Old 04-24-2009, 03:30 PM   #1
2009 34' Classic
Galveston , Texas
Slide Outs
I have been thinking of buying another Airstream to replace my 1996 34' Classic Limited. I am thinking about buying a unit with a slide out. A Airstream dealer in Arkansas said he does not sell units with slide outs because they cause problems. Any folks out there with slide out units that have an opinion one way or another?
Don in Galveston
donemerson is offline   Reply With Quote
Old 04-24-2009, 03:34 PM   #2
jcanavera's Avatar
2004 30' Classic Slideout
Fenton , Missouri
Images: 143
We love the slide out. No problems or issues that I have encountered. There is a weight penalty in that you have some fairly heavy hitch weights to deal with and for all intents a heavier trailer.
You do need to play by the rules. Only open the slide when the stabilizer jacks are down. Don't raise the stabilizer jacks until the slide is retracted. I use silicone on the seals about twice a year.
Obviously the dealer you talked to has had some bad experiences. I know the early slides back around 2001 had some seal issues and some trailers were retrofitted. I don't know how the slide outs in the Safari line performed but the Classics are pretty nice. It all depends a lot on how your previous owner treated their slide.
Jack
Jack Canavera
STL Mo.
AIR #56
Old 04-24-2009, 03:37 PM   #3
Colonial Airstream NJ
Colonial Airstream's Avatar
1968 17' Caravel
Lakewood , New Jersey
Images: 79
Don,
Thanks for the post. We love the slide-out model and had very few problems with them over the years, so nothing negative to post.
We just ordered the last two 2009 Airstream 34' Classic Limited S/O trailers. Below are links to two 34''s I have in stock one is a slide and one in a non slide. Hopefully you will enjoy the photos.
2009 Airstream Classic Limited 34' - Slide-Out Dinette
Colonial Airstream NJ - 2009 Airstream Classic Limited 34' Slide-Out Dinette
2009 Airstream Classic Limited 34' - Lounge
Colonial Airstream NJ - 2009 Airstream Classic Limited 34' Front Lounge
Patrick Botticelli - Colonial Airstream 1121 Route 88 Lakewood, NJ 08701 - 1-800-265-9019 www.colonialairstream.com
Colonial Airstream is offline   Reply With Quote
Old 04-24-2009, 03:42 PM   #4
jcanavera's Avatar
Fenton , Missouri
Images: 143
Patrick, it's interesting in that Airstream continues to put the 13.5 K AC unit in the 34' units. When I ordered my 30' slide out, I upgraded to the 15 K units. I never regretted that upgrade. Especially with the additional space a slide out gives you.
Jack
Jack Canavera
STL Mo.
AIR #56
Old 04-24-2009, 03:42 PM   #5
2009 34' Classic
Galveston , Texas
Thanks Jack
Cheers,
Don
Old 04-24-2009, 03:48 PM   #6
1968 17' Caravel
Images: 79
Jack
Jack I agree it is a no brainer. Every unit I have coming in has the upgraded a/c unit and every other 30'+ Classic Limited I add the 2nd a/c in the bedroom.
Old 04-24-2009, 03:51 PM   #7
jcanavera's Avatar
Fenton , Missouri
Images: 143
I've visited a lot of 34' non slide units with the single 13.5 unit in the Missouri heat and have never been impressed with the ability of that unit to hold temp when you get into the really hot weather. You are smart in adding the additional AC unit in the bedroom or ordering the upgraded 15K unit.
Jack
Jack Canavera
STL Mo.
AIR #56
Old 04-24-2009, 04:13 PM   #8
Wingeezer's Avatar
2005 30' Classic
Burlington , Ontario
Patrick,
I have a 2005 Classic 30 that I bought just last September. We haven't yet had any summer travel experience with it yet, but I'm suspecting the single
AC which I think is 13.5k may struggle to keep the bedroom cool.
Can you tell me if it is likely that this trailer would be pre wired for a bedroom AC unit? If not, is it very difficult to run the wiring?
Would I be right in thinking it would be installed over the vent where we now have a second Fantastic fan?
Thanks.
Brian & Connie Mitchell
2005 Classic 30'
Hensley Arrow / Centramatics
Old 04-24-2009, 04:49 PM   #9
moderator
Airslide's Avatar
2014 23' FB International
Wilton , California
Images: 50
Send a message via Yahoo to Airslide
Originally Posted by Wingeezer View Post
Patrick,
Thanks.
We love our 30 S/O. Its an early one and i did have to adjust the slide a bit to center it but no other issues. The frame is very beefy and the extra room really opens it up. The coach is heavy and my overall payload can be compromised easily but we are very happy with the decision to purchase this combination.
Vinnie
"Old fashioned service on your late model Airstream"
https://www.facebook.com/VinniesNort...ir?ref=tn_tnmn
Airslide is offline   Reply With Quote
Old 04-24-2009, 06:11 PM   #10
vswingfield's Avatar
1983 34' Excella
1967 24' Tradewind
Little Rock , Arkansas
Images: 32
Rivet 13,500 vs 15,000
Just about a year ago I relpaced the Coleman with a Carrier 15,000 Btu heat pump model. (http://www.airforums.com/forums/f427...ead-40795.html) In the full sun here in Little Rock, it struggles to bring the interior temp near the outdoor temp. Once the sun goes down, it cools off quickly.
Interestingly enough, the bedroom, which only has 3 windows, is the coolest room in the Excella even though it is the west end. Having the insulation on the corners really makes a difference. If I add a second AC, and it is under consideration, I will use a 13,500. With only the bedroom to cool, I should be able to hang meat in there. I've always wanted my own walk in refrigerator.
Vaughan
Old 04-25-2009, 07:40 AM   #11
1968 17' Caravel
Images: 79
Patrick,
Thanks.
Brian,
The bedroom in an 05 30' S/O Classic in not wired for a 2nd A/C. I have heard of folks going back to the factory and adding the 2nd A/C but from what I understand it was pricey.
Old 04-25-2009, 07:46 AM   #12
jcanavera's Avatar
Fenton , Missouri
Images: 143
The 15K Penguin unit on my 30' Slide has no problems in keeping the bedroom cool. If you close both doors that encompass the center bath, you are going to cut down air flow going into the rear bedroom. The doors don't completely cut off the airflow since there is a pathway above and below the doors for air flow to pass through.
Jack
Jack Canavera
STL Mo.
AIR #56
Old 04-25-2009, 08:00 AM   #13
Stream 1529's Avatar
2004 34' Classic S/O
San Antonio , Texas
We've had our 34' S/O for just about 6 yrs, and we love it. The only problem with our S/O was owner inflicted. I extended the slide when the trailer wasn't level side - side, and I sheared some pins. Pushing in the slide took two on the outside. Like Jack, I lubricate the seals on a regular basis.
Having 2 a/c's is a must. The 13.5 unit will not keep a 28', or larger, trailer comfortable in the summer. We experienced this in our first AS, a 31'. Blistering hot in South Dakota, and the unit blew out. I talked with the Dometic people and they told me that, in a 31', the small unit would cool the trailer to 10* less than the outside temps. Not good when it's 101 outside. They also said that the 13.5 would work effectively in trailers less than 28'.
Since I ordered our rig from the mfg, I was able to have them install a dome king sat receiver on the roof, and that has worked out well. The extra space from the slide is well worth the additional weight, in my opinion. The 2 a/c's mean the inside temp is 78-82 when it's 100+ outside.
______Tom
Blog: www.travelpod.com/members/wbcci1529
'04 34' Classic S/O lounge, dome king, twin a/c, faux fireplace to keep the wife warm , equa-li-zer, prodigy, 4 birds, dog - no kids allowed!
'05 Excursion 4x4, 6.0 PSD, magnaflow, helwig anti-sway, air lift springs.
Stream 1529 is offline   Reply With Quote
Old 04-25-2009, 08:07 AM   #14
ZoominC6's Avatar
Colleyville , Texas
Don, You'll love the S/O and if you're like most of us you'll have no problems with it at all. I ditto the 15K AC upgrade as it makes one heck of a difference in our 30 footer. I've also seen the 34s with two units and the owners swear by them. I believe the two units were custom built into the units and of course the electrical service went up from 30amp to 50amp. Leveling AND securing stabilizers prior to S/O extension are a must as previously mentioned by others. Good luck and get out there.
In dog years, I'm dead!
ZoominC6 is offline   Reply With Quote
Blow outs handn Tires 35 08-28-2008 01:07 PM
310 Underbelly Storage slide outs Chuckles Classic Motorhomes 1 10-22-2007 03:09 PM
Slide outs FireFighter Airstream Trailer Forums 1 05-14-2004 04:22 PM
Problems with Slide Outs? flyfisher Our Community 8 01-19-2004 01:10 PM
fuse burn outs Ed L Our Community 5 06-16-2003 10:10 PM
