Old 07-30-2008, 06:47 PM   #1
davidz71's Avatar
1986 25' Sovereign
Southern Middle , Tennessee
Smoke Detector alarming with moisture?
I have a Kidde Kitchen smoke detector mounted within inches of my ceiling just before entering the side corner bedroom of my '86 Sovereign. It has the hush feature in case it alarms while using the kitchen appliances. It is marked 2004 and has only alarmed twice before. It did it once when the campfire smoke got rather thick and the fans pulled smoke in and then once when I was cooking something in the frying pan.
Lately I found it alarming early in the morning during a high humidity situation where it rained the evening before. I replaced the battery thinking maybe it was low. It did it several weeks later during the same high humidity situation early in the morning. There was heavy dew on the grass both times. Is the detector picking up moisture droplets that are being drawn inside the trailer and pulled past the detector on the way out the rear bedroom Fantastic Fan? I'm just curious if anyone has had a similar experience.
Craig
AIR #0078
3.73 rear end
Mag-Hytec rear diff cover
Amsoil synthetics all around
Old 07-30-2008, 08:41 PM   #2
reday's Avatar
2003 31' Land Yacht 30
Old Hickory , TN
Not sure what brand I have. Would go to the garage and check, but it's raining right now. It would be whatever AS was putting in 03 units. I have noticed that lately it starts chirping when someone has taken a shower. This is with shower vent exhaust going and the exhaust vent over the head going across the hallway as well. You would think this would keep moisture down???
Ralph & Margie Day
Lizzy the Borderline Collie
Old Hickory, TN
Between 'steams...
reday is offline   Reply With Quote
Smoke alarm keeps 'alarming'... TennisMan 2007 Safari SE 25 05-03-2009 08:51 PM
Best Battery operated CO and Smoke Detector RBolton Batteries, Univolts, Converters & Inverters 6 10-16-2007 05:20 PM
Smoke detector Ed L General Appliance Topics 4 05-14-2007 01:58 PM
CO smoke detector questions 63air General Interior Topics 9 04-15-2006 08:31 AM
Smoke Detector ViewRVs Airstream Motorhome Forums 7 09-02-2002 07:57 PM
