Old 08-30-2009, 08:56 AM   #1
2000 31' Excella
Maryville , Tennessee
Smokers smell ?
Hello, we are looking at a camper the owner says was occasionally smoked in.
The condition of the camper is supposed to be excellent inside and out.
I have no problem with this (I used to smoke years ago) as long as we can get the smell out if any.
I am affected by smokers smoke now but this would be different.
Does anyone have any experience with an AS smoked in ?
Will a fan on inside for a few hours take care of this ?
Robbie R.
Robbie R. is offline   Reply With Quote
Old 08-30-2009, 09:02 AM   #2
More than one rivet loose
thecatsandi's Avatar
Los Alamos , New Mexico
Robbie R.
Robbie,
A fan will not do it.
ALL surfaces will have to be cleaned at least once. All fabrics will have to be washed or you can try treating cloth with Fabreze. If the trailer has cloth walls you have a lot of work ahead of you.
Michelle TAC MT-0
Sarah, Snowball
Old 08-30-2009, 09:03 AM   #3
Vintage Alum. Enthusiast
flyfshr's Avatar
1959 24' Tradewind
Phoenix , Arizona
Images: 40
I believe you'll need more than a fan to remedy the smell that is more than likely left in all of the soft goods. "Occasionally smoked in" is probably more than occasionally. You'll need to wash the curtains, clean the carpet (if it has any) and thoroughly wash any other absorbing materials. Have you been in the trailer yet to determine the amount of lingering smell?
Best of luck.
FF
4CU 2699 / AIR 10 / TAC AZ-1
I'm haunted by aluminum.
flyfshr is offline   Reply With Quote
Old 08-30-2009, 10:41 AM   #4
bredlo's Avatar
1954 22' Safari
Deerfield , Illinois
Send a message via AIM to bredlo
I'd say even the Zolatone (or whatever painted surfaces there may be) may need a fresh coat. I've been in houses that smell like smoke years after the last cigarette was lit. Paint is porous, so a fresh coat of paint is usually one of the magic bullets that freshens things up. Good luck!
bredlo is offline   Reply With Quote
Old 08-30-2009, 10:42 AM   #5
Isadora's Avatar
1976 Argosy 24
Joplin , Missouri
If you can borrow, or rent an ozone generator it would really help. It has taken out the smoker's smell from a rental house that we own, and car dealers use them. Put one in the trailer and let it run for 24 hrs. But the one thing you have to know about this is that while it is running, no one can be inside with it as it takes the oxygen out of the air.
Jim and Sandy
"To know is nothing at all. To imagine, is everything." --Albert Einstein
http://chaosinature.blogspot.com/
Isadora is offline   Reply With Quote
Old 08-30-2009, 10:51 AM   #6
AZ-JH's Avatar
Peoria , Arizona
If tobacco odor was that easy to get rid of, the owner would simply have done so prior to showing it for sale.
AZ-JH is offline   Reply With Quote
Old 08-30-2009, 11:35 AM   #7
Isadora's Avatar
1976 Argosy 24
Joplin , Missouri
Not everybody knows about ozone generators. I only do because my daughter, who was a pet broker, used them on the puppy shipping vans. She has one that we used.
Jim and Sandy
Old 08-30-2009, 11:36 AM   #8
2000 31' Excella
What a bummer !
No I have not been in the camper yet to see if the smell is bad.
Thanks a lot for your help.
Robbie R.
Old 08-30-2009, 11:39 AM   #9
1963 24' Tradewind
San Diego , California
a friend of mine purchased a car that was smoked in . no amount of cleaning got rid of the smell!
Sixty3TW4US is offline   Reply With Quote
Old 08-30-2009, 12:02 PM   #10
AIR-Quarius's Avatar
1970 27' Overlander
Espanola , Full Timer
Send a message via Yahoo to AIR-Quarius Send a message via Skype™ to AIR-Quarius
Get an ionizer (room 'fan' type) like the motels use...we use one ...it is called a 'Peak 03 Air Purifier' ...works real good!
http://customrvdecalplus.com
AIR-Quarius is offline   Reply With Quote
Can non-smokers be happy in smoked-in trailer/towing vehicle gardener General Interior Topics 45 04-12-2010 06:20 AM
That Smell! I Know What It Is Now! whitefawn Leaks - Weatherstrips, Gaskets, Caulks & Sealants 12 03-09-2010 03:48 PM
Cookshack Smokers Airhog1 Stella's Kitchen 37 08-17-2007 03:27 PM
Smell!!!! jim8860 General Motorhome Topics 5 09-07-2005 07:59 PM
Smell garry General Interior Topics 8 05-09-2005 08:31 PM
