06-12-2012, 10:54 AM
San Diego
Skin options for the interior of my 20' Argosy MH
Needing to replace the the interior skins on my 1974 Argosy MH 20'. What are my options or suggestions. Half of the old panels are gone.
06-13-2012, 04:53 PM
1977 20' Argosy 20
Charleston
, West Virginia
Are you talking about the aluminum panels or the molded plastic inserts (like over the driver's area)?
The interior walls are aluminum sheets with contact paper riveted to the frame.
06-13-2012, 06:24 PM
1968 28' Ambassador
Cedaredge
I thought about putting 1/8 in plywood up. but you can use aluminum our anything that will curve slightly.
Jason
2008 5.7 L V8 Sequoia
AIR # 31243
WBCCI # 6987
FOUR CORNERS UNIT
06-16-2012, 10:26 PM
San Diego
inside panels but not yhe front or rear bulk areas
06-16-2012, 11:01 PM
1974 23' Safari
1947 25' Spartan
, Manor
Someone correct me if I'm wrong, but those inside panels are structural, so I would go with aluminum of the same (or greater) thickness.
06-17-2012, 06:28 AM
People's republic of gainesville
Might not be structural on a MH, if that is what the original poster has. Jim
06-17-2012, 06:41 AM
1974 23' Safari
1947 25' Spartan
, Manor
Looks like a 20' Argosy....
If you want to use wood I would still say put the aluminum up first, the main reason being that IF (or maybe it's better to say WHEN) a leak happens you will have at least one barrier between the wood and the water.
The second reason is that there are a surprisingly small amount of ribs to secure the inside skin on. This works alright for aluminum, but wood might be more difficult to secure if you can't put screws anywhere you need them.
Just my thoughts....
06-17-2012, 05:21 PM
1977 20' Argosy 20
san diego
Interesting. I've owned my 20 footer for 10 years and wondered the same thing. Some of the panels, like in the kitchen are abs. That said, it seems to me that in Airstream's design the interior panels are an integral part of the structure.
While there may some abs in places, it doesn't follow that the aluminum isn't needed.
Without addressing strength issue wood vs. aluminum, having put 30,000 mi.
on mine, wood may be strong enough but too soft for the fasteners with the jarring of the ride. When the suspension is refreshed with new bushings, etc.,
It's a stiff ride.
By the way, Iam in San Diego if you want to PM me.
06-18-2012, 05:37 PM
San Diego
San Diego Stoke!
I'd love to connect and ck yours out. With the exception of the bathroom and ajoining closet my 20' is stripped right down to the bare aluminum on the inside. PO kept 90% of what he removed plus he had partialy stripped another 20'er so I have a lot of duplicate parts. Missing the drivers side rear banana skin and I can't seem to find one anywhere.
bIRD
Bird's Surf SHED
San Diego, Ca 92110
619 276 BIRD
06-18-2012, 06:00 PM
1974 23' Safari
1947 25' Spartan
, Manor
bIRD
Bird's Surf SHED
San Diego, Ca 92110
619 276 BIRD
Cool surf shop!
06-18-2012, 09:12 PM
San Diego
Thanks!
06-18-2012, 10:27 PM
1975 Argosy 28
Fresno/Clovis
bIRD
Bird's Surf SHED
San Diego, Ca 92110
619 276 BIRD
Inlandrv has banana wraps made out of abs for some MH.
Roger
Air# 29488
TV-2012 Silverado LTZ 4WD
Looking for a good used main entrance screen door.
| Thread Tools |
| Display Modes |
