Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Interior Restoration Forum > General Interior Topics
Old 04-27-2005, 08:30 PM   #1
1977 31' Sovereign
davidh's Avatar
Kalispell , Montana
Question Secure TV While in travel
What is the best way to secure TV while traveling? And other loose items stored on floor? Need help with some ideas.
davidh is offline   Reply With Quote
Old 04-27-2005, 09:39 PM   #2
Contributing Member
Pahaska's Avatar
Austin (Hays County) , Texas
I use the adhesive TV ties that are available at Camping World and most RV dealers. They have them that will tie down quite large TV sets. I used them on the credenza to tie down a 13" set with built-in DVD player and it never moved. I used 2 ties on diagonal corners of the set.
My current flat panel TV simply lies on its face on a non-slip pad on the credenza and never moves.
Stuff on the floor, I make sure is against a forward surface and I use a pillow or something similar o keep it from sliding or tipping to the side. Braking is the only real strong force that the object will experience; accelleration is too slow to make any difference.
John W. Irwin
2018 Interstate GT, "Sabre-Dog V"
WBCCI #9632
Old 04-28-2005, 11:34 AM   #3
1977 31' Sovereign
davidh's Avatar
Kalispell , Montana
Exclamation Thanks PaHaska
Thanks alot, I will look for those ties this weekend. I am new to this and I do not want to Butcher up the inside of the trailer as it is in mint condition. Any other tips on storage while traveling would be of great help. Thanks again!
Old 04-28-2005, 04:52 PM   #4
scf31's Avatar
1977 25' Caravanner
Jeffersonville , Kentucky
Nothing on the counter tops,they slide off and you get a suprise when you open the door,
scf31 is offline   Reply With Quote
Old 04-28-2005, 05:16 PM   #5
norbert's Avatar
1993 30' Excella
whitewater , north of cheddar curtain
Images: 24
i got the xtra large ties for my 13 inch, and it didnt hold...rather then put a screw into my counter top...the tv goes on the floor before departure.
make sure your refrigerator door is secured...i had one hell of a surprise also my coffee maker goes in the sink
norby
Illegitimous noncarborundum(dont let the bastards wear you down)
The only true nobility is found through giving good food to your friends- Anton Careme
beauty is in the eye of the beerholder-cosmo fishhawk
if something is too good to be true, its usually gone before i get there-mister boffo
norbert is offline   Reply With Quote
Old 04-28-2005, 05:21 PM   #6
Retired Moderator
john hd's Avatar
1992 29' Excella
madison , Wisconsin
Images: 40
i made a seat belt for mine!
i used two 3 inch heavy duty brass door handles screwed into the cabinet behind the tv. then i went to the hardware store and purchased 6 feet of 3 nylon webbing with adjustable buckles. the kind that snap together like a seat belt.
i threaded the webbing through the door handles and around the zenith. one snap and it is secure. it has never fallen off the counter yet, even after some pretty serious braking. sure beats picking it up off the floor every time i want to walk through the trailer!
john
you call them ferrets, i call them weasels.
Old 04-28-2005, 06:07 PM   #7
Cracker's Avatar
Pittsfield , Maine
We wanted a large screen TV - 20" to satisfy our old eyes. The Toshiba fit the bill due to a "cut-away" rear tube enclosure that overhangs the dinette. I take it off of the living room credenza and place it with the face against the sofa. Two nylon straps wrap around the TV and the front upper round bar of the sofa in transit. The DVD player velcros to the top of the TV - although I normally remove it for travel.
Cracker
Cracker is offline   Reply With Quote
Old 04-28-2005, 09:14 PM   #8
myboyburt's Avatar
1993 25' Excella
Full Time , Anywhere USA
Images: 12
Not the TV but other stuff stored in shower pan
We store items in our shower pan while in transit. It has raised sides and I place towels around the items so they don't move around much. Flat stuff I store under the twin mattresses in the bedroom area (i.e. small folding table and books). Just need to remember to remove the items when I go to bed as it makes for a lumpy restless night if I forget.
Michelle & Leon
New England Unit
myboyburt is offline   Reply With Quote
Old 04-28-2005, 09:25 PM   #9
Tinsel Loaf's Avatar
Face down in the middle of the bed.
Tinsel Loaf is offline   Reply With Quote
Old 04-28-2005, 10:55 PM   #10
1977 31' Sovereign
davidh's Avatar
Kalispell , Montana
Cool Thank's to all
Thank's to all that replied it is very much appreciated. If there is more addvice for this greenhorn it will be needed, thanks again you all have been of great help davidh..
Old 04-29-2005, 11:07 AM   #11
5 rivets, 1 loose screw
Rog0525's Avatar
1966 20' Globetrotter
Saginaw County , Michigan
Images: 11
securing the tv
I started a thread on this same topic some time ago.
Suction cups and bungee cords worked for me. No screws or adhesive.
I had a little 18' Caravel at that time.
http://www.airforums.com/forum...t=suction+cups
Rog
May you camp where wind won’t hit you, where snakes won’t bite and bears won’t git you.
Rog0525 is offline   Reply With Quote
Old 04-29-2005, 12:17 PM   #12
DayStreamer
grizzy's Avatar
2001 19' Bambi
Mesa , Arizona
We purchased a 17" flat panel TV at Best Buy -- they are getting fairly inexpensive. It gets stored in the bottom of the closet until we want to watch. Its very light and only requires plug into the power and plug into the antenna. Works great and is out of the way when we aren't watching.
Dave
DayStreamer
2001 19' Bambi
02 Avalanche
Mesa Arizona
AIR #5591
grizzy is offline   Reply With Quote
A&E Travel Awn 5000 uwe Awnings 11 07-05-2016 07:33 AM
Broken Travel Lock Charcigar Doors & Locks 2 06-08-2004 08:23 AM
Travel on 1 axle. Over59 Axles 6 04-18-2004 04:22 PM
Travel to Rosarito Mexico Krazykraut Airstream Motorhome Forums 6 10-18-2002 06:59 PM
Trailer Travel, a visual history of mobile America 83Excella Our Community 6 08-20-2002 07:13 AM
