Old 03-29-2004, 09:32 AM   #1
gregg's Avatar
sealing shower walls to pan
I found dampness in the cabinet forward of the shower. Upon inspection I found the caulk at the pan/wall seam had failed. This AM I started scraping the old silicon. I sprayed the walls with CLR and it leaves a clean-residue free surface on both the ABS pan and the phenolic laminate walls. I removed the rivets and spread the joint so I can get caulk down into the gap before installing the new rivets.
My question is-What shall I use to reseal this joint?
gregg is offline   Reply With Quote
Old 03-29-2004, 09:35 AM   #2
Just a member
thenewkid64's Avatar
1978 28' Argosy 28
Tampa Bay , Florida
Images: 21
I have redone my shower with ivory silcone. It works well in this application and is what the factory used.
Brett G
WBCCI #5501 AIR # 49
1978 Argosy 28 foot Motorhome
Old 03-29-2004, 09:53 AM   #3
gregg's Avatar
New Kid 64-Thank you. gb
Old 09-16-2009, 07:39 AM   #4
BakedTaters's Avatar
1969 31' Sovereign
Rockport , Texas
Maybe it's living on the coast, or working on boats, but we always end up using marine grade silicone, which is mildew and UV resistant. 3M 101, or if you never, ever plan on doing this ever again, 5200. However, 5200 is very permanent and it's a booger to get out, and that's where 4200 comes in, a less permanent version of 5200. Both come in fast cure, and both are 3M products.
BakedTaters is offline   Reply With Quote
Old 04-06-2016, 09:40 AM   #5
1989 25' Excella
Loretto , Tennessee
Thank you for the silicone tip. We are about to redo our shower. We have noticed that the walls are not sealed to the shower pan. Surely this causes water to drip between! Is this a problem or is there some sort of seal between the pan and wall that you can't see from the outside?
EmilyK is offline   Reply With Quote
Shower stall walls 53flyingcloud Upholstery, Blinds, Walls & Interior Finishes 11 04-07-2016 06:25 AM
Ugh! shower leak detected. mcostanzo Sinks, Showers & Toilets 1 10-03-2003 10:33 AM
Sagging Shower w9det 2001 Safari 1 09-12-2003 01:28 PM
Shower "door" leak mcostanzo Airstream Motorhome Forums 1 08-11-2003 09:37 AM
64 Bambi II shower pan Pat McSween Sinks, Showers & Toilets 2 08-02-2003 02:53 PM
