Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Interior Restoration Forum > General Interior Topics
Old 10-23-2009, 07:58 PM   #1
Airstreamin and luvin it
Commercial Vendor
Devoman's Avatar
Profile:  2005 25' Safari
Northwest Panhandle , The Sunshine State/WBCCI 6637
Shub Door Came Off!!!!
Getting things ready today and started to put things in the shower area.It seems that the double sided sticker that hold the shub frame in place seperated from the half inch wall.I put it back together but dont know how long this will hold.Has anyone ever had this happen to them?I even noticed how simple the shower area was made and it can really use some modding up to make it more water proof in certain areas.
It just suprised me that they used double sided tape to mount these up to hold the door into place.I would have thought that even some type of caulking would also help.
Blue Numbers and Signs
E-mail me for quotes.
Devoman is online now   Reply With Quote
Old 10-23-2009, 09:41 PM   #2
ROBERTSUNRUS's Avatar
Lakewood , California
Images: 18
Hi, my shower door has not fallen off, but due to flexing and changes in temperature, my upper cross bar/brace become loose. I took the upper cross bar off and installed a nylon [square] license plate nut in one end. This made for a tight fit. I also re-sealed my Shub with bath tub sealer on both sides where it meets the wall. Been a few years and no problems.
2005 Safari 25-B
"Le Petit Chateau Argent"
[ Small Silver Castle ]
2000 Navigator / Equal-i-zer / P-3
YAMAHA 2400 / AIR #12144
Old 10-23-2009, 10:55 PM   #3
Commercial Vendor
Devoman's Avatar
Sealer
I am going to seal it with some bathtub sealer and a piece of clear angled plastic trim to lay on top of it.that should hold it down good.Seems like the glue gave way though.Maybe some dabs sikaflex in some areas may help it stick better.
Old 10-23-2009, 11:43 PM   #4
tpi
Trabuco Canyon , California
Mine did that a couple years ago. I noticed it gradually shifting, I suspect due to vibration and expansion cycles.
I slipped a putty knife into the double sided tape area, broke it loose, and relocated in the appropriate position. Then I caulked along the inside wall edge/shub from top to bottom. Mine had been shifting outward toward the toilet (more at the top than the bottom).
The caulk has held fine for a couple years now with no further shifting.
tpi is online now   Reply With Quote
Airstream outside entry door with screen door & trim netlace Doors & Locks 1 10-02-2009 06:53 PM
Vintage 70's Shower Door and Water Heater Door -- Freebie maccamper General Repair Forum 6 05-15-2009 10:18 AM
Da Shub...... SafariSS Plumbing - Systems & Fixtures 0 04-22-2007 10:17 PM
Weather seal for '57 door and screen door cdmagda Doors & Locks 0 09-01-2005 10:40 AM
Pocket Door vs. Accordion (folding) Door A/S Interior pap Cabinets, Counter Tops & Furnishings 12 03-10-2005 05:40 PM
