Old 08-26-2010, 04:38 PM   #1
1966 22' Safari
1951 18' Clipper
franktown , Colorado
Seam sealing from the inside?
Hello all,
In the midst of my restro on a 51 Clipper. Currently the interior skins are all out and I am getting ready for wiring and insulation. It has occured to me that the exterior skins when lapped and riveted create two different seams........one on the outside and another on the inside. With all the interior seams now exposed, I should take the time and do some sort of seam sealing to them. Could not hurt ....right? At close observation, it appears that they were not sealed on the inside from the factory. I could get as sloppy as I want to as you will never see it once the insulation goes in. What are your thoughts and what would you recommend?
ironheadxlch is offline   Reply With Quote
Old 08-26-2010, 05:47 PM   #2
truckasaurus's Avatar
1960 33' Custom
Saskatoon , Saskatchewan
I'm thinking of using spray rubberized undercoating on my inside seams, the factory riveting was pretty sloppy in places so I think $20 of spray can't hurt.
truckasaurus is offline   Reply With Quote
Old 08-26-2010, 05:55 PM   #3
1952 25' Cruiser
Foresthill , California
We used a high adhesive foil sealer tape on all our inside rivit seams prior to insulating. I'll look for the brand name and get back with you. Here are a couple of photos.
ID:	109441   Click image for larger version
PRATTMAN is offline   Reply With Quote
Old 08-26-2010, 06:11 PM   #4
1994 30' Excella
Mississauga , Ontario
In the home heating industry there is a foil tape that is used and I often find that in time it fails.
If I had my inside skins off I would trowel on a seam sealer. Maybe a polyurethane caulk or maybe duct sealer which can be purchased from a forced air heating duct supply house.
Al
Al and Jean
TAC ON-3
Old 08-26-2010, 06:25 PM   #5
nmbosa's Avatar
Nowhere , Washington
That's what I did with mine. I too figured it couldn't hurt.
Norm and Mary
blog: Captain Wilson's Overlander
nmbosa is offline   Reply With Quote
Old 08-26-2010, 07:55 PM   #6
r carl's Avatar
Lin , Ne
Vulkem 116 or similar should work great and last a long time. Around $6.50 a tube, cheap.
Old 08-26-2010, 07:55 PM   #7
1966 22' Safari
1951 18' Clipper
inside seam sealing
Hello all again,
It seems (no pun intended) that the Canadians have it by 2:1. I can see no down side to inside seam sealing.........just a matter of chosing which product one should use..........tape or sealent. . Being the lazy SOG that I am, I might just chose both. Thank you for your input.
Regards
Ironheadxlch
Old 08-26-2010, 10:00 PM   #8
Wabbiteer's Avatar
1972 29' Ambassador
St. Paul , Minnesota
Both tape and polyurethane caulk have a weakness - the surface they are being applied to. I had pockets of Vulkem between & under the taillights holding water that squirted like a clown flower when I was wedging the new floorboard in, freeze thaw cycles enlarged the area along the seams... Anyhow, some solvent scrub over the areas you're applying to to break the bacon grease and any other junk that could poison the adhesive bond.
Old 08-27-2010, 04:14 AM   #9
68 TWind's Avatar
1968 24' Tradewind
Oxford, , Mississippi
I would go to an auto body shop paint supplier, one that the body shops use, and get some seam sealer that brushes on. Body shops have used it forever, it will stop leaks and will last. Have you ever tried to remove some while working on a car, once it dries it is there forever.
Bruce & Rachel
68 Trade Wind
2001 Toyota Tundra
Old 08-27-2010, 07:48 AM   #10
2vets's Avatar
1960 24' Tradewind
St. Albans , Vermont
We used vulkem on all of the interior seams per Colin Hyde, who does vintage trailer restoration.
ID:	109454   Click image for larger version
2vets is offline   Reply With Quote
Old 08-27-2010, 08:06 AM   #11
Aerowood's Avatar
1971 21' Globetrotter
Arvada , Colorado
Thin Vulcum down with mineral spirits so that it will wick and paint it on with a brush
Old 02-26-2013, 05:48 AM   #12
Roadrunner's Avatar
1978 29' Ambassador
1974 25' Tradewind
1974 27' Overlander
Indiana , Pennsylvania
We are getting close to sealing the inside skins as well. Has anyone used something like "Flex Seal". Seems like it might work...
Indiana, PA
TAC PA-5
WBCCI 4871
Roadrunner is offline   Reply With Quote
Old 08-25-2015, 01:55 PM   #13
Marufaru's Avatar
1976 Argosy 26
Atlanta , Georgia
I was recommended Pro Flex Sealent. Apparently made for the RV industry. Anyone have experience with that?
Marufaru is offline   Reply With Quote
Old 08-25-2015, 02:22 PM   #14
BIGED52's Avatar
1967 22' Safari
MILAN , Illinois
Seam sealing
Try the product Captain Tolleys Creeping Crack Cure. It is available at most marine stores and wicks into cracks and seam/panel overlaps until the cracks are sealed. You can also use this on rivets to seal them. It is similar to automotive sealer but resistant to water intrusion. Then overlay seams with Vulkem or Acryl-R. No more leaks! Ed
1967 Safari Twin "Landshark" w/International trim package
1999 GMC Sierra 1500 SLT
FORUMS MEMBER SINCE 12/16/2004AIR#7110
"My tire was thumping, I thought it was flat. When I looked at the tire, I noticed your CAT!" Burma Shave
BIGED52 is offline   Reply With Quote
interior seam sealing GR8DANE Leaks - Weatherstrips, Gaskets, Caulks & Sealants 5 09-09-2013 11:58 AM
Sealing the inside seams? akmntman Leaks - Weatherstrips, Gaskets, Caulks & Sealants 5 07-15-2010 11:06 AM
Sealing Olympic Rivets From The Inside Dan Clayton Leaks - Weatherstrips, Gaskets, Caulks & Sealants 5 11-13-2006 09:02 PM
Seam sealing - again Fyrzowt Leaks - Weatherstrips, Gaskets, Caulks & Sealants 9 11-08-2006 12:01 PM
sealing leaks from inside lwebb Leaks - Weatherstrips, Gaskets, Caulks & Sealants 9 05-20-2006 07:36 PM
