Old 09-13-2006, 08:12 PM   #1
gaylejoe's Avatar
2007 25' Safari FB SE
St. Hedwig , Texas
Smile Source for moulding trim
I am looking for a source for moulding trim for my 77 Argosy. I have tried several retail sources without success. The moulding in question is very small.
gaylejoe is offline   Reply With Quote
Old 09-14-2006, 12:07 AM   #2
CaddyGrn's Avatar
1963 16' Bambi
Yreka , California
Moulding
Howdy,
I asked a similar question a while back. Got several answers. Here is the thread:
http://www.airforums.com/forum...light=moulding
You might also use the search tool at the top blue toolbar, and key in the word moulding. You will see all the different threads that have the word moulding in it. Might have to hunt awhile, but you will surely find places to check out!
I would post a picture of what you have, especially if you want to replace with similar stuff. It will help you get answers!
Good luck!
Mrs. NorCal Bambi (traveling in S Tardis)
CaddyGrn is offline   Reply With Quote
Old 09-14-2006, 03:49 AM   #3
balrgn's Avatar
1974 27' Overlander
1954 26' Romany Cruiser
1960 26' Overlander
Rockingham County , New Hampshire
Images: 74
Send a message via AIM to balrgn Send a message via Yahoo to balrgn
Inside or outside?
'74 Overlander (T-O-Bee)
'46 Spartan Manor (Rosie)
'54 Cruiser (Bogart)
'60 Overlander (Hoagy)
WBCCI 1754 - AIR # 6281
www.balrgn.com
balrgn is offline   Reply With Quote
Old 09-16-2006, 01:26 PM   #4
gaylejoe's Avatar
St. Hedwig , Texas
The moulding is for the inside of the trailer.
Old 09-16-2006, 01:39 PM   #5
CanoeStream's Avatar
St. Cloud , Minnesota
J-trim is the thin plastic that protects sheet metal edges on the interior. It gets brittle and breaks away. Replacing it involves removing & replacing some pop rivets (available at local hardware stores or Home Despot). You'll need to cut the hidden part every couple inches to make the curve around the front windows.
Insert nosing is the approx 1" wide plastic that fits inside the extrusions you find back in your bathroom. If the fit is too tight sand the corners on the insert nosing and maybe backside, then use silicone spray to assist with sliding it in. Don't force if still too tight. Getting access to the extrusion end may be quite a job!
Both are available at Oasis RV in Tucson. Call and talk to their parts department. They are very knowledgeable, helpful and efficient in understanding what you want. Their prices are among the best around. I had what I wanted in Minnesota within 3-4 business days!
5 meter Langford Nahanni
Aluminum Trim Source? melprice Cabinets, Counter Tops & Furnishings 6 09-08-2009 06:19 PM
blue trim molding larry smith Clearcoat, Exterior Paint & Trim 83 12-07-2003 11:04 AM
Exterior Blue Vinyl Trim Danno Clearcoat, Exterior Paint & Trim 5 06-29-2002 04:15 PM
Grey trim on the ouside of '61 Bambi windows 61BambiCanada Windows & Screens 1 05-21-2002 11:48 PM
Exterior trim ALANSD Airstream Motorhome Forums 1 04-14-2002 07:53 PM
