Safari 23'
Old 09-16-2004, 08:35 AM   #4
Hi, Chuck
I experienced the same problem on my unit some years back. I used picture hanging tape (two-sided with the correct amount of thickness) to put it back together that lasted seven years before I sold the unit.
I think a permanent fix could be to use very small machine screws in combination with plastic screw head covers. You can buy the covers in differenct colors (I have used brown and white) to suit your taste.
Rick
Rick Alston is offline   Reply With Quote
Old 09-16-2004, 06:23 PM   #5
Retired Moderator
john hd's Avatar
1992 29' Excella
madison , Wisconsin
Images: 40
chuck
3 M auto trim tape would be a good choice.
we used it on rickstreams front window on his excella, i swear you wouldn't need any rivets to hold it in! very sticky!
john
Old 09-17-2004, 08:24 AM   #6
JohnG's Avatar
Originally Posted by john hd
chuck
john
Plus it is suppose to have a service life of 25 years. Sounds like it would do the job to me too.
Just adding my 2¢ worth
John G
___________________________
1975 31ft Sovereign International
........Rear Bath Double Bed Model
Tow Vehicle:1999 GMC Serria SLE Classic 1500 5.7Ltr
System: Jordon 2020 Ultima Brake Controller
Hook-Up: Equalizing Hitch and Sway Bar
JohnG is offline   Reply With Quote
Speaking of Stripes and Decals smily Clearcoat, Exterior Paint & Trim 21 10-31-2003 07:42 AM
Speaking of hitch balls Ken J Hitches, Couplers & Balls 11 10-18-2003 09:09 AM
speaking of towing with a car... Chuck Tow Vehicles 52 05-20-2003 11:51 AM
speaking of something old jpurdy Our Community 2 12-17-2002 06:07 PM
