Old 06-12-2019, 08:32 PM   #1
Houston , Texas
Skin and rib high temperature
Has anyone ever measured how hot the skin and ribs get in direct sunlight (from the inside)? Just want to know how heat resistant the materials need to be.
John
John_Dennis is offline   Reply With Quote
Old 06-12-2019, 08:58 PM   #2
1966 22' Safari
Fredericksburg , Texas
John, there are threads on the forums discussing heat transfer through the skin and ribs. I know I’ve read the temperature swing. The skin temperature can get very hot on the inside if you don’t design for that. In rebuilding ours we did use a thermal break to help out. Good luck.
Bubba L is offline   Reply With Quote
Old 06-14-2019, 06:43 PM   #3
Houston , Texas
I have read through a number of threads about insulating and temperature but never found a mention of how hot the skin gets. I am wanting to be sure any materials I use can withstand that much heat.
Old 06-14-2019, 07:39 PM   #4
Overkill Specialist
GMFL's Avatar
2014 23' International
Dadeville , Alabama
Direct sin? Temp could easily get 120-130 degrees
GMFL is online now   Reply With Quote
Advice re: dent in skin/rib algebrotha Ribs, Skins & Rivets 25 02-13-2018 02:43 PM
hydraulic leveler question - how high is too high? JourneytoRet Flat-Front (Cutter, Clipper, XC, XL & Skydeck) Motorhomes 12 04-06-2013 11:33 AM
Gas Prices for 2011 - How high is too high to tow? Kosm1o On The Road... 77 01-02-2011 09:48 PM
Gasket Material for rib before installing Interior skin CapnTom Ribs, Skins & Rivets 13 01-19-2010 07:56 AM
