Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Interior Restoration Forum > General Interior Topics
Old 11-14-2012, 06:16 PM   #1
mopariac's Avatar
1972 29' Ambassador
Weatherford , Texas
Smile Slide cover for the screen door replacement
I have what I think is the original plastic slide cover on my screen door. The part that covers the hole where the handle is. It is almost unusable because it is old and cracking to pieces. I have search for quite some time to find a replacement but I can only find large ones that don't fit my application. Mine is like 5" x 6". Before I manufacture one out of aluminum, does anyone know where I can find one that will fit my door? Does anyone else run into the same issue and if so what did you do?
mopariac is offline   Reply With Quote
Old 11-14-2012, 06:40 PM   #2
1976 Argosy 26
Fair Oaks , California
How about this ?
Screen Door Gizzy 72-77 200008 [200008] - $19.95 : Out-of-Doors Mart!, More Airstream Parts on-line than anyone!
Argosy Heir is offline   Reply With Quote
Old 11-14-2012, 08:08 PM   #3
mopariac's Avatar
1972 29' Ambassador
Weatherford , Texas
Thumbs up Thank you so much...
Wow I cannot believe I looked so long. Should have asked on here months ago. I'm in Texas but I am originally from Carmichael. I really like Fair Oaks.Thanks again and have a great day.
Old 11-14-2012, 09:27 PM   #4
1976 Argosy 26
Happy to help. I need one of those myself and have it on my mental shopping list.
Old 11-15-2012, 04:35 PM   #5
desertair27's Avatar
1960 26' Overlander
1963 24' Tradewind
El Paso , Texas
Images: 32
Thanks for the info. I've been looking everywhere for that thing
desertair27 is offline   Reply With Quote
Old 11-02-2013, 08:40 AM   #6
moparjohn's Avatar
1973 25' Tradewind
Bloomsbury , New Jersey
screen slide
OK, just got a new one, what did you guys use to trim it? MPJ
moparjohn is offline   Reply With Quote
Old 11-02-2013, 09:11 AM   #7
Minno's Avatar
1972 31' Sovereign
Lexington , Minnesota
We bought a new one as ours is cracked, but the new one is thicker than our slide ... haven't quite figured out how we're going to get it in there yet! We will probably have to sand down the edges to make it fit. Might want to check yours.
Kay
Old 11-02-2013, 11:41 AM   #8
Rivet Monster
wahoonc's Avatar
1975 31' Sovereign
1980 31' Excella II
Sprung Leak , North Carolina
Images: 40
Kay
I used a big pair of scissors to trim it to size, if it is too thick a low angle block plane works great for making it thinner along the edges.
Aaron
WBCCI #XXXX AIR #2495
Old 11-02-2013, 12:28 PM   #9
Aaron
That screen door slide is intentionally made larger, because of a variation in the screen doors.
Cut them down to a little less than 1/4 inch larger, and then flex them (bend them) so that they will fit into the screen door track.
Andy Rogozinski
Inland RV Center
Corona, CA
Old 12-13-2013, 05:30 PM   #10
terrencecolp's Avatar
1976 25' Tradewind
Tulsa , Oklahoma
screen door
Once installed, use silicone spray to loosen it up.
terrencecolp is offline   Reply With Quote
Old 04-07-2014, 01:06 PM   #11
Jessi64's Avatar
2014 16' Sport
Alliance , Ohio
Is there anything that you can use to replace it entirely with something more decorative? And the same goes with that steel panel in the middle of the door...
Jessi64 is offline   Reply With Quote
Old 04-07-2014, 02:49 PM   #12
robert claus's Avatar
2000 19' Bambi
mt. Prospect , Illinois
I had to put velcro on the edge of the sliding panel and where it closes to the door. Our cat learned he could push it open and jump out - not that he'd go anywhere. Pick him up and bring him back in, looking at you like "I just got out here!"
robert claus is offline   Reply With Quote
Old 04-09-2014, 07:04 PM   #13
Overland Adventurer
AtomicNo13's Avatar
2009 34' Panamerica
Telluride , Colorado
A quick spray with Rustoleum "aluminum" looks awesome. Looks like metal instead of the eventual yellow plastic door....
Old 04-09-2014, 07:24 PM   #14
1987 25' Sovereign
Oregon , Ohio
You could also try Krylon Fusion for plastic. No need to prime first.
msmcv51 is offline   Reply With Quote
Old 04-09-2014, 07:30 PM   #15
Overland Adventurer
AtomicNo13's Avatar
2009 34' Panamerica
Going on 4 years for both doors.... 3 kids 2 dogs; all well and shiny as new!
Old 04-12-2014, 09:41 PM   #16
1976 25' Tradewind
Tulsa , Oklahoma
Handle cover
That's so funny about your cat opening your cover and getting out. Every time I close mine my cat looks at me like (How'd you do that?).
Old 08-19-2020, 12:22 AM   #17
2017 27' Flying Cloud
1994 21' Sovereign
Capitola , California
Thank you to this forum we have looked for the Screen door sliding piece for a year!
I'm super happy to have found it!
smattson is offline   Reply With Quote
Old 08-25-2020, 03:55 AM   #18
Hilton Head , South Carolina
1972 Gizzy
Od before cutting 7 13/16 x 5 13/16
loridcook is offline   Reply With Quote
