Old 05-17-2012, 03:42 PM   #15
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
Thumbs up
I had the "no stick double sided tape" fail. Leaked like a sieve.
Shower frame pulled away from the wall.
Tried better tape, several different caulks nothing held.
Shower=Water...light bulb moment.
Last resort...marine epoxy resin mixed with verrrry fine sawdust, with a 1/4 round molding at the bottom epoxied to the wall for extra support. A thick bead of PL roof caulk across the threshold frame.
No leaks and SOLID
ID:	158665   Click image for larger version
PFC
"Tahawus"
but Iím the Husband, so we went to Cleveland. 😂
RLC
Step aside Starbucks, this is a job for alcohol.
Old 05-18-2012, 01:48 PM   #16
B25guy's Avatar
2003 25' Safari
Yakima , Washington
Images: 20
finished re=installing shower door
I made one little modification...drilled an 1/8" hole to drain ALL the water back into the shower. I noticed that after plugging the two holes in the bottom (that were causing the original leak to the outside of the shower), there was about a 1/16" of a lip preventing all of the water to drain fully out of the notch where the curtain retracts.
I've tested it by squirting some water into the box and it all comes out the new hole...yay, no more puddle outside!
Marc
ID:	158726   Click image for larger version
B25guy is offline   Reply With Quote
Old 05-18-2012, 02:07 PM   #17
2002 19' Bambi
Lafayette , California
The rollaway shower door in our 2002 Bambi is the same as B25guy's and has leaked twice since the trailer was new. In both cases it was because the caulking along the bottom rail had lost adhesion with the edge of the shower stall. The first time it started to leak, I went nuts trying to find the problem because the caulk LOOKED like it was okay. The second time, I knew exactly what to do and stripped out the old caulk and put in new in about 30 minutes.
B25guy's solution for that little lip sounds good. I cut a little channel on the inside (on the shower side) so the water could run out. Caulk on the outside took care of the two drain holes.
Tim
Tim A. is offline   Reply With Quote
Old 05-18-2012, 04:25 PM   #18
1994 30' Excella
Mississauga , Ontario
the important thing with these acrylic or fiberglass enclosures is to make sure that you are using a caulk that holds to those surfaces. A lot of silicone caulks do not.
Al
Al and Jean
TAC ON-3
Old 05-19-2012, 06:22 PM   #19
Travel Bird's Avatar
2012 27' FB International
Denver , Colorado
Here is the info. I received from Andy Thompson, Can-Am RV. He highly recommends the roll away shower doors:
$330.00 The roll away shower door does not have as much bling as the chrome one that Airstream installs but I find them much more functional. First of all having the opening into the shower makes the hallway feel wider. If you want to hang bathing suits or towels in the shower they will try as there is air flow. Getting in and out of the shower is easier because the door is not swinging around or getting tangled with the bath door. Also the swinging door drips water all over the floor when you open it. The roll away door just looks like plastic but is a really well done piece the panel is made a material that wonít mold and it has squeegee that wipes the water off it when you roll it up. They have been used in the corner bath Airstreams for 11 years now, we have never had to replace one.
ID:	158778   Click image for larger version
Name:	Door Closed.jpg
Anna
Blog: Glamper~An Airstream Diary
www.glamperanairstreamdiary.com
WBCCI #4846, WBCCI DenCO Unit
Air #62992
Travel Bird is offline   Reply With Quote
Old 06-30-2017, 05:30 AM   #20
1990 34' Excella
Dorchester , America
Send a message via Skype™ to rjgmt1
Nick, I love your tag line "The Price of Freedom ..."
rjgmt1 is offline   Reply With Quote
Old 06-30-2017, 06:38 PM   #21
....and it's certainly still true, as, for example, I recently replaced my rotted out water heater for the second time. You may have noticed that my contribution to this thread is more than twelve years old. What an excellent forum!
Nick.
Nick Crowhurst, Excella 25 1988, Dodge Ram 2500 Cummins Diesel. England in summer, USA in winter.
"The price of freedom is eternal maintenance."
nickcrowhurst is offline   Reply With Quote
Door Catches niftypkg Doors & Locks 4 05-22-2007 05:09 PM
Shower door. Has anyone put one on a 1987 345 or similar airstream with curtain? MacInDaBox Airstream Motorhome Forums 2 05-17-2007 12:06 PM
1965 Main Door buckmaster 1965 - 1969 Globetrotter 0 10-19-2002 07:47 PM
Bent Trailer Door Argosy74 Doors & Locks 3 09-03-2002 08:31 AM
