Old 06-01-2008, 10:25 PM   #1
gaylejoe's Avatar
2007 25' Safari FB SE
St. Hedwig , Texas
Smoke Alarm?
The smoke alarm in our 03 25' Safari seems a little sentisive. Anytime we use the stove top burners it will set off the alarm even though we have the vent hood fan turned on. Is there a way to adjust the sensitivity on the alarm?
gaylejoe is offline   Reply With Quote
Old 06-01-2008, 11:32 PM   #2
TBRich's Avatar
2006 19' Safari SE
Tucson , Arizona
Images: 64
I don't think they can be adjusted...ours goes off sometimes, too, so we usually turn on the Fantastic Fan in that area to help draw the air through...that helps in our Bambi...not sure it would in yours... We haven't done so yet, but we have talked about getting one of those plastic shower caps to snap over the detector when we are cooking...but remember to remove it when you're finished cooking!
TB & Greg and Abbey Schnauzer
#3954
Old 06-02-2008, 01:04 AM   #3
ROBERTSUNRUS's Avatar
Salem , Oregon
Images: 18
Hi, long story on another post, but if your smoke alarm has two buttons, one is the hush button. You can push the hush button in advance and it will silence the alarm for a short time [about seven minutes] but it will beep every 45 seconds until the time runs out. Or if the alarm goes off while cooking, just push the hush button to silence it long enough, hopefully, for the smoke to clear. [about seven minutes] Other than that they go off pretty easy because of the small area inside of your trailer. Do not disarm or remove it; It is there for your safety.
2005 Safari 25-B
"Le Petit Chateau Argent"
[ Small Silver Castle ]
YAMAHA 2400 / AIR #12144
Old 06-02-2008, 05:30 AM   #4
FreshAir's Avatar
1966 24' Tradewind
Placerville , California
I moved ours to the rear. It is probably better back there anyway as that is where we sleep.
Neil.
Neil and Lynn Holman
FreshAir #12407
Avatar;
1966 Trade Wind
455 cid
1969 Oldsmobile Ninety Eight
455 cid
Old 06-02-2008, 06:06 AM   #5
Bambi75th's Avatar
2007 19' Bambi
Los Alamos , New Mexico
The smoke detector in our 75th Anniversary Bambi wiould often go off when we cooked. We relaced it (under warranty thank goodness) and heve not had problems since. I guess some are just more sensitive than others. Good luck with yours.
Bambi75th is offline   Reply With Quote
Old 06-02-2008, 07:25 AM   #6
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
Ours was mounted directly over the cooktop area--at least we knew when supper was ready.
I moved it to the bedroom area as well, and now only have issues when the meal is very smoky.
Old 06-02-2008, 09:49 AM   #7
peegreen's Avatar
1998 31' Excella 1000
South Berwick , Maine
If a fire were to start in the trailer, where is the "most" likely place for it to start. I'm thinking around the stove, fridge, furnace and hot water heater, although I guess it could be anywhere. I would want the smoke detector in the nearest location with the greatest probability for a fire starting for the earliest warning. My '89 had one up front and the rear. The '98 has one only in the front - I was surprised. Push the hush button and deal with it.
WBCCI 24291
New England Unit
Metropolitan NY Unit
peegreen is offline   Reply With Quote
Old 06-02-2008, 10:15 AM   #8
Ready-to-Travel
pmclemore's Avatar
2012 30' International
Walkerton , Virginia
What we do is open the window opposite the stove and turn on the ffan. That sets up a good clear air flow that gives the smoke detector clean air to test.
Pat
pmclemore is offline   Reply With Quote
Old 06-02-2008, 10:17 AM   #9
Always Airstreaming!
rickandsandi's Avatar
2005 22' Safari
1960 24' Tradewind
Anytown , Connecticut
Send a message via AIM to rickandsandi
The more sensative a smoke detector or anyof the other detectors in our AS the happier I am! Yes, ours will go off in the Safari when cooking; simple solution- I remove it from the ceiling and place it on my pillow. This way it is not being activated by cooking but with it on my bed pillow I remember to replace it before bedtime.
J. Rick Cipot
Sandi Gould
NEU New England Unit
Airstream Life Magazine
Proud Member of WBCCI
WBCCI #3411
AIR #17099
2009 Silverado 2500HD
2004 22' Safari
1960 24' Tradewind
rickandsandi is offline   Reply With Quote
Old 06-02-2008, 12:06 PM   #10
richinny's Avatar
2011 34' Classic
....not as tasty as a mint but very thoughtful!
Ricky
Smoke alarm keeps 'alarming'... TennisMan 2007 Safari SE 25 05-03-2009 08:51 PM
Furnace sets off smoke alarm silverback 2002 - 2005 International 37 11-12-2006 08:24 PM
Smoke detectors BillTex General Interior Topics 7 07-19-2006 10:28 AM
smoke alarm frederic.c01 Interior Restoration Forum 9 08-06-2004 10:39 PM
Smoke Detector ViewRVs Airstream Motorhome Forums 7 09-02-2002 07:57 PM
