Old 03-06-2015, 02:05 PM   #1
2015 25' FB Flying Cloud
Bellevue , Washington
Sofa/Pull Out Bed - Make More Comfortable?
We have a 2014 25FB Flying Cloud. When we have anyone sleep on the sofa/slide out bed they usually complain of it not be very comfortable. Your hips tend to fall in the crack between the two cushions that make up the sofa/bed. It might have been better if the design called for one long cushion instead of two two cushions? Regardless, has anyone gotten the same complaint and found a solution that makes the sofa/bed a bit more comfortable to sleep on?
Thanks.
jreckin is offline   Reply With Quote
Old 03-06-2015, 02:45 PM   #2
2007 22' International CCD
Possibly add some straps with Velcro to hold the gap tighter?
I have similar issues with my dinette/bed setup. We won't talk about the tendency of the table top to slip off the seats. I'm going to put an air lift pedestal in place of the folding leg to locate it more accurately and prevent slipping. It's a bit crude at present.
KE4GNK/AE
Old 03-06-2015, 03:03 PM   #3
Wishing's Avatar
2014 27' FB International
Arlington , Virginia
This might sound overly complicated but we do this for our two smaller children who sleep on it: we bought a queen sized foam topper with its own padded zip up cover, and cut it to fit the width of the pull out bed. The cut off piece of foam topper that we trimmed off (one long strip) is placed on the slide out, under the long back cushion which makes up the pullout bed. The full-size foam topper is placed on top, securing everything with its own elastic cover that goes around all the cushions (holding everything in place). Then we add yet another full-size elasticized mattress sheet, along with the other bed linens.
Wishing is offline   Reply With Quote
Old 03-06-2015, 04:01 PM   #4
adonh's Avatar
1976 31' Sovereign
Missouri City , Texas
Thanks.
This is an age old problem that has not been corrected over the years. Bottom line they are uncomfortable to sit on and even worse to sleep on. There is no "Solution that makes the sofa/bed a bit more comfortable to sleep on". Sorry. Except to do what others have done including me with my 1976 31' Sovereign, take it out and install Recliners. But, you say, that does not make in to a bed. True but you spend more time sitting on them and they are so comfortable that you you can sleep like a log on them as well.
Here are some interior pics that include the leather wall away recliners that I installed a few years back.
Airstream Interior 2010.pdf
Don Hardman
1976 31' Sovereign
adonh is offline   Reply With Quote
Old 03-06-2015, 04:16 PM   #5
KJRitchie's Avatar
2008 25' Classic
Wichita Falls , Texas
If you are only sleeping one person take off the backrest and sleep on the cushion without pulling the tray out. A second peron can sleep in the converted dinette area. That's is how I sleep on it when the kid come with us and she and DW sleep in the front queen.
Kelvin
Old 03-06-2015, 04:54 PM   #6
Figment of My Imagination
Protagonist's Avatar
2012 Interstate Coach
This is actually a perennial problem for those of us who own an Airstream Interstate; our convertible sofa/lounges are notorious for having padding that's thin (or nonexistent) right where the sleeper's natural pressure points happen to be. The generally used solution is to add a pad on top of the cushions. I use a cot pad from Cabela's that I can roll up and use as a bolster when it's not in use to bridge across the less-padded portions of the bed. Other people use memory-foam toppers, but my apelike proportions (long torso, short legs) put my natural pressure points on the cushions rather than between them so I don't need quite as much supplemental padding.
WBCCI #1105
TAC LA-4
My Google-Fu is strong today.
Old 03-07-2015, 10:07 AM   #7
m.hony's Avatar
2013 30' Classic
Greenwood , Mississippi
I find sleeping in the gap between the cushions quite comfortable, but I generally don't even let the sofa out- I just sleep on the couch as a couch- give me a blanket and a pillow and I'm good to go-
2013 Classic 30 Limited
TAC #MS-10
Airforums #70955
Old 03-07-2015, 10:51 AM   #8
Zigidachs's Avatar
2011 30' Classic
Ridgefield , Washington
When our young grandchildren sleep on the sofa, there are no complaints. When we have slept on the pull out sofa while guests slept in our Sleep Number bed, WE had plenty of complaints.
We used a tempura type, 4" cover (Costco) which helped, but there is a slight "slope" or slant to the forward edge of the sofa. Three problems:...Where to stow the blasted topper?...(they take up an enormous amount of room even in the bed of a TV) and the process of setting up the bed and take down every night...a pain,,,,and lastly that cover is very heavy.
Real solution? I have no great answer. We kayak and often sleep in a tent with a quality air mattress on the ground ( of course) and the tent sleeping is far more comfortable than that dratted sofa!
Zigidachs is offline   Reply With Quote
Old 03-07-2015, 01:33 PM   #9
Hang a hammock over the sofa?
WBCCI #1105
TAC LA-4
Old 03-07-2015, 02:23 PM   #10
4Kilefamily's Avatar
2009 34' Classic
North Richland Hills , Texas
We use a Full size Colman Air Mattress with Full size sheets. Just blow it up and set it on top of the pulled out sofa. It folds up easily and you can adjust the firmness with air pressure.
No more falling into the sofa crack.
Sleep well and keep traveling.
4Kilefamily is offline   Reply With Quote
Old 03-07-2015, 02:30 PM   #11
terryV's Avatar
2002 31' Classic
Monroe , Iowa
How hard is it to take the sofa out? Is it bolted down?
terryV is offline   Reply With Quote
Old 03-07-2015, 02:36 PM   #12
cameront120's Avatar
1972 25' Tradewind
I use a feather mattress as a topper to the bench seats and find it very comfortable. You could also get a foam topper to do the same thing. I like the feather because it can be rolled up quite tightly and take up less space than the foam.
North Vancouver, BC
Old 03-07-2015, 04:03 PM   #13
S/OS #005
2004 28' Safari S/O
Georgetown , Ontario
Sofa bed
We have 2004 safari with a sofa; we purchased a double foam topper from costco & it makes the sofa very comfortable. We also did the same for the twin beds cutting the foam to fit and laying on top of the original mattresses. It is the blue gel foam toppers we have used.
JACQUIE is offline   Reply With Quote
Old 03-09-2015, 01:25 PM   #14
Thanks for all the ideas. We decided to go with a a fitted sheet to go over the cushion (holds them together) and a air mattress (ALPS Mountaineering Comfort Series Air Pad) on top of that. Thanks again.
Does anyone think the L shaped sofa is comfortable? Ntex Buyer Guidelines 16 11-27-2014 10:50 PM
How to make dinette seats more comfortable vakathy General Interior Topics 6 09-27-2014 03:49 PM
Sofa bed, dinette/bed, swivel chairs and fold out table Don Landis Argosy Motorhomes 9 09-07-2011 06:56 PM
Sofa bed, dinette/bed, swivel chairs and fold out table Don Landis General Interior Topics 0 04-21-2009 01:18 AM
